backup for vacuum pump/attitude indicator failure
Old November 19th 06, 02:16 PM posted to rec.aviation.owning,rec.aviation.ifr
Kelly
Default backup for vacuum pump/attitude indicator failure
I would be interested in getting opinions about backup systems for a
vacuum pump failure and/or AI failure. I have a 172P with a single
vacuum pump system, standard instruments otherwise, and a Garmin 430.
I am most concerned about having a good backup if I lose a vacuum pump
or AI in IMC. I have been thinking about either a Garmin 396/496 or
the electric AI available from Sporty's. Looks like I could get a 396
or installed electric AI for about the same price ($2200 or so). While
I haven't seen the panel page/"6-pack" page on the 396 or 496, I have
read (in Aviation Consumer) that it's good enough to keep control of
the airplane in an emergency situation. Obviously, the 396/496 has a
number of other neat features such as inflight weather, terrain info,
etc. Any suggestions on which way to go with this.
BTW, I had also considered the Precise Flight backup vacuum system for
a while, and it certainly is cheaper (around $700 installed). However,
I was concerned by the fact that it would do nothing for you in the
event of failure of the AI vs. the primary vacuum pump.
Thanks.
Kelly
Old November 19th 06, 03:17 PM posted to rec.aviation.owning,rec.aviation.ifr
: BTW, I had also considered the Precise Flight backup vacuum system for
: a while, and it certainly is cheaper (around $700 installed). However,
: I was concerned by the fact that it would do nothing for you in the
: event of failure of the AI vs. the primary vacuum pump.
The DG will still work though. In something like the 172 (or my Cherokee), that's a good chunk of the necessary gyro for IMC.
What about a non-TSO'd electric AI? Seems like one should be able to install one of those for backup purposes.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old November 19th 06, 05:40 PM posted to rec.aviation.owning,rec.aviation.ifr
Frank Ch. Eigler
"Kelly" writes:
vacuum pump failure and/or AI failure. I have a 172P [...]
Considering the nature of the 172, you likely don't engage in too much
heavy duty IMC, so backup equipment could be of the "help me land now"
kind rather than "help me fly for a few hours more" kind.
[...] While I haven't seen the panel page/"6-pack" page on the 396
or 496, I have read (in Aviation Consumer) that it's good enough to
keep control of the airplane in an emergency situation. [...]
You should also consider the iQue3600a, which has essentially the same
aviation features as the 396, at half the price, and with ground-side
utility as PDA and car GPS. (The other backup technologies you
mentioned have no separate ground utility.)
In any case, you should test it out. Borrow someone's
296/396/496/iQue or other portable aviation GPS, set it up in your
cockpit, go under the hood and do some partial-panel with a mostly
covered-up instrument panel. An hour or two might suffice.
- FChE
Old November 19th 06, 07:33 PM posted to rec.aviation.owning,rec.aviation.ifr
Frank Ch. Eigler
A Lieberma writes:
(Hm, I am talking to myself. :-)
Why would you say this based on a model of a plane? [...] Just
because it's a C172 doesn't mean the plane won't be flown in hard
IFR on a frequent basis [...]
The inherent limitations of range and speed complicate bad weather
diversion planning, power limits altitude reach and icing risk
exposure, small amount of redundancy turns malfunctions into
emergencies. So sure, it can be flown in hard IFR on a frequent
basis, but such greater risks have to be accepted.
- FChE
Old November 19th 06, 07:21 PM posted to rec.aviation.owning,rec.aviation.ifr
wise purchaser
Why not install a 4 inch Venturi on the side or the belly of the
aircraft ( 50 bucks aircraft spruce) then route to a selector valve
then you could switch between engine pump or venturi. This will drive
BOTH AI and the DG.
Or you could install the venturi to drive a back up CHEAP ( older type;
black face) Gyro Horiz. I am sure an instrument shop will sell you one
at a good price as every one wants a color faced type.
Now what about BACK UP electrical power thats CHEAP and portable!
I use one in my Airplane it provides 5 hours of FULL Avionics power !
It cost LESS than 30 bucks to make and all parts are from WAL - MART!
Hint: GARDEN TRACTOR
Old November 19th 06, 09:17 PM posted to rec.aviation.owning,rec.aviation.ifr
Jim Macklin
Hint, unless a homebuilt, all parts must be approved parts.
My vote for safety and redundancy would be for the Sporty's
AI [not as a replacement for T&B] and the 496 GPS. The 496
is aviation, marine and highway, it is your XM radio too.
Unlike the emergency attitude indicators used in jets, the
Sporty's AI does not have a separate battery for power.
You can have your shop create a redundant power source with
a small battery that will be charged from the bus, but
isolated if the alternator fails.
"wise purchaser" wrote in message
ps.com...
of the
selector valve
This will drive
| BOTH AI and the DG.
( older type;
sell you one
portable!
Avionics power !
WAL - MART!
Old November 19th 06, 09:42 PM posted to rec.aviation.owning,rec.aviation.ifr
Jose[_1_]
Is this really true? I cannot mount an unapproved CD player someplace
so that it won't flop around in flight?
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 19th 06, 11:45 PM posted to rec.aviation.owning,rec.aviation.ifr
Jim Macklin
yes
"Jose" wrote in message
m...
parts.
player someplace
| Jose
can't see where
Potter).
Old November 19th 06, 06:50 PM posted to rec.aviation.owning,rec.aviation.ifr
Robert M. Gary
I wouldn't bother with a backup vac system because its use is limited.
A backup pump won't cure a dead AI. I would buy the Sporty's backup AI.
For under $2K and next to no labor (just a couple power hookups ) you
get full, 100% AI redudency.
-Robert, CFII
Thanks.
Kelly
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 10:42 AM
Backup vacuum pump system STC'ed for Cherokee 180 Chuck Owning 6 September 18th 04 03:30 PM
Fllight Recorder Wars, Part II: What Backup to Use? Chip Bearden Soaring 13 March 31st 04 11:10 PM
Good AI backup, wish me luck Robert M. Gary Instrument Flight Rules 29 March 1st 04 06:36 PM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 10:53 PM
