Landing speeds for naval aircraft?
Old November 23rd 06, 09:46 PM posted to rec.aviation.military.naval
M. B.
Default Landing speeds for naval aircraft?
Here is a topic for discussion.....
The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is
taking a heavy toll and is wearing out faster than the design was
intended.
The "Growler" will come in heavier and faster.
Can the current configuration of the arresting gear handle it and not
have catastrophic fatigue failure without major modification?
I've heard the arresting gear is being overhauled on USS Reagan IOT support
Operational Test for Growler.
Old November 24th 06, 01:14 AM posted to rec.aviation.military.naval
John Carrier
"M. B." wrote in message
news:1Fo9h.6234$J5.4129@trnddc04...
intended.
support
Of course, its a function of weight and speed (squared if I remember my HS
physics correctly). The old RA-5C was pretty heavy and fast, the Whale was
just heavy. The F-14 could come aboard at 52.8 (later 54.0 IIRC, don't know
for sure, never flew the airplane with proper engines), but the speeds were
in the mid 130's.
Of course, the big deal on the Rhino (Grihno?) is bring back, so while the
airframe is relatively light, if its weight gets up there and the speed gets
into the high 140's ....
R / John
Old November 29th 06, 02:02 PM posted to rec.aviation.military.naval
fudog50 wrote:
Since the original question was about landing speeds, I assume you
mean traps?
intended.
I have landed onboard Nimitz as well as other CVs same class in the
Phantom, which I think was 'faster and heavier' than the 'Bug' series
of A/C'...same for the RA-5 and Whale(altho I don't know if it was
faster coming aboard than the F-4)..why would the Growler and Super
bugs start to wear things out now?
On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen"
The closer to the fuselage the greater the bending load on the wings due to
lift forces. But at the fuselage is where the "swing" hinges are typically
located, which makes for a complicated, and unnecessary, structural design
problem.
WDA
end
"DDAY" wrote in message
nk.net...
In article , "W. D. Allen"
Those swing wing aircraft disappeared for probably the same reason swept
wings are disappearing and ICBM rocket motor exhaust cone skirts are no
longer used. The performance increase was not worth the mechanization
complexity or maintenance.
Yep, that's the theory that I'm working toward--a change in the definition
of acceptable.
I recently saw an ad for an Indian airpower expo and it featured a sleek
concept model aircraft with swing wings. At first I was shocked and
wondered if this means that the Indians are actually considering building
such an aircraft. However, I soon noticed that the model appears to have
three engine inlets--two on either side (like an F-18) and a large ventral
one. That makes no sense and I think the model is notional. Other than
that, I haven't seen any serious consideration of swing wings in many
years.
D
I am using the free version of SPAMfighter for private users.
It has removed 917 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter for free now!
Old November 29th 06, 02:19 PM posted to rec.aviation.military.naval
Frank Minich
The RA-5C max trap was 50,000 pounds, at 139KIAS on-speed.
Maybe the numb-nutz has gone kinder/gentler since then.
Frank
mean traps?
intended.
due to
typically
design
problem.
WDA
end
nk.net...
In article , "W. D.
Allen"
swept
no
mechanization
definition
of acceptable.
sleek
building
have
ventral
than
years.
D
Old November 30th 06, 02:05 PM posted to rec.aviation.military.naval
Its a changed world. The Forrestals are now called "small decks" by
those grizzled salts that operated from them, and Rhinos are "huge".
Of course the gents who flew A-3s on the 27 charlies may have a
different perspective...
Frank
mean traps?
intended.
due to
typically
design
problem.
WDA
end
nk.net...
In article , "W. D.
Allen"
swept
no
mechanization
definition
of acceptable.
sleek
building
have
ventral
than
years.
D
Old November 30th 06, 02:18 PM posted to rec.aviation.military.naval
fudog50 wrote:
Stick with the original arguement-
"requirements changed and the swing-wing no longer fits
the existing problem set"
No military scenarios exist currently that would make it an option for
the cost.
Vector thrust has taken the place of swing wing.
As John has pointed out, swing wing was for high speed dash + slow
speed manuvering with a A/C big enough to carry the Phoenix, able to
come aboard small decks like the Forrestal class. Vectored thrust and
swing wing don't do the same thing at all. Better wings and engines and
digital flight controls have 'replaced' swing wing. Remember when the
Turkey was designed, by whom and why...Swing wing was already stuck in
the designers and $ people heads via the AArdvark...needed a CV capable
Phoenix carrier, Grumman was the USN's darlings...hence the F-14, by
Grumman...
On Sat, 18 Nov 2006 20:31:53 GMT, "DDAY"
What are the carrier landing speeds for:
The F-14 Tomcat?
The F-18A Hornet?
The F-18E/F Super Hornet?
I'm working on an article about the Space Shuttle and I want to address the
commonly repeated claim that the shuttle is a "mistake" because its
technology is being abandoned.
I'd like to compare it to swing-wing technology. During the 1960s, the
swing-wing was the rage in new aircraft design and it ended up in quite a
few aircraft such as the F-111, the F-14, the MiG-23, Tu-22, MiG-27, the
B-1, and the Russsian Tu-160. But the Tu-160, designed in the early 1980s,
appears to have been the last swing-wing aircraft.
What I'm trying to explore is why that is. Why was this technology really
popular for a couple of decades and then phased out? I don't think you can
say that better airfoil or wing technology replaced it. It's just that
requirements changed and the swing-wing was a solution that no longer fit
the existing problem set. But I'm willing to be proven wrong.
D
Old November 30th 06, 04:08 PM posted to rec.aviation.military.naval
John Weiss[_1_]
wrote...
I don't think anyone considers Forrestal -- the first of the "super
carriers" -- a "small deck"! OTOH, I watched a pair of turkeys land on
Midway... Now THAT was a "clobbered deck"!
Old November 30th 06, 08:16 PM posted to rec.aviation.military.naval
John Weiss wrote:
wrote...
If ya flew Turkeys onboard FID, like I did, it was a small deck.
Particularly after landing abord IKE, America and Nimitz...
Yep, I was there in VF-151 when those 2 landed during the North Pacific
'Fun-Ex'....Midway-maru had more acreage that FID, BTW-BUT Midway
always felt like it was 'small'...
Old December 1st 06, 12:50 PM posted to rec.aviation.military.naval
John Carrier
John Weiss wrote:
wrote...
Small was Oriskany, Hancock, and Lex and their sisters. Night traps on two
of them.
R / John
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
