Landing speeds for naval aircraft?
Old November 18th 06, 08:31 PM posted to rec.aviation.military.naval
DDAY
Default Landing speeds for naval aircraft?
What are the carrier landing speeds for:
The F-14 Tomcat?
The F-18A Hornet?
The F-18E/F Super Hornet?
I'm working on an article about the Space Shuttle and I want to address the
commonly repeated claim that the shuttle is a "mistake" because its
technology is being abandoned.
I'd like to compare it to swing-wing technology. During the 1960s, the
swing-wing was the rage in new aircraft design and it ended up in quite a
few aircraft such as the F-111, the F-14, the MiG-23, Tu-22, MiG-27, the
B-1, and the Russsian Tu-160. But the Tu-160, designed in the early 1980s,
appears to have been the last swing-wing aircraft.
What I'm trying to explore is why that is. Why was this technology really
popular for a couple of decades and then phased out? I don't think you can
say that better airfoil or wing technology replaced it. It's just that
requirements changed and the swing-wing was a solution that no longer fit
the existing problem set. But I'm willing to be proven wrong.
D
Old November 18th 06, 08:48 PM posted to rec.aviation.military.naval
Greasy Rider @ invalid.com
On Sat, 18 Nov 2006 20:31:53 GMT, "DDAY"
postulated :
The swing wing was a maintenance nightmare.
Old November 18th 06, 09:31 PM posted to rec.aviation.military.naval
Jim Carriere
postulated :
Also flaps and slats were improved to be similarly effective at reducing
approach speeds.
Old November 19th 06, 12:48 PM posted to rec.aviation.military.naval
John Carrier
"Jim Carriere" wrote in message
postulated :
really
can
fit
approach speeds.
Not exactly true. The F-14 had the lower approach speed by about 10 knots.
The major advantage to the swing wing is that it allows a design to have
good loiter and range characteristics plus excellent high speed capability.
Neither the Bug nor the Rhino can match the Turkey in these performance
parameters.
While high speed is apparently no longer a major design consideration,
loiter and range remain desirable. The Navy, when it hung its future on the
F-18, adapted to the aircraft's limitations in these areas by reducing or
eliminating deck cycles/times and learning to live with its performance
shortcomings.
R / John
Old November 19th 06, 06:27 PM posted to rec.aviation.military.naval
W. D. Allen[_1_]
Those swing wing aircraft disappeared for probably the same reason swept
wings are disappearing and ICBM rocket motor exhaust cone skirts are no
longer used. The performance increase was not worth the mechanization
complexity or maintenance.
WDA
end
"DDAY" wrote in message
k.net...
The F-14 Tomcat?
The F-18A Hornet?
1980s,
can
D
I am using the free version of SPAMfighter for private users.
It has removed 891 spam emails to date.
Paying users do not have this message in their emails.
Try SPAMfighter for free now!
Old November 19th 06, 07:19 PM posted to rec.aviation.military.naval
DDAY
In article , "W. D. Allen"
Yep, that's the theory that I'm working toward--a change in the definition
of acceptable.
I recently saw an ad for an Indian airpower expo and it featured a sleek
concept model aircraft with swing wings. At first I was shocked and
wondered if this means that the Indians are actually considering building
such an aircraft. However, I soon noticed that the model appears to have
three engine inlets--two on either side (like an F-18) and a large ventral
one. That makes no sense and I think the model is notional. Other than
that, I haven't seen any serious consideration of swing wings in many years.
D
Old November 22nd 06, 08:53 PM posted to rec.aviation.military.naval
W. D. Allen[_1_]
The closer to the fuselage the greater the bending load on the wings due to
lift forces. But at the fuselage is where the "swing" hinges are typically
located, which makes for a complicated, and unnecessary, structural design
problem.
WDA
end
k.net...
of acceptable.
years.
D
It has removed 917 spam emails to date.
Old November 23rd 06, 09:25 AM posted to rec.aviation.military.naval
fudog50
Since the original question was about landing speeds, I assume you
mean traps?
Here is a topic for discussion.....
The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is
taking a heavy toll and is wearing out faster than the design was
intended.
The "Growler" will come in heavier and faster.
Can the current configuration of the arresting gear handle it and not
have catastrophic fatigue failure without major modification?
On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen"
problem.
WDA
end
nk.net...
of acceptable.
years.
D
Old November 23rd 06, 09:42 AM posted to rec.aviation.military.naval
fudog50
Stick with the original arguement-
"requirements changed and the swing-wing no longer fits
the existing problem set"
No military scenarios exist currently that would make it an option for
the cost.
Vector thrust has taken the place of swing wing.
The F-14 Tomcat?
The F-18A Hornet?
D
Old November 23rd 06, 09:50 AM posted to rec.aviation.military.naval
fudog50
Sorry,
To clarify,
Landing speeds are not the only consideration.
Lift on takeoff is the major consideration.
Can you imagine a Tomcat with TF-30's trying to take off with wings
swept? About 8000 ft maybe on a good day!
(granted with 110-400's and wings extended about 2500 ft)
On Thu, 23 Nov 2006 01:25:43 -0800, fudog50
mean traps?
intended.
problem.
WDA
end
ink.net...
of acceptable.
years.
D
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
