Question on Baron 58 prop control
Old November 28th 06, 03:52 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default Question on Baron 58 prop control
Air mass
"BT" wrote in message
| "Mxsmanic" wrote in message
| Allen writes:
| As Jim said the PW PT6 engine has no physical
connection between the
| power
| section and the drive section.
| How does power get from one to the other?
| air pressure
Old November 28th 06, 04:04 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Barrie writes:
How does this compare with the present form of propulsion, such as in the
B747, which I've heard being called "Fanjet"? Is it the same but turbine
blades replace propellor blades while serving a similar function?
Essentially, yes. A turbofan is a jet engine with a very large front
fan in a duct. This fan, which is driven by a turbine in the
combustion section that in turn is driven by hot exhaust gases,
provides most of the thrust. It's like a many-bladed propeller in a
duct (whence the term "ducted fan," which is occasionally used). It's
much more efficient than a pure turbojet, and it also has advantages
over an open prop. It's the preferred mode of propulsion for
commercial airliners these days.
However, turbofans don't work well at transonic and supersonic speeds,
although I understand that these problems have been fixed in recent
years. Likewise, they don't have significant advantages for low speed
flight like that of a small GA plane.
Old November 28th 06, 04:06 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Doug writes:
And that is why a sim will NEVER be like true flight. With a sim, if
you crash, you crashed and you are ok. With a real airplane, you
crashed, and that's IT! No more you. A different headspace, attitude,
whatever you want to call it.
A good simulator can very rapidly make you forget that it's just a
simulator. This is hard with MSFS because it doesn't move or provide
the physical environment of a cockpit, but if it did, you'd start
mistaking it for real pretty quickly.
Even as it is, it can be stressful when things go wrong in the sim
environment.
If you prefer risking your life for real, that's your choice.
Personally, I see that as a drawback to real flight, not an advantage.
Old November 28th 06, 04:09 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
A Lieberma
"Doug" wrote in news:1164680980.670569.130090
@l12g2000cwl.googlegroups.com:
Hey Doug,
Having been there done this with Mx (sim vs real world), you are wasting
your time with Mx as he is a troll (as you will note from his reply to
you). Just check out his recent postings and you will clearly see this.
You just may want to ignore Mx's postings and reply to those who really
appreciate the time you take in answering their questions.
Thanks!
Allen
Old November 28th 06, 08:31 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Robert,
I honestly haven't had the
time to install it.
Well, let's hope you at least have the 15 Gig (!) of free HD space it
requires.
Thomas Borchert (EDDH)
Old November 28th 06, 12:14 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Neil Gould
Recently, Mxsmanic posted:
Doug writes:
I've been in several "real" & full-motion simulators, and none of them
confused me about the reality of the experience. It is not the same at
all.
Neil
Old November 28th 06, 05:28 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Robert M. Gary
Thomas Borchert wrote:
Robert,
time to install it.
requires.
So what? Disk space is basicly free nowadays.
-Robert
  #28
Old November 28th 06, 07:17 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Robert,
not in my laptop.
  #29
Old November 28th 06, 11:47 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Steve Foley[_2_]
"Thomas Borchert" wrote in message
Robert,
not in my laptop.
The drives in most laptops are now interchangeable.
Check he
http://www.tigerdirect.com/applicati...asp?CatId=1277
  #30
Old November 29th 06, 12:43 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Dave[_1_]
And the Lake "Renagade": amphib can also.... reverse pitch for
stopping and reversing.
Dave
On 27 Nov 2006 15:24:36 -0800, "Doug"
Some seaplane props are featherable and reversable so the seaplane can
stop or backup and so the prop can be used as a brake. I believe the
Cessna Caravan in Seaplane config can do this, not sure.
Question on prop cycle Frode Berg Owning 9 April 25th 06 06:36 AM
Prop Balancing Question A Lieberman Owning 3 February 1st 06 11:25 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
