aluminum rib, aluminum spar, holes drilled but screws broken off
Old December 7th 06, 11:37 PM posted to rec.aviation.homebuilt
jls
Default aluminum rib, aluminum spar, holes drilled but screws broken off
I'm rebuilding a Super Cub wing and the flanges on the ribs and the
spar caps have been drilled perfectly so the #4 steel screws go right
in, that is, if a screw has not been broken off. In which case I have
the option of redrilling and turning the spars into Swiss cheese and
losing ac43-13 edge distance on the rib flanges, or drilling out the
broken, embedded screws. Trouble is that when I try to drill the damn
broken screws out they harden and the drill bit becomes useless.
Looks like I need a #45 drill bit made of diamond or carbide. Ideas?
Thanks.
Old December 7th 06, 11:59 PM posted to rec.aviation.homebuilt
Thanks.
I have a set of silicon carbide tipped drills. The guy
I bought them from used to go around to woodworking
shows demoing them by drilling holes in files and bricks,
glass blocks, all sorts of things, all with the same bit.
Yes, silicon carbide, not tungsten carbide.
Altavista has lots of hits on "diamond drill bit'".
But a #4 screw is tiny. Good Luck.
FF
Old December 8th 06, 06:07 PM posted to rec.aviation.homebuilt
jls
Thanks.
FF
Thanks, Fred. All these ribs I bought from Northland in Dakota
Territory @ $50 apiece were already drilled for screw holes-- eight per
rib and two for each nose rib. They matched up perfectly to the holes
drilled in the spars when this aircraft was built at the factory in the
fifties, so when I began fastening new ribs to the old spars I began
finding holes that were stopped up, i. e., holes where screws had been
broken off.
So a guy in the Supercub Club from the Cleveland area has advised me to
buy a pencil die grinder, i. e., a carbide tipped tool--- like the
dentists use--- to drill out the embedded screws.
Thanks for your very informative post.
Old December 8th 06, 10:25 PM posted to rec.aviation.homebuilt
Thanks.
FF
broken off.
If you live close by to Greenbelt, MD or can wait until the next time
I'm in Cleveland, I'll lend my bits to you if you want to try them out.
Also, there are diamond bits available for the dremel tool.
FF
Old December 8th 06, 10:30 PM posted to rec.aviation.homebuilt
wright1902glider
You might also try a left-hand (that is the reverse of standard,
right?) drill bit. HF sells 'em, and you may also find them packaged
with a set of EZ-outs at the BLUE or ORANGE stores. That might work if
the screws aren't corroded into the holes. If there's enough of a screw
left, I've also had mixed results filing flats on the screws 180
degrees opposed, and grabbing on with a crescent wrench or vice-grips.
Careful, don't break the screw off a second time like I did.
You might also try drilling with cutting fluid. I had a similar
experience trying to drill out a set of rivets holding the ball joints
into my Dodge. (Wadda they make those damn rivets out of anyway?) With
the hand-electric drill it took 27 broken bits and 4 days. When I did
the other side, I pulled the a-arm out of the truck, mounted in a vise
on the drill press, and then drilled down using a 1/64" cobalt bit and
cutting fluid. It only took about 5 minutes per hole using 7 different
sized bits to achieve the same results. I wasn't using any more
pressure or speed with the drill press. So maybe the cutting fluid is a
semi-magic bullet?
Thanks.
FF
broken off.
Old December 8th 06, 10:41 PM posted to rec.aviation.homebuilt
jls
FF
Well, Fred, I'm in Western North Carolina, but if you could tell me
where to purchase those silicon carbide bits, I'd buy some. Sounds
like all of us need some. I get tired of breaking bits all the time
and tossing away the dull ones. They ought to all be made out of
carbide or be diamond-tipped, unless you're drilling wood or soft
aluminum.
Thanks.
Old December 8th 06, 10:45 PM posted to rec.aviation.homebuilt
jls
semi-magic bullet?
Excellent advice, there Wright 1902. Thanks a lot. I'll run to the
HF store and see what I can find. Something's gotta work.
Old December 9th 06, 12:44 AM posted to rec.aviation.homebuilt
Sears has a nice set of extractors called "Power Extractors" that go
down to #40 size. In the small sizes, they have a left hand drill on
one end, and a fluted extractor on the other. I have used them to
remove many a broken and stuck screw on my plane and they work well.
The product # is 00952155000 on the Sears website. Also this webpage
has it.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Most Sears stores I have looked in have them.
Regards,
Bud
semi-magic bullet?
Old December 12th 06, 03:20 AM posted to rec.aviation.homebuilt
jls
Correction. Those ribs are Dakota Cub ribs from Dakota Territory, and
I bought a great set of struts and rudder from Northland in Alaska.
Great prices on shipping too, because of all the airplanes coming out
of Alaska almost empty, but going up full.
Thanks to Bud for the info on the Craftsman easy-outs.
I'm out here on an airport in the mtns. using a laptop and wireless
(and freezing) and it's the most beautiful place in the world. Don't
you think an airport at night with all those lights is prettier'n a
Christmas tree?
Old December 12th 06, 03:56 AM posted to rec.aviation.homebuilt
Stella Starr
Default aluminum rib, aluminum spar, holes drilled but screws brokenoff
Yup!
Christmas tree?
misdrilled hole on on tubular aluminum spar question patrick mitchel Home Built 12 October 2nd 06 08:17 PM
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
