misdrilled hole on on tubular aluminum spar question
Old October 1st 06, 04:44 PM posted to rec.aviation.homebuilt
patrick mitchel
Default misdrilled hole on on tubular aluminum spar question
There's a discussion on a ul ng about a guy that built a strut braced light
plane and in a fit of overkill (apparently ) decided to add a (non plans)
jury strut. He drilled a hole (3/16") on the bottom of the tubular alum
spar. Then realized he may have made a mistake. Whats the outcome and is
there a fix without putting in a new spar. Just curious (and I didn't do
it!!) Pat
Old October 1st 06, 05:47 PM posted to rec.aviation.homebuilt
Stache
it!!) Pat
Answer: There is a repair, but a DER structural engineer should review
the repair. The repair is to ream the hole to accept a bronze bushing
and maybe a doubler depending on the location, edge distance, and
material make up. This is no place to guess or just replace the spar.
Stache
Old October 1st 06, 05:51 PM posted to rec.aviation.homebuilt
J.Kahn
it!!) Pat
The bottom of a strut braced spar in the mid span location between the
fuse and main strut attach will be under compression, not tension, so
the hole may be benign if it is filled with a rivet to restore most of
the compression strength in that area. Possibly a doubler patch is in
order to prevent buckling of the weakened area, but the doubler has to
be properly designed minimize the effects of the sudden change in
resistance to buckling due to the patch, depending on the local loads.
The good news is a tubular spar must be sized to deal with the loads at
the highest stress point, which is on the outboard side of the strut
attach fitting, so for the rest of its length it is overbuilt.
Two options:
1 He should confess what he did to the plans maker and ask for a repair
scheme or recommendation. I would be surprised if he didn't ok a plug
rivet in the hole, especially if there are already rib attachment holes
in the same area to each side.
2 If the plans maker says he has to buy a new spar, find a structural
repair specialist for a recommendation.
John
Old October 1st 06, 06:42 PM posted to rec.aviation.homebuilt
Orval Fairbairn
it!!) Pat
WRONG! WRONG! WRONG! The bottom of a wing spar (assuming +G) is ALWAYS
under tension! The hole creates a stress concentration and can impair
the ability of the spar to carry design loads.
Two options:
Mandatory!
I would be surprised if the designer DID approve of plugging the hole
with a rivet, as a rivet will add stress to an already stressed part.
Buy the new spar and chalk one up to experience and ignorance.
Old October 1st 06, 08:26 PM posted to rec.aviation.homebuilt
jerry wass
it!!) Pat
RIGHT! RIGHT!RIGHT--READ THE WHOLE PROBLEM. It is a Strut Braced wing !
-he's installing a jury strut, so he is between the load restraining
points of the spar, Always under compression with Pos. G's Would go
into tension with Neg G's--but how much can you load this type of
construction with Neg G's??
Two options:
Mandatory!
Old October 1st 06, 09:09 PM posted to rec.aviation.homebuilt
Orval Fairbairn
light
it!!) Pat
Go back and draw in your stress paths! There may indeed be neutral
stress on the spar between the root and the strut attach point, but it
is likely in tension. The strut takes up the entire moment of the wing,
however.
Two options:
Mandatory!
Old October 1st 06, 10:22 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Orval Fairbairn" wrote in message
news
light
plans)
is
do
it!!) Pat
snip
The strut is in tension and at an angle to the spar which puts a compression
load on the spar. Aerodynamic forces between the strut and the root tend to
lift the wing, which increases the compression on the bottom of the spar
between the strut and root (supported at both ends).The moment applied at
the strut from the outboard portion of the wing tends to put the top in
compression, the bottom in tension. The net result (tension or compression)
depends on the details of the geometry - how far out is the strut and what
kind of angle is it at.
In any case, I would want to put a doubler over the hole...
Geoff
Old October 2nd 06, 12:31 AM posted to rec.aviation.homebuilt
Rich S.[_1_]
news
Am I missing something here? Is this a low wing or a high wing?
Rich "Mid Wing" S.
Old October 2nd 06, 12:45 AM posted to rec.aviation.homebuilt
J.Kahn
news
Rich "Mid Wing" S.
Well, I am assuming it's a high wing strut braced ultralight where the
tubular spar forms the leading edge, with the strut attachment at around
60% of span, or else a Kolb deal where the tubular spar is at the more
typical spar location.
Interestingly the DeHavilland Canada Twin Otter has its lift strut only
at about 1/3 span, so it could be said to be more of a "semi-cantilever"
wing. The loads on the root fittings are strongly downward and inward.
John
Old October 2nd 06, 12:54 AM posted to rec.aviation.homebuilt
"Rich S." wrote in message
news
news
Rich "Mid Wing" S.
Well, there you go, I was assuming a high wing what with it being an
ultralight and all. But I could be wrong. Eh?
Geoff
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 01:31 PM
Tech: Aluminum Forming Question Scott Rodriguez Home Built 5 March 15th 06 04:42 AM
mismatched hole question Dick Restoration 5 October 17th 04 12:43 PM
epoxy aircraft seats? Lpmcatee356 Home Built 26 December 3rd 03 11:16 PM
DuoDiscus Wing Duane Eisenbeiss Soaring 27 October 31st 03 02:34 AM
