Procedure for calculating weight and balance
Old January 8th 07, 04:40 PM posted to rec.aviation.piloting
Mxsmanic
Default Procedure for calculating weight and balance
Thomas Borchert writes:
If you fly a cruise speed of 150
knots in a Baron, you'd still have different elevator positions
depending on CG location. In fact, the position would change during the
flight with fuel burn. Which would be "neutral"?
The one that aligns the trim tabs with the control surfaces.
  #112
Old January 8th 07, 04:42 PM posted to rec.aviation.piloting
Mxsmanic
Kev writes:
In this case, you really need to listen to what Thomas and others are
saying. There is no neutral position. There is just a natural
position for a certain flight regime.
The neutral position for trim tabs is the position in which the trim
tabs are aligned with the control surface. The neutral position for
control surfaces is the position in which they are aligned with the
surfaces to which they are attached (wings or stabilizers).
  #113
Old January 8th 07, 05:13 PM posted to rec.aviation.piloting
Gig 601XL Builder
Mxsmanic wrote:
Kev writes:
Ok Anthony, you have perfectly loaded your aircraft so the that it trims out
to what you like to call nuetra or default. What are you going to do once
you have burned off fuel and the CG changes?
  #114
Old January 8th 07, 05:22 PM posted to rec.aviation.piloting
Newps
Kev wrote:
Newps wrote:
MxIdiot is a complete and utter moron and deserves everything he gets.
Careful. Glass houses and all that.
Fire away.
Plus it's fun.
Dude, do more flying. I can think of a lot more fun things, than
constantly bashing one teenage boy on the net :-)
Wind 280@30G45
  #115
Old January 8th 07, 05:24 PM posted to rec.aviation.piloting
Newps
What's the neutral position of a Cub or Cessna 180?
  #116
Old January 8th 07, 05:33 PM posted to rec.aviation.piloting
Gig 601XL Builder
The problem is he isn't a teenager.
http://www.atkielski.com/
  #117
Old January 8th 07, 11:07 PM posted to rec.aviation.piloting
Mxsmanic
Gig 601XL Builder writes:
Adjust the trim. Ideally, I'd be in an aircraft where the fuel load
is already at that ideal neutral point, and so very little adjustment
would be required.
  #118
Old January 8th 07, 11:08 PM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
I don't know. I've never flown anything that tiny.
  #119
Old January 8th 07, 11:23 PM posted to rec.aviation.piloting
Tony
So sad.
On Jan 8, 6:08 pm, Mxsmanic wrote:
Newps writes:
What's the neutral position of a Cub or Cessna 180?I don't know. I've never flown anything that tiny.
  #120
Old January 8th 07, 11:24 PM posted to rec.aviation.piloting
Newps
would be required.
No such animal.
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
