#141
Mxsmanic wrote:
Newps writes: No such animal. Unless you are familiar with every aircraft ever built, you don't really know. For a plane to have the fuel loaded as you suggest the fuel would have to be contained in an infinitely narrow (forward to aft)tank and be moveable to take into account what the pilot had for breakfast that morning. |
#142
Duncan writes:
Which is indicated how? Please do explain. Look at the control surface. If the trim tab is flush with the control surface, it is in its neutral position. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#143
#144
Duncan writes:
There is no trim tab - it's a spring type system to balance out the force on the column. So the question remains, what is the neutral position? Trim tabs that don't exist don't have neutral positions. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#145
#146
Duncan writes:
Hey don't be a ******. What is the neutral position for a spring type trim control? I said tab, not control. A tab is neutral when it is flush with the control surface to which it is attached. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#147
#148
FAA Advisory Circular AC 120-27E
Aircraft Weight & Balance Control This is used by the builder to construct the W&B for certification, also printed in the aircraft Type Certificate (TC) FAA-H-8083-1 Aircraft Weight & Balance Handbook |
#149
Blanche Cohen writes:
FAA Advisory Circular AC 120-27E Aircraft Weight & Balance Control This is used by the builder to construct the W&B for certification, also printed in the aircraft Type Certificate (TC) FAA-H-8083-1 Aircraft Weight & Balance Handbook Thanks! I've located and downloaded both. They should be very helpful, particularly the latter. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#150
![]() Y'All, Not exactly on topic but something to try in a simulator and again in an air. Trim for level at cruise, Put your hands and arms a far forward as you can and hold them there. The nose of the aircraft will drop and the speed increase slightly in the airplane but not in the simulator. Then put your hands up and back as far as you can reach. The plane's nose will rise and airspeed will drop as you lelnter a climb. You can actually fly the aircraft just be moving your arms and using the rudder. This is NOT possible on the simulator. During WWII (See my web site at www.whittsflying.com ) I was the mechanic operator of a radar bombing simulator on Tinian Island that provided simulated flights over Japan and specifically Fukuoka. We worked on the attack only to find on the Sept 9, 1945 mission day that the target was obscured by smoke. Nagasaki.was a secondary target requiring an attack from a direction opposite to the one practiced. Thus this very first electronic simulator paved the way for the failures of future electronic simulators to really provide a true sense of what is supposed to happen. Another Comparison: I had a Designated Examiner that I had tutored through his CFI come to me in need of a Flight Review. I told him as, we got into the airplane, that we were going to make an IFR flight from Concord to shoot the ILS in Oakland. We discussed the flight and requirements except for one minor aspect which began on takeoff. As he lined up on the runway, I informed him that I had electrified the yoke. Were he to touch the yoke he would go up in smoke. Under the hood he flew a perfect flight without touching the yoke including making the Oakland published missed at which point I asked his permission to have a go at it. It can be done in an airplane. Can anyone do it in a simulator? Has it even been tried? Gene Whitt |
Differences between automotive & airplane engines | Chris Wells | Home Built | 105 | February 18th 06 11:00 PM |
Pocket PC Weight and Balance Spreadsheet | Navzilla Support | Piloting | 0 | October 9th 05 11:47 PM |
Cessna 172 F Weight and Balance | [email protected] | Owning | 8 | September 22nd 05 02:38 AM |
172S Weight and Balance Question | David J | Piloting | 9 | March 23rd 04 01:08 AM |
Weight and balance.. | Bart | Rotorcraft | 9 | August 19th 03 02:57 AM |
