Procedure for calculating weight and balance
Old January 9th 07, 02:45 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default Procedure for calculating weight and balance
Mxsmanic wrote:
Newps writes:
No such animal.
Unless you are familiar with every aircraft ever built, you don't
really know.
For a plane to have the fuel loaded as you suggest the fuel would have to be
contained in an infinitely narrow (forward to aft)tank and be moveable to
take into account what the pilot had for breakfast that morning.
  #142
Old January 9th 07, 06:33 PM posted to rec.aviation.piloting
Mxsmanic
Duncan writes:
Which is indicated how? Please do explain.
Look at the control surface. If the trim tab is flush with the
control surface, it is in its neutral position.
  #144
Old January 10th 07, 05:35 AM posted to rec.aviation.piloting
Mxsmanic
Duncan writes:
There is no trim tab - it's a spring type system to balance out the
force on the column. So the question remains, what is the neutral
position?
Trim tabs that don't exist don't have neutral positions.
  #146
Old January 10th 07, 03:41 PM posted to rec.aviation.piloting
Mxsmanic
Duncan writes:
Hey don't be a ******. What is the neutral position for a spring type
trim control?
I said tab, not control. A tab is neutral when it is flush with the
control surface to which it is attached.
  #148
Old January 13th 07, 04:39 AM posted to rec.aviation.piloting
Blanche Cohen
FAA Advisory Circular AC 120-27E
Aircraft Weight & Balance Control
This is used by the builder to construct the W&B for certification, also
printed in the aircraft Type Certificate (TC)
FAA-H-8083-1 Aircraft Weight & Balance Handbook
  #149
Old January 13th 07, 09:09 AM posted to rec.aviation.piloting
Mxsmanic
Blanche Cohen writes:
Thanks! I've located and downloaded both. They should be very
helpful, particularly the latter.
  #150
Old January 30th 07, 12:20 AM posted to rec.aviation.piloting,rec.aviation.student
Y'All,
Not exactly on topic but something to try in a simulator and again in an
air. Trim for level at cruise,
Put your hands and arms a far forward as you can and hold them there. The
nose of the aircraft will drop and the speed increase slightly in the
airplane but not in the simulator. Then put your hands up and back as far
as you can reach. The plane's nose will rise and airspeed will drop as you
lelnter a climb. You can actually fly the aircraft just be moving your arms
and using the rudder. This is NOT possible on the simulator.
During WWII (See my web site at www.whittsflying.com ) I was the mechanic
operator of a radar bombing
simulator on Tinian Island that provided simulated flights over Japan and
specifically Fukuoka. We worked on the attack only to find on the Sept 9,
1945 mission day that the target was obscured by smoke.
Nagasaki.was a secondary target requiring an attack from a direction
opposite to the one practiced. Thus this very first electronic simulator
paved the way for the failures of future electronic simulators to really
provide a true sense of what is supposed to happen.
Another Comparison:
I had a Designated Examiner that I had tutored through his CFI come to me in
need of a Flight Review.
I told him as, we got into the airplane, that we were going to make an IFR
flight from Concord to shoot the ILS in Oakland. We discussed the flight
and requirements except for one minor aspect which began on takeoff.
As he lined up on the runway, I informed him that I had electrified the
yoke. Were he to touch the yoke he would go up in smoke. Under the hood he
flew a perfect flight without touching the yoke including making
the Oakland published missed at which point I asked his permission to have a
go at it. It can be done in an airplane. Can anyone do it in a simulator?
Has it even been tried?
Gene Whitt
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
