#31
Robert M. Gary wrote:
On Jan 27, 8:28 am, "Tony Cox" wrote: I'd assume symptoms were caused by some prop seal failure. I'd go to fine pitch (to minimize further oil loss) & then reduce RPM to where I could still maintain altitude (to further minimize oil loss, and to minimize structural damage if the prop were about to disintegrate) while heading for the nearest airport. I'd probably avoid touching anything and head towards the airport. Could a prop seal really leak enough oil to make drops appear on the windscreen? Usually prop seal leaks show up as moisture under the prop. -Robert, CFII We used to have an old diaphragm prop. I invited my teaching attendant to go flying with us (in his younger years he flew P-51's and then flew for Phillipine air). About halfway home the diaphragm started to go and I mentioned it to Ron in the backseat as a way to make sure Jim (flying in the right seat) didn't get concerned. It took him about 10 seconds to transition to the instruments (it threw a bunch of oil on the right side, but the left was ok). Margy |
#32
On Sun, 28 Jan 2007 12:31:51 GMT, B A R R Y
wrote: I've heard a statistic tossed around at Wings seminars stating that most engine failures occur during a change or adjustment. Guest engine experts seem to always agree not to touch anything if it's still running and high confidence of the exact problem isn't available. Which would seem to indicate that if you can consistantly fly with just two engine settings (full power and idle) you are less likely to get unwelcome engine related surprises... grin |
#33
On Jan 28, 6:59 pm, "Ash Wyllie" wrote:
Doug opined You do realize that the govenor changes blade angle when you change power settings don't you? Yes, but if the prop is in in fine pitch, it can't get any finer. The above is incorrect on a constant speed prop, if what you mean is the prop knob is all the way in ('fine"). There is really no way of knowing exactly how fine the prop is currently running, but just because you push the prop knob all the way in does NOT mean the prop is all the way to the fine stops!!! It COULD be, but not necesarily. If you push the prop knob in, he govenor makes the pitch as fine as necesarry to get redline rpm, or until it hits the stops, whichever comes first. It is a mistaken belief that just because the prop knob is all the way in, on a constant speed prop, that you are all the way to the stops. Not true. |
#34
Grumman-581 wrote:
On Sun, 28 Jan 2007 12:31:51 GMT, B A R R Y wrote: I've heard a statistic tossed around at Wings seminars stating that most engine failures occur during a change or adjustment. Guest engine experts seem to always agree not to touch anything if it's still running and high confidence of the exact problem isn't available. Which would seem to indicate that if you can consistantly fly with just two engine settings (full power and idle) you are less likely to get unwelcome engine related surprises... grin Like the WW1 guys? G |
#35
I've heard the same thing Barry.. don't know where the stats are found
BT No supporting stats. Lycoming has researched it and it's a myth. You can find the info in their tech briefs on their website. I heard it "around the airport" c1980. If there are stats, they are old. About all I can add is that one of the locals had the engine drop to idle at the first power reduction--probably at the crosswind turn--the clevis connecting the throttle to the carburetor came loose. IIRC, he made a successfull landing on the airport. |
#36
On Sun, 4 Feb 2007 03:07:27 -0500, "Peter Dohm"
wrote: I've heard the same thing Barry.. don't know where the stats are found BT No supporting stats. Lycoming has researched it and it's a myth. You can find the info in their tech briefs on their website. I heard it "around the airport" c1980. If there are stats, they are old. About all I can add is that one of the locals had the engine drop to idle at the first power reduction--probably at the crosswind turn--the clevis You sure it wasn't the "Deadly downwind turn?". connecting the throttle to the carburetor came loose. IIRC, he made a successfull landing on the airport. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#37
On 27 Jan 2007 08:28:13 -0800, "Tony Cox" wrote:
Here's a question that anyone with a single engine, constant speed prop might have to deal with sometime. You're cruising along happily when suddenly oil drops start appearing on the windshield. There is no "bang" or anything else to indicate catastrophic failure. The nearest airport is out of gliding range. What do you do? I'd assume symptoms were caused by some prop seal failure. I'd go to fine pitch (to minimize further oil loss) & then reduce RPM to where I could still maintain altitude (to further minimize oil loss, and to minimize structural damage if the prop were about to disintegrate) while heading for the nearest airport. Can anyone think of a better response? Clean the windshield? I had one that did that. landed, cleaned, wiped prop down, went around the pattern, no more problem. I know it was the seals as you could see the streaks down the blades. Apparently they just didn't seat. That was something like three years ago and no problem since. OTOH I haven't flown in 6 weeks due to the weather so I'll have to pay close attention next time out. Bout time for a couple hours of just practice. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| Thread Tools | |
| Display Modes | |
| OOPS! Got contact cement on the windshield | Mike Rapoport | Owning | 12 | November 14th 04 12:13 AM |
| Windshield Antenna Kits | Scrabo | Piloting | 2 | July 12th 04 05:58 PM |
| windshield wipers | tony roberts | Owning | 8 | June 1st 04 03:45 AM |
| Arrgh! I may have scratched my windshield! | Peter R. | Owning | 7 | April 28th 04 08:58 AM |
| Windshield sealant | Mike Noel | Owning | 10 | October 2nd 03 02:04 AM |
