Max weight of K21
Old February 3rd 07, 09:43 AM posted to rec.aviation.soaring
t-tree
Default Max weight of K21
Hi just trying to find the max cockpit weight for the front seat of
both a K21 abd a K13 if anyone knows.
Thanks
Old February 3rd 07, 10:25 AM posted to rec.aviation.soaring
W.J. \(Bill\) Dean \(U.K.\).
For the K21 the maximum front seat load is 110kg (242lbs). This is the
handbook figure, and is the maximum design weight for the seat.
If the K21 is flown solo the maximum front seat weight by moments (without
putting the glider C. of G. forward of the forward limit) is much higher,
certainly above 300lbs, but that weight is way above the load for which the
seat structure is designed.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"t-tree" wrote in message
Thanks
Consequence of shifting carry-on luggage to checked luggage for aircraft weight Mxsmanic Piloting 121 September 11th 06 11:13 PM
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
