Consequence of shifting carry-on luggage to checked luggage for aircraft weight
Old August 14th 06, 01:05 AM posted to rec.aviation.piloting
Mxsmanic
Default Consequence of shifting carry-on luggage to checked luggage for aircraft weight
Does the average weight calculation for passengers on commercial
flights include an allowance for their carry-on luggage?
The reason I ask is that, if the carry-on weight is shifted to the
hold, calculations that use an assumed average weight for passengers
and their carry-ons in conjunction with actual weighing for luggage in
the hold may produce estimates of take-off weight that are too high.
For example, if the average passenger has 10 lbs of carry-on and this
is incorporated into the estimated weight used for that passenger, and
he is suddenly required to check the carry-on, the assumed weight will
be too high by 10 lbs. This, combined with the 10 lbs extra of
measured weight in the luggage in the hold, would make the take-off
weight calculation 10 lbs high. Multiply that by hundreds of
passengers, and you have a weight that could be thousands of pounds
off.
Has anyone considered this? A too-high estimate could affect flight
characteristics and might also waste fuel (since more would be loaded
than needed).
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 05:08 AM
