60 degree Mopar V6 for homebuilt?
Old February 7th 07, 04:19 AM posted to rec.aviation.homebuilt
RapidRonnie
Default 60 degree Mopar V6 for homebuilt?
Instead of the Javelin Ford, which appears totally dead, or the Chevy
V6 that is 3/4 a small block has nayone thought about flying the
pushrod Chrysler V6? They are becoming available pretty cheap.
Old February 7th 07, 06:42 AM posted to rec.aviation.homebuilt
Morgans
"RapidRonnie" wrote in message
From my experience in cars, they are pretty cheap because they are crap, or
next to it.
Jim in NC
Old February 7th 07, 05:40 PM posted to rec.aviation.homebuilt
Peter Dohm
or next to it.
I have heard that enough times to wonder it there might be some basis;
OTOH, back when they were still current production, my local Chrysler dealer
believed they were sufficiently reliable that a 100,000 standard factory
waranty was imminent.
I don't recall whether they were bimetal or aluminum block engines, but
adiquate and consistent cooling is *very* important with aluminum heads on
an iron block.
Also, some of the newer designs may be lighter, although I don't know the
weight of either.
BTW, Ford had a 3.0L and GM had a similar engine that may have been the
3.4L, which were both just about as compact as the Chrysler 3.0L and 3.3L
engines.
Peter
Old February 7th 07, 06:03 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Peter Dohm wrote: --
dealer believed they were sufficiently reliable that a 100,000
standard factory waranty was imminent.
Peter
Of course that could be because at the time word was bad enough about them
that a long waranty was the only way they were going to sell them.
Old February 7th 07, 06:35 PM posted to rec.aviation.homebuilt
cavedweller
or next to it.
an iron block.
weight of either.
engines.
Peter
The 3.0L Chrysler engine of recent times is not a push rod engine. It
was a Mitsubishi design and had its share of problems, particularly
with valve guides and cam and crank seals. The 3.3L pushrod engine
(and its variants) is of US design and manufacture.
Search rec.autos.makers.chrysler.
Old February 8th 07, 04:32 AM posted to rec.aviation.homebuilt
Peter Dohm
Chevy
crap,
or next to it.
dealer
on
an iron block.
weight of either.
3.3L
engines.
Peter
Now that you mention it, I recall that the 3.0L was a Mitsubishi design, and
that the complaints that I heard were about it. Apparently, the 3.3L was
not a revision of the same engine, as I had supposed.
A quick look in the rec.autos.makers.chrysler group strongly suggests that
the 2.7L might also be a poor choice. It's obvoisly hard to guess how much
is simply poor maintenance, but an Intrepid is obviously a much lighter load
for an engine than an airplane...
Peter
Old February 8th 07, 01:20 PM posted to rec.aviation.homebuilt
cavedweller
Chevy
crap,
or next to it.
dealer
on
an iron block.
weight of either.
3.3L
engines.
Peter
Peter
The 2.7 isn't part of the 3.3 family either and IT had its own
problems, many of which could be ameliorated by rigid maintenance.
I don't understand your specific reference to the "load" in an
Intrepid being the measure of suitability for the engine's application
in an airplane. The jump to aircraft use for any auto engine is a big
one no matter what vehicle it comes out of.
Old February 8th 07, 02:51 PM posted to rec.aviation.homebuilt
Peter Dohm
and
was
that
much
load
Peter
You're right that it is not part of the same engine family, and it
presumably differs considerably from the other overhead cam engines as well.
The reference may not really belong in the same posting.
I am not quite sure why, but rumors suggest that the _modern_ overhead cam
and multi-valve engines are far less tolerant of sloppy or deferred
maintenance than most older designs.
The load issue with the intrepid is slight, but that is a heavier car than
the Sebring and Stratus in which is was most commonly used. Aircraft use is
a lot more like pulling a trailer uphill at highway speed.
Old February 8th 07, 03:00 PM posted to rec.aviation.homebuilt
cavedweller
and
was
that
much
load
Peter
Roger that.
..... in first gear if a PSRU is used.
Old February 8th 07, 03:53 PM posted to rec.aviation.homebuilt
Montblack
("cavedweller" wrote)
Aircraft use is a lot more like pulling a trailer uphill at highway
speed.
(Wikipedia)
"Airstream trailers are well recognized for their distinctive rounded
aluminum bodies, which originated in the 1930s from designs largely created
by Hawley Bowlus . Bowlus was the designer of Charles Lindbergh's aircraft,
the Spirit of St. Louis."
"Rec.Homebuilt" g
http://www.airstream.net/images/torpedo.jpg
"Dr. H.W. Holman and wife Thelma with the oldest existing Airstream. This
'torpedo trailer' was built from plans supplied by the Airstream company in
1935."
http://www.airstream.net/as_photos/photos.html
Photos of vintage Airstreams
Montblack
37 Degree Single vs Double Flared Tubing Craig Foster Home Built 1 July 21st 04 03:24 PM
90 Degree turn while slipping ISoar Soaring 40 February 14th 04 10:49 AM
37 degree flare, 1/8" stainless Richard Riley Home Built 8 August 29th 03 04:21 AM
