Low fuel emergency in DFW
Old February 25th 07, 11:02 AM posted to rec.aviation.piloting
Mike Young
Default Low fuel emergency in DFW
"Bob Noel" wrote in message
"Mike Young" wrote:
A response of "unable" is not a refusal?
I am "unable" to hop like a frog.
I "refuse" to hop like a frog.
There's a distinct difference.
In the context of Pilot-Controller communication, any distinction is
insignificant.
It's not just significant. It's all the difference in the world, and the
reason for the heat in this thread. On the scale of bigness, the only
uncertainty I have is which is larger, the semantics of can't versus won't;
or answering "Affirmative!" to the question "Are you declaring an emergency
at this time?" There's no room for mush-mouth weasel words in that incident.
I don't believe the news broadcast told all that was worth telling.
  #222
Old February 25th 07, 11:46 AM posted to rec.aviation.piloting
Bob Noel
insignificant.
It's not just significant. It's all the difference in the world...
"refuse" and "unable" means the same thing from the ATC POV.
Bob Noel
Looking for a sig the
lawyers will hate
  #223
Old February 25th 07, 12:59 PM posted to rec.aviation.piloting
Jim Macklin
No, it does not, it gives the PIC the legal authority to
deviate from any law, rule or clearance GIVEN by ATC pr the
FAA. It does not allow the PIC to justify causing an
accident.
ATCs job in an emergency is to think straight and get the
PIC priority service and on the ground ASAP within the
bounds of possibilities. Think about the movie Airport,
that had a snow covered runway, a stuck plane on a runway
and noise complaints. Dean Martin as PIC was demanding
clearance to the runway that was blocked. ATC doesn't have
authority to physically clear a runway, that was about the
only accurate part of that movie.
Priority does not mean ATC will build a runway in 30 seconds
so you can land.
"Jose" wrote in message
t...
| Which law, rule or regulation allows near mid-air
collisions
| because one aircraft has a cob up their ass?
| The one that gives an emergency aircraft priority over all
other aircraft.
| Jose
| Humans are pack animals. Above all things, they have a
deep need to
| follow something, be it a leader, a creed, or a mob.
Whosoever fully
| understands this holds the world in his hands.
| for Email, make the obvious change in the address.
  #224
Old February 25th 07, 01:12 PM posted to rec.aviation.piloting
Jim Macklin
Because I think they are wrong and they have not said just
how they would have "cleared the airspace" in less time than
was available to allow the straight in approach and landing?
The controllers knew the position of each airplane and they
also knew the time for a straight in approach. They knew
that it would be quicker the way it was done, not the way
the PIC wanted in a "panics" state of mind.
The plane did not flame-out, there were no mid-airs, and
nobody died or was injured.
I would bet my lottery winnings from last night [did not
win] that the re-training ATC got was to include statements
of their rationalizations about traffic and flight times "on
the tape."
"Thomas Borchert" wrote in
message ...
| Jim,
| I don't think you understand the complexity of the
airspace
| around DFW,
| Ok, I'll be blunt: I don't think you understand you have
been answered
| here by controllers who know EXACTLY what that kind of
emergency would
| mean to operations at DFW. And they have told you
repeatedly that it is
| a non-issue. Why do you continue to insist otherwise?
| Thomas Borchert (EDDH)
  #225
Old February 25th 07, 01:28 PM posted to rec.aviation.piloting
Judah
601XL Builder wrDOTgiacona@suddenlinkDOTnet wrote in news:45E0A989.1090806
@suddenlinkDOTnet:
MB made the point that had the aircraft been on fire that the pilot
probably wouldn't have bypassed the other two airports.
If the aircraft was on fire, the pilot would probably do an emergency
accelerated descent. However, if he were at low fuel, an accelerated descent
would probably not be desirable.
If he was truly at 15,000', and at a 4-5 mi/min airspeed, 81 miles would be
about right...
  #226
Old February 25th 07, 01:49 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Low fuel emergency in DFW PING: Steven McNicoll
"C J Campbell" wrote in message
e.com...
Maybe Steve can elucidate what it means when ATC asks you if you would
like to declare an emergency and what happens when you do. I think at
least
part of it is calling out the emergency equipment on the ground.
I can't personally recall a controller asking a pilot if he'd like to
declare an emergency. I don't believe FAAO 7110.65 ever directs a
controller to ask a pilot if he'd like to declare an emergency. It does say
an emergency can be declared by the controller as well as a pilot. Pilots
are often hesitant to declare an emergency, but I've never known a
controller to be. In situations that have the properties of an emergency
ATC tends to treat it as an emergency without advising the pilot.
  #227
Old February 25th 07, 02:20 PM posted to rec.aviation.piloting
Jim Macklin
If he was at 81 miles [first I've seen that number], then
ATC did have time to clear the airspace. Just where was the
airplane when the pilot declared the emergency and where was
he when he asked for straight in to 17?
"Judah" wrote in message
| @suddenlinkDOTnet:
that the pilot
an emergency
accelerated descent
81 miles would be
| about right...
  #228
Old February 25th 07, 02:41 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Mike Young" wrote in message
nk.net...
Bad analogy. Is there a distinct difference between saying you're
"unable" to hop like a frog, and saying you "refuse" to hop like a frog,
when you ARE able to hop like a frog?
Yes, I do believe this is at the crux of this thread (rope). The
presumption is that the controller stating UNABLE in any way resembles a
pilot's use of UNABLE.
Here's the definition from the Pilot/Controller Glossary:
UNABLE- Indicates inability to comply with a specific instruction, request,
or clearance.
Do you see a resemblance now?
We're down to just the semantics of the controller's statement that he was
*UNABLE* to land the distressed aircraft on the requested runway.
Well, we know that he was able to, the FAA said so.
  #229
Old February 25th 07, 02:52 PM posted to rec.aviation.piloting
Judah
I don't know - I was quoting someone else who said he was 81 miles out...
Which is why I said "If"...
"Jim Macklin" wrote in
  #230
Old February 25th 07, 02:56 PM posted to rec.aviation.piloting
Jim Macklin
There really is too much speculation, TV reports are not
reliable and knee-jerk reactions don't clarify the issue.
81 miles out...
| "Jim Macklin" wrote
in
then
was
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
