Low fuel emergency in DFW
Old February 22nd 07, 01:24 AM posted to rec.aviation.piloting
Tony
Default Low fuel emergency in DFW
Did anyone see the news about an AA (maybe 777) airplane declaring a
fuel emergency in DFW, requesting a downwind landing to I think 17
Center, and being told no, had to circle to land on 31 R?
I'm not exactly sure of those details, but it's close enough. It's
that old deal, when a pilot makes a mistake, the pilot dies, and when
a controller makes a mistake, the pilot dies. Turns out the airplane
had enough fuel to circle and land, butr damn it, heads should roll,
or at least jobs lost.
I hope the next time such an event happens the PIC TELLS the
Controller p@ic@ he is landing on 17 Center, rather than request it.
As it happens DFW was using 35 C runway for departures, and I gather
it would have been 'inconvenient' to make a suitable hole.
We should OWN the sky when we declare an emergency, and sort out the
details once the event is over, dammit!
Old February 22nd 07, 01:58 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Tony" wrote in message
ps.com...
I saw the report on ABC news. I agree completely, heads should roll. The
reporter said, I believe, that there was disagreement on who denied the
requested runway, the controller or the supervisor. Regardless, I think
both heads should roll.
Old February 22nd 07, 04:00 AM posted to rec.aviation.piloting
Tuno
And if I were the airline, I would start with the PIC, for endangering
the passengers by not being P*I*C.
I made the mistake once of letting the controller tell me I couldn't
land, and I almost busted the &^%$ out of my glider because of it. Not
making that mistake again ...
-ted
Ventus 2C "2NO"
Old February 22nd 07, 05:45 AM posted to rec.aviation.piloting
BT
I once had a tower controller tell me after I had turned base (close in
base) that I was now sequenced #2 behind a Cessna... I did not see the
Cessna and did not know where it was. I told him UNABLE... other people on
the frequency reported hearing other things that I will deny saying. I was
giving a ride in a Blanik L-13 and I was in the back seat. The controller
promptly sent the Cessna on a go around.
He and his supervisor came over and apologized to us about an hour later.
They were not used to controlling traffic at our field. It was a temporary
tower for a fly in and air show. We had briefed the tower controllers
earlier that when a glider calls the down wind, he owns the runway.
We have parallel runways for glider and power operations, and the tower was
using both runways for power.. as they should because of the increased
traffic.
BT
"Tuno" wrote in message
-ted
Ventus 2C "2NO"
Old February 22nd 07, 04:31 PM posted to rec.aviation.piloting
Morgans[_2_]
"Unable" is a word that should be used, and with emphasis, then do what you
need to do, and sort it out later.
The only reason I could see for a glider not given priority, is another
glider closer than you, or a balloon., right?
Old February 22nd 07, 05:37 AM posted to rec.aviation.piloting
Mike Schumann
The controller made an interesting suggestion that if the aircraft was
really that low on fuel he should divert to a closer airport. I would
suggest that it would be wise to get the full info before jumping to
conclussions.
Obviously one major question is where the aircraft was when the pilot
declared a fuel emergency. Once you declare an emergency, particularly if
you suspect a fuel leak, I would think you should land at the closest
available field. It is certainly conceivable that the pilot didn't want the
hassle of making an unscheduled landing, and was trying to streach it to get
to DFW.
Mike Schumann
nk.net...
ps.com...
Posted via a free Usenet account from http://www.teranews.com
Old February 22nd 07, 10:32 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Mike Schumann" wrote in message
conclussions.
the hassle of making an unscheduled landing, and was trying to streach it
to get to DFW.
I didn't jump to any conclusions. The pilot said he had an emergency, and
that he needed 17C at DFW. He was denied.
Old February 22nd 07, 10:57 AM posted to rec.aviation.piloting
Mxsmanic
Steven P. McNicoll writes:
Once you've declared an emergency, denial is moot. ATC's only responsibility
is to keep other people out of your way.
Old February 22nd 07, 12:37 PM posted to rec.aviation.piloting
Jim Macklin
How many "outraged" posters have ever flown into DFW as a
pilot? For ATC to turn the airport around takes about half
an hour, even if all they do is tell all the other airplanes
to go away. ATC did fit the "emergency" into the traffic,
which seems to be the better solution.
message
nk.net...
in message
the aircraft was
airport. I would
before jumping to
| conclussions.
when the pilot
at the closest
pilot didn't want
| to get to DFW.
an emergency, and
Old February 22nd 07, 02:56 PM posted to rec.aviation.piloting
Dylan Smith
to go away.
I'm sure if this had resulted in (a non-fiery, given the lack of fuel)
crash, this would really have comforted the crew and passengers on that
plane.
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
