Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Rolling a Non Aerobat 150
Old March 1st 07, 11:27 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
NoSpam
Default Rolling a Non Aerobat 150
john smith wrote:
.... snipped
the rate of descent is still going to be about 800 fpm with an indicated
airspeed of 45-50 mph. That's quite and airload on the inside turn side
.... snipped
800 fpm is surprisingly low - are you sure? The aircraft I normally fly
does about 300 feet per turn and about 1-2 seconds per turn - so being
conservative that's about 10,000 fpm.
Dave
Old March 1st 07, 10:07 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
john smith
NoSpam wrote:
john smith wrote:
... snipped
... snipped
Dave
Oops, you're right, it is higher. Don't know what I was thinking when I
wrote that.
Old March 2nd 07, 06:38 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Tue, 27 Feb 2007 21:35:00 -0500, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote:
"RST Engineering" wrote in message
Note that what is said here is not true. The regs say that you can teach
any maneuver that is "required for a rating" without parachutes. This
includes spins. You can teach a student spins without a parachute(s) if
you wish.
And, one could consider the fact that wearing a parachute or not won't make
one bit of difference (at least as far as survival is concerned) in 90+% of
the aircraft used for training if one were to find a spin to be
unrecoverable and/or if one were to pull the wings off.
A spin is a fully stalled condition. The doors of a 150 or 172 should
be *relatively* easy to open as opposed to being in a high speed
spiral.
For the parachute to do any good, you would have to be able to open the door
far enough to actually get out of the airplane. You could do it in a
Citabria or 150 Acro with the door release - or something like a Cub. But
anything else? Naah...
But, of course, if one were to die inside the aircraft, having a 'chute on
should be enough to assure that one would go to heaven since he and/or she
would have died while complying with FAA regulations. The rest of us will
end up in a significantly less comforable environment, eh?
Personally I think spins are fun.
www.rogerhalstead.com
Old March 5th 07, 01:59 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
DR
spiral.
As I understand it, there is a difference in the _extent_ of the stall
between the two wings. If that were not the case and both wings were
fully stalled (which would require AOA to be ~90 degrees I think) the
yaw would decay due to fusilage and tail drag?
Cheers Mark
------------ And now a word from our sponsor ---------------------
For a secure high performance FTP using SSL/TLS encryption
upgrade to SurgeFTP
---- See http://netwinsite.com/sponsor/sponsor_surgeftp.htm ----
Old March 5th 07, 12:49 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Dylan Smith
spiral.
I think 'fully stalled' in the context of a spin means that both wings
exceed the critical angle of attack. That's not to say one wing can't
have a different AoA than the other (IIRC, the critical angle of attack
is something on the order of 16 degrees)
Yes, the Reply-To email address is valid.
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Old March 5th 07, 01:01 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Stefan
The outer wing isn't necessairily stalled.
Even without a thorough knowledge, I dare to believe that this depends
on the profile...
Old March 6th 07, 01:42 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
stearmandriver
spiral.
Cheers Mark
thought I'd jump in on this one. I've been a Stearman driver for about 30 years and might have about as much time in "unusual attitudes" as right side up. In a fully developed spin, the door on the outside of the spin will be pretty difficult to open, and in fact it's tough to even move yourself out on that side. the old military training in open cockpits was to bail to the inside of the spin if unrecoverable. so, the quick release pins are in the aerobat to ensure you can get the door off- Centrifigal force and wind presssure will keep it closed otherwise.
Old March 6th 07, 08:39 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
pittss1c
I know of one to get out of a decathlon. It was from the back seat no less.
(It helps when the wing has departed and there is a big hole above your
head though)
Mike
john smith wrote:
In article . net,
"Todd W. Deckard" wrote:
Why would you say this? The door would be fairly easy to open in a spin.
In a high speed loss of control it might be very difficult to overcome
aerodynamic resistance but it is possible to open a forward hinged door
and force it open enough to squeeze out at even 100kts in straight flight.
With a modern canopy you stand a chance of a survivable deployment at
even a few hundred feet.
I wouldn't be too positive about those statements.
I have over 300 freefalls and 25 hours of acro in a Citabria.
The Citabria only has one door... on the right side. In a right spin,
of the airframe. Add to that centrifugal forces and getting through the
doorway after jettisoning the door will be a challenging proposition.
You have two sets of seatbelts to release, a headset to remove and a
body with a parachute attached to fit through the doorway. When you exit
you will be on the inside side of the airplane, which you have to clear
before you pull the D-ring.
Tic-toc, the clock is winding down as fast as the altimeter.
I have knowledge of only one acro pilot who successfully exited a
Decathlon.
Old March 23rd 07, 01:36 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Cox
If you do manage to get out of a spinning aircraft, I wouls estimate close
to a 100% better chance of survival if you have a chute on. I sure would
hate to be the person who was able to get out of the so called "impossible
aircraft to get out of" only to find they didn't have a chute on.
Wear a chute, what can it hurt?
Adam
Adam Cope
www.dcaerobatics.com
703-623-9445
Old March 23rd 07, 01:57 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Don Tuite
Adam
Then there's this:
http://www.aero-news.net/index.cfm?C...-7233c1bb43f8&
(Hope it's not a repost. It's about the 150 rudder bumpers jamming.)
Don
Rolling a Non Aerobat 150 Tom Inglima Piloting 39 December 21st 08 02:04 PM
Rolling a Non Aerobat 150 Tom Inglima Owning 4 March 1st 07 01:44 AM
Rolling a Non Aerobat 150 Tom Inglima Instrument Flight Rules 4 March 1st 07 01:44 AM
Rolling a Non Aerobat 150 Larry Dighera Piloting 98 June 18th 05 12:28 AM
Rolling a Non Aerobat 150 Larry Dighera Piloting 1 April 29th 05 07:31 PM
