Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Rolling a Non Aerobat 150
Old February 27th 07, 04:41 AM posted to rec.aviation.aerobatics,rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Tom Inglima
Default Rolling a Non Aerobat 150
Spins have NEVER been in the private pilot PTS. The PTS (Practical Test
Standard) only has been in existence for around 20 years or so. The last
time spins were required for a Private Certificate was back in the early
1950's or maybe the late 1940's. Note that there is nothing that prevents
an instructor from teaching spins to a student pilot. However you would
have to wear parachutes to be legal since the regs only allow spins without
the wearing of parachutes for people training for a flight instructor
certificate.
The predecessor for the PTS was the Flight Test Guides. These were slim
volumes of not more than 20 pages and about 2 or 3 inches wide and about 4
inches high. In any case they were smaller than a 3 by 5 index card. they
had very broad descriptions of maneuvers' and gave examiners and inspectors
wide latitude in what and how they wanted you to perform various maneuvers.
Part 61 was actually a much better regulation then in that it clearly made
the CFI responsible for preparing a competent pilot that was able to show
good judgment.
The predecessor regs and guidance was to list the actual maneuvers in the
reg. If you could get a monkey to somehow do the maneuver a certificate
would be issued.
Tom Inglima
"Chris G." nospam@noemail wrote in message
eenews.net...
Besides, spin training is NOT required for a private pilot certificate.
Spin AWARENESS (aka recognizing you're going to get into a spin) is
required. Spins are not part of the PTS anymore though.
I don't necessarily think that omitting spins from the PTS is the best
move the FAA has made, but I don't know the whole story. I know I'm
having my instructor make sure he teaches me spins in the 150 I'm learning
in. I believe that training in spins and spin recovery is a very
important skills that could save my life one day.
Chris
On Wed, 27 Apr 2005 14:46:42 -0500, "Gig 601XL Builder"
wr.giacona@coxDOTnet wrote:
On 27 Apr 2005 09:43:30 -0700, "Noah Fiedel"
In addition, were you & your instructor wearing parachutes
as required for aerobatic flight?
Not required, since spin training is required for a rating.
Looked to me like a roll not a spin.
Oooops.
Never mind.
Old February 27th 07, 06:38 AM posted to rec.aviation.aerobatics,rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
RST Engineering
Note that what is said here is not true. The regs say that you can teach
any maneuver that is "required for a rating" without parachutes. This
includes spins. You can teach a student spins without a parachute(s) if
you wish.
without the wearing of parachutes for people training for a flight
instructor certificate.
Old February 27th 07, 11:49 AM posted to rec.aviation.aerobatics,rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Ron Natalie
you wish.
Actually the regulation specifically mentions spins. It doesn't
matter they were required for a rating or not. The "required
for a rating" part applies to the "and other maonouvers".
The FAA has affirmed that once a manouver is required in
training (not necessarily for the checkride) for any rating
it's fare game for ANY instructional use at any time.
Except of course, while using MSFS.
Old February 27th 07, 01:43 PM posted to rec.aviation.aerobatics,rec.aviation.ifr,rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Jose
Default PED Rolling a Non Aerobat 150
Well, not quite. See below:
(2) Spins and other flight maneuvers required by the
regulations for any certificate or rating when given by-
That is, "Spins and other...", which means something different from
"Spins, and other..."
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old February 28th 07, 02:35 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Capt. Geoffrey Thorpe
"RST Engineering" wrote in message
you wish.
And, one could consider the fact that wearing a parachute or not won't make
one bit of difference (at least as far as survival is concerned) in 90+% of
the aircraft used for training if one were to find a spin to be
unrecoverable and/or if one were to pull the wings off.
For the parachute to do any good, you would have to be able to open the door
far enough to actually get out of the airplane. You could do it in a
Citabria or 150 Acro with the door release - or something like a Cub. But
anything else? Naah...
But, of course, if one were to die inside the aircraft, having a 'chute on
should be enough to assure that one would go to heaven since he and/or she
would have died while complying with FAA regulations. The rest of us will
end up in a significantly less comforable environment, eh?
Personally I think spins are fun.
Geoff
Old March 1st 07, 01:52 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Todd W. Deckard
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message
make one bit of difference (at least as far as survival is concerned) in
90+% of the aircraft used for training if one were to find a spin to be
Why would you say this? The door would be fairly easy to open in a spin.
In a high
speed loss of control it might be very difficult to overcome aerodynamic
resistance but
it is possible to open a forward hinged door and force it open enough to
squeeze out
at even 100kts in straight flight. With a modern canopy you stand a chance
of a survivable
deployment at even a few hundred feet.
The only reason I responded to the post is to encourage anyone wearing a
parachute
to drill the procedure like any other flying skill (and I know this was a
casual usenet
post, but avoid those negative thoughts).
1. Jettison the canopy/pull the door release pins (if so equipped)
2. Grasp the door frame/strut with one hand
3. Then, release the seat belt(s) with the other hand
4. pull clear and jump
5. assume the hard arch position, look, grasp the ripcord with both hands
and pull
to full arm extension until the cables clear the housing.
6. Discard the ripcord handle and look over your right shoulder.
There was a series of articles in Soaring/Sport Aerobatics a few years ago:
http://www.silverparachutes.com/uplo...PROCEDURES.htm
I would encourage anyone to make a recreational jump, even a tandem, to
familiarize
themselves with the experience. You may find it opens the door to a whole
new
expression of aviation; after all riding in a boat ain't swimming and by the
same token
sitting in an airplane isn't really flying ...
Stay Lucky,
Todd
Old March 1st 07, 02:46 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Alan Gerber
familiarize
new
same token
Neither is dropping straight down to the earth.
.... Alan
Alan Gerber
PP-ASEL
gerber AT panix DOT com
Old March 1st 07, 03:41 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
john smith
In article . net,
In a high speed loss of control it might be very difficult to overcome
aerodynamic resistance but it is possible to open a forward hinged door
and force it open enough to squeeze out at even 100kts in straight flight.
With a modern canopy you stand a chance of a survivable deployment at
I wouldn't be too positive about those statements.
I have over 300 freefalls and 25 hours of acro in a Citabria.
The Citabria only has one door... on the right side. In a right spin,
the rate of descent is still going to be about 800 fpm with an indicated
airspeed of 45-50 mph. That's quite and airload on the inside turn side
of the airframe. Add to that centrifugal forces and getting through the
doorway after jettisoning the door will be a challenging proposition.
You have two sets of seatbelts to release, a headset to remove and a
body with a parachute attached to fit through the doorway. When you exit
you will be on the inside side of the airplane, which you have to clear
before you pull the D-ring.
Tic-toc, the clock is winding down as fast as the altimeter.
I have knowledge of only one acro pilot who successfully exited a
Decathlon.
Old March 1st 07, 11:27 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
NoSpam
john smith wrote:
.... snipped
.... snipped
800 fpm is surprisingly low - are you sure? The aircraft I normally fly
does about 300 feet per turn and about 1-2 seconds per turn - so being
conservative that's about 10,000 fpm.
Dave
Old March 6th 07, 08:39 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
pittss1c
I know of one to get out of a decathlon. It was from the back seat no less.
(It helps when the wing has departed and there is a big hole above your
head though)
john smith wrote:
In article . net,
Decathlon.
Rolling a Non Aerobat 150 Tom Inglima Piloting 39 December 21st 08 02:04 PM
Rolling a Non Aerobat 150 Tom Inglima Owning 4 March 1st 07 01:44 AM
Rolling a Non Aerobat 150 Tom Inglima Instrument Flight Rules 4 March 1st 07 01:44 AM
Rolling a Non Aerobat 150 Larry Dighera Piloting 98 June 18th 05 12:28 AM
Rolling a Non Aerobat 150 Larry Dighera Piloting 1 April 29th 05 07:31 PM
