"Jon Woellhaf" wrote in message
... And I've been trying to learn for years why R is on the left and L is on the right. My recollection from the last time this was discussed is that the labeles used to be the other way around so that "L" on the left meant that the left mag was grounded and, therefore, the right mag was firing. Then, to keep it more consistent with the "Off" and "Both" labeling, they switched the labeling but left the right key position which grounded the right mag so that the left mag was firing now labeled "L"? Doesn't bother me a bit. If one mag fails an RPM drop, I'm gonna check the wiring to both any. What is more important to me is that the left key position has the bottom plugs firing. That's important so that I can pull the correct plugs the first time to clear an unusually stubborn fouling. Say, why don't they label them "Off", "B", "T", and "Both"? ------------------------------- Travis Lake N3094P PWK |
Right magneto is "hot" (ungrounded). The "OFF" position grounds
both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. No, but he should know that that the Right mag is hot (firing plugs) and the Left mag is cold (not firing) when the switch is in the "R" position, and that the Right mag is cold (not firing) and the Left mag is hot (firing plugs) when the switch is in the "L" position. That much systems knowledge would seem usefull for a safe and reasonable Go/NoGo decision prior to take-off, and also to explain a problem to an efficient manner. Knowledge of the specifics of how the ignition system works could be very usefull in the case of "stealing your oun airplane" because you lost the key at a remote hunting/fishing spot; but I can not imagine that being part of an accredited licensing test. Peter |
the right. I wonder. Maybe because the ancient systems used two toggle switches labelled "L" and "R" and they were connected to their respective mags. When you turned off the L switch, you were running on the R mag. It was self-evident. Our two Citabrias still have this setup and I bet American Champion is still building them that way. When Bendix came up with the combination starter/mag switch, the internal mag-shorting contacts were set up in the same order but now they had to label them opposite so that you knew which one you were sparking on. I'd rather have the toggles in my Jodel but it makes the airplane so much easier to steal. If you can get in you can go. Very true. But I've known pilots who thought that might be very usefull if they lost their key at a remote fishing hole... Peter (It is an amusing thought) |
On Sat, 3 Mar 2007 19:11:50 -0600, "Travis Marlatte"
wrote: "Peter Dohm" wrote in message .. . Right magneto is "hot" (ungrounded). The "OFF" position grounds both mags. I know from personal experience that a lot of pilots continue to have serious misconceptions about such things, but it still bothers me. This is the sort of thing that is part of every run-up, and therefore should have been part of the aircraft systems knowledge requirement to get the license--not necessarily the grounding issue, but which magneto actually fires its set of plugs. I don't get the connection. Why would the licenced pilot need to know which mag and which set of plugs is firing on Left or Right key position? Know why the mag check is important and what to watch for during the mag check, yes. On the right (or left) looking toward the propeller, or t'other way round? (And tractor or pusher? And are the mag designations different on the two engines in a Cessna 337?) Maybe it's time to label mag switches Port and Starboard, mateys! Don |
![]() wrote I'd rather have the toggles in my Jodel but it makes the airplane so much easier to steal. If you can get in you can go. You could rig up a cover to put over the toggles, with a place to put a padlock on the cover, as long as it is not a certified plane. Would altering a plane in that manner be against the rules for certified planes? It would be in the certified plane's regular certified condition, while it was being flown, after all! -- Jim in NC |
![]() "Travis Marlatte" wrote Say, why don't they label them "Off", "B", "T", and "Both"? Excellent suggestion! Why not? It might make too much sense, that way! One could put an "auxiliary label" on panel next to the "L" and "R" with a Dyno Label, or with another favorite method, though. -- Jim in NC |
"Travis Marlatte" wrote in
t: What is more important to me is that the left key position has the bottom plugs firing. That's important so that I can pull the correct plugs the first time to clear an unusually stubborn fouling. I thought that one mag controlled the top plugs on one side and the bottom on the other side. |
![]() "Peter Dohm" wrote in message ... : : No, but he should know that that the Right mag is hot (firing plugs) and the : Left mag is cold (not firing) when the switch is in the "R" position, and : that the Right mag is cold (not firing) and the Left mag is hot (firing : plugs) when the switch is in the "L" position. That much systems knowledge : would seem usefull for a safe and reasonable Go/NoGo decision prior to : take-off, and also to explain a problem to an efficient manner. : : Knowledge of the specifics of how the ignition system works could be very : usefull in the case of "stealing your oun airplane" because you lost the key : at a remote hunting/fishing spot; but I can not imagine that being part of : an accredited licensing test. : : Peter : : But they sure as heck should know that turning off the master switch will not turn off their engine. |
There are some old engines that did use battery power for
the ignition and in those, the battery master must be on. But, in general aircraft built in the post WWII period have two independent magnetos and the battery is used for lights, starting and radios, etc. Some aircraft had one magneto and one coil/distributor [like a car], so the AFM/POH should be read. Also ignition operation should be checked on the ground as part of the pre or post-flight checklists. "Blueskies" wrote in message t... | | "Peter Dohm" wrote in message ... | : | : No, but he should know that that the Right mag is hot (firing plugs) and the | : Left mag is cold (not firing) when the switch is in the "R" position, and | : that the Right mag is cold (not firing) and the Left mag is hot (firing | : plugs) when the switch is in the "L" position. That much systems knowledge | : would seem usefull for a safe and reasonable Go/NoGo decision prior to | : take-off, and also to explain a problem to an efficient manner. | : | : Knowledge of the specifics of how the ignition system works could be very | : usefull in the case of "stealing your oun airplane" because you lost the key | : at a remote hunting/fishing spot; but I can not imagine that being part of | : an accredited licensing test. | : | : Peter | : | : | | But they sure as heck should know that turning off the master switch will not turn off their engine. | | |
![]() "Jim Macklin" wrote in message ... : There are some old engines that did use battery power for : the ignition and in those, the battery master must be on. : But, in general aircraft built in the post WWII period have : two independent magnetos and the battery is used for lights, : starting and radios, etc. Some aircraft had one magneto and : one coil/distributor [like a car], so the AFM/POH should be : read. Also ignition operation should be checked on the : ground as part of the pre or post-flight checklists. : : : How old are you talking, Jim? Any specifics? Engine, airframe? |
Nav radio settings in FMC | Mxsmanic | Piloting | 5 | January 10th 07 08:39 PM |
74 Archer ignition switch question | Mike Noel | Owning | 9 | September 10th 06 10:46 PM |
Ignition switch, what happen when Left or Right is selected | Martin B | Piloting | 41 | May 21st 05 04:55 AM |
ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 08:07 PM |
Just Ordered: An Ignition Switch and Oil Filter from ACS | Larry Smith | Home Built | 30 | October 22nd 03 07:41 AM |
