What do you do in the real world?
Old March 10th 07, 07:00 PM posted to rec.aviation.ifr
A Guy Called Tyketto
Default What do you do in the real world?
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mxsmanic wrote:
ArtP writes:
You might have to explain why you accepted the route if you knew you
could not fly it.
Many routes will eventually intersect terrain if there are mountains nearby.
Nevertheless, you might well accept the route if you expect to be given a new
heading or altitude before you get near terrain. If your radio fails,
however, the situation changes.
Radio failure has nothing to do with what the OP asked. He
asked about the routing should he have been IMC. ArtP's inference still
stands. If you are IMC and accepted a route that you may not have been
able to fly, you will have some explaining to do about why you accepted
a route that could put you into that mountainside.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFF8wBbyBkZmuMZ8L8RAqG9AJ4s7drKopSl/OCrtklhDShTHFPchgCgjLJF
hvMYao1VsmmZOcehYYgeE8g=
=B3vt
-----END PGP SIGNATURE-----
Old March 10th 07, 07:31 PM posted to rec.aviation.ifr
Ron Garret
Ron Rosenfeld wrote:
On Sat, 10 Mar 2007 00:03:57 -0800, Ron Garret
Last night I flew from SJC to VNY. To my astonishment I was cleared
vectors to SNS, then direct VNY (despite having filed a more standard
routing) at 9000 feet. I knew perfectly well that the routing was going
to change because I've done that route a zillion times, and indeed, near
Bakersfield they switched me over to the standard LHS, LYNXX8 arrival,
followed by vectors to the ILS RWY 16R.
My question is: what should I have done if I'd been in IMC and lost comm
before they changed my routing? By the book I should have continued to
fly my clearance, which would have run me into a mountain around GMN, so
that's probably not the right answer. Viable possibilities seem to
include:
1. Divert (or climb) just enough to avoid the terrain around GMN, fly
to VNY, and commence an approach from there.
2. As above, but vector myself for the ILS before reaching VNY.
3&4 - as above but fly to LHS and the LYNXX8 arrival.
5. Divert to the nearest airport with an IAP.
My aircraft is /G so I know pretty much exactly where I am at all times.
rg
"By the book", the route you fly should be the last clearance.
Yes, I know that. That is why the subject of this post is "What do you
do in the real world?"
I don't understand, however, why you would run into a mountain if you are
following the altitude rules of the "lost-comm" regulations. Is your
aircraft not able to climb to the minimum IFR altitude for your route?
The assigned route was not on an airway, and so there is no minimum IFR
altitude on the route. The first 250 miles or so are over pretty flat
terrain. It is only shortly before you get to the destination that the
mountains begin.
rg
Old March 10th 07, 07:38 PM posted to rec.aviation.ifr
Ron Garret
ArtP wrote:
On Sat, 10 Mar 2007 06:51:48 -0500, Ron Rosenfeld
Is your
aircraft not able to climb to the minimum IFR altitude for your route? If
that is the case, you have an emergency situation and can do whatever you
need to do.
could not fly it.
Of course I could fly it, just not at the initially assigned altitude.
That is why my option #1 was to climb.
rg
Old March 10th 07, 07:43 PM posted to rec.aviation.ifr
Ron Garret
Correction (because I know the FAR mavens are going to be all over me
for that one): I should have said, "The minimum IFR altitude is not
easily determined." By the book it's either 1000 or 2000 feet about the
highest obstacle within 4 nautical miles depending on whether or not the
area is designated mountainous. Taking that rule and actually figuring
out where you are supposed to begin to climb and how high (and, more to
the point, where you are supposed to begin to descend, because your
destination is just on the other side of the mountains in this case) is
not such an easy thing to do in flight.
rg
Old March 10th 07, 07:55 PM posted to rec.aviation.ifr
Frank Ch. Eigler
Not so. If you're off an airway, then the off-route obstacle
clearance altitude (OROCA) applies, and is printed on the LO charts.
The first 250 miles or so are over pretty flat terrain. It is only
shortly before you get to the destination that the mountains begin.
Lost comm minimum altitudes apply per segment, not per leg. So in
this case, you would need to climb when you enter the grid square
containing tall rocks.
- FChE
Old March 10th 07, 08:00 PM posted to rec.aviation.ifr
John R. Copeland
"Ron Garret" wrote in message ...
Aren't the Grid MORAs shown on your enroute charts?
You said you are /G equipped, and thus know where you are.
Old March 10th 07, 11:22 PM posted to rec.aviation.ifr
ArtP
On Sat, 10 Mar 2007 11:38:27 -0800, Ron Garret
All I said was that it was not an option (assuming no emergency)
because you are expected to fly at or above the MEA for the route even
if it is higher than the initially assigned altitude.
Old March 10th 07, 11:24 PM posted to rec.aviation.ifr
Newps
able to fly,
He could fly it just fine, it was a vector. ATC does it all the time
and in reality isn't a route at all as there is no non radar component
to it.
Hogwash. ATC would never vector an airplane if every aircraft refused
because at some point you would hit something. The answer to the
question is if you lose comm you take care of yourself. It is an
emergency situation if terrain is a factor. You do what ever you have
to to avoid terrain/obstructions.
Old March 11th 07, 12:15 AM posted to rec.aviation.ifr
Hash: SHA1
able to fly,
to it.
If it was a vector, that changes the whole story. If it was a
clearance that he wasn't going to be able to accept, then there would
be some questions.
Oh, I agree. ATC would never vector a plane like that, don't
get me wrong. But as the OP had mentioned, if he accepted a routing
that he believed he couldn't fly and the weather was IMC, the question
would have to be asked on why he accepted that routing in the first
place.
BL.
iD8DBQFF80oHyBkZmuMZ8L8RAkfRAKDzFEOSiRcQm15A1HjHPo YsysLEWACgil9H
TCKtdW0HAN+xSn/DofOI5Mk=
=25D3
Old March 11th 07, 12:57 AM posted to rec.aviation.ifr
Ron Garret
Heh, you know, I had forgotten all about those. I've never had occasion
to use them until now.
rg
Real-world IFR currency Paul Folbrecht Instrument Flight Rules 47 March 23rd 05 04:19 PM
Real World Problem in FS9 The Real Cali Kid Simulators 12 December 6th 03 11:15 AM
Real World Weather (Isabelle) [email protected] Simulators 1 September 21st 03 09:53 PM
Real-time real world air traffic in flight sims Marty Ross Simulators 6 September 1st 03 04:13 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
