Last night I flew from SJC to VNY. To my astonishment I was cleared
vectors to SNS, then direct VNY (despite having filed a more standard routing) at 9000 feet. I knew perfectly well that the routing was going to change because I've done that route a zillion times, and indeed, near Bakersfield they switched me over to the standard LHS, LYNXX8 arrival, followed by vectors to the ILS RWY 16R. My question is: what should I have done if I'd been in IMC and lost comm before they changed my routing? By the book I should have continued to fly my clearance, which would have run me into a mountain around GMN, so that's probably not the right answer. Viable possibilities seem to include: 1. Divert (or climb) just enough to avoid the terrain around GMN, fly to VNY, and commence an approach from there. 2. As above, but vector myself for the ILS before reaching VNY. 3&4 - as above but fly to LHS and the LYNXX8 arrival. 5. Divert to the nearest airport with an IAP. My aircraft is /G so I know pretty much exactly where I am at all times. rg References: LYNXX8 arrival: http://www.airnav.com/depart?http://.../00067LYNXX.PD F ILS RWY 16R approach: http://www.airnav.com/depart?http://.../00552I16R.PDF |
On Sat, 10 Mar 2007 00:03:57 -0800, Ron Garret
wrote: Last night I flew from SJC to VNY. To my astonishment I was cleared vectors to SNS, then direct VNY (despite having filed a more standard routing) at 9000 feet. I knew perfectly well that the routing was going to change because I've done that route a zillion times, and indeed, near Bakersfield they switched me over to the standard LHS, LYNXX8 arrival, followed by vectors to the ILS RWY 16R. My question is: what should I have done if I'd been in IMC and lost comm before they changed my routing? By the book I should have continued to fly my clearance, which would have run me into a mountain around GMN, so that's probably not the right answer. Viable possibilities seem to include: There's only one. You fly it as last cleared. You arrive at the expected time as the expected place. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger writes:
There's only one. You fly it as last cleared. You arrive at the expected time as the expected place. Even if the expected place is a mountainside? He mentioned that his last clearance would have sent him into a mountain eventually. What do you do then? I'm curious, too. -- Transpose mxsmanic and gmail to reach me by e-mail. |
wrote: Last night I flew from SJC to VNY. To my astonishment I was cleared vectors to SNS, then direct VNY (despite having filed a more standard routing) at 9000 feet. I knew perfectly well that the routing was going to change because I've done that route a zillion times, and indeed, near Bakersfield they switched me over to the standard LHS, LYNXX8 arrival, followed by vectors to the ILS RWY 16R. My question is: what should I have done if I'd been in IMC and lost comm before they changed my routing? By the book I should have continued to fly my clearance, which would have run me into a mountain around GMN, so that's probably not the right answer. Viable possibilities seem to include: 1. Divert (or climb) just enough to avoid the terrain around GMN, fly to VNY, and commence an approach from there. 2. As above, but vector myself for the ILS before reaching VNY. 3&4 - as above but fly to LHS and the LYNXX8 arrival. 5. Divert to the nearest airport with an IAP. My aircraft is /G so I know pretty much exactly where I am at all times. rg "By the book", the route you fly should be the last clearance. I don't understand, however, why you would run into a mountain if you are following the altitude rules of the "lost-comm" regulations. Is your aircraft not able to climb to the minimum IFR altitude for your route? If that is the case, you have an emergency situation and can do whatever you need to do. Real world: I'm not familiar with your area. I would squawk 7600 and, depending on my location, probably fly that "usual" clearance. Once ATC notes that you have lost comm, they'll try to figure out what you're doing and should be protecting all the approaches at VNY. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Sat, 10 Mar 2007 11:08:26 +0100, Mxsmanic
wrote: Even if the expected place is a mountainside? He mentioned that his last clearance would have sent him into a mountain eventually. What do you do then? I'm curious, too. You still fly the assigned route at the highest of the last assigned altitude (or any expected altitude at the expected time) or the minimum altitude for the route. |
On Sat, 10 Mar 2007 06:51:48 -0500, Ron Rosenfeld
wrote: Is your aircraft not able to climb to the minimum IFR altitude for your route? If that is the case, you have an emergency situation and can do whatever you need to do. You might have to explain why you accepted the route if you knew you could not fly it. |
ArtP writes:
You might have to explain why you accepted the route if you knew you could not fly it. Many routes will eventually intersect terrain if there are mountains nearby. Nevertheless, you might well accept the route if you expect to be given a new heading or altitude before you get near terrain. If your radio fails, however, the situation changes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
"Mxsmanic" wrote in message
... ArtP writes: You might have to explain why you accepted the route if you knew you could not fly it. Many routes will eventually intersect terrain if there are mountains nearby. Nevertheless, you might well accept the route if you expect to be given a new heading or altitude before you get near terrain. If your radio fails, however, the situation changes. -- Transpose mxsmanic and gmail to reach me by e-mail. You can't file or accept a route you can't fly just because you're sure of a re-route. You have to assume that you will lose comm shortly after takeoff and fly the whole thing, as filed, minimim altitudes included. -- ------------------------------- Travis Lake N3094P PWK |
Travis Marlatte wrote: You can't file or accept a route you can't fly just because you're sure of a re-route. You have to assume that you will lose comm shortly after takeoff and fly the whole thing, as filed, minimim altitudes included. You're arguing IFR with someone who never leaves his bedroom. |
Travis Marlatte writes:
You can't file or accept a route you can't fly just because you're sure of a re-route. Sure you can. Aircraft do it all the time. For example, you can be assigned a route and altitude from the West Coast (of the U.S.) that will take you right into the side of a mountain if you continue on it long enough; but you accept it anyway because you know that ATC will change your heading and altitude long before that happens. You have to assume that you will lose comm shortly after takeoff and fly the whole thing, as filed, minimim altitudes included. But what if you are given vectors and altitude well after take-off, and these will _eventually_ lead you into a mountain, and you lose communications before ATC can change them? Do you return to your original flight plan, no matter what kind of altitude or course changes are required? Do you fly the last vectors you were given, and veer away from them only when it becomes unsafe to fly them (and which way do you go?)? What do you do? If you receive vectors very different from your filed route in crowded airspace and you then lose your radio, trying to return to your originally filed route might be dangerous. At the same time, you can't indefinitely follow vectors that will take you into terrain. If you follow the latter vectors, at some point you must deviate from them to avoid terrain--which way do you go then? -- Transpose mxsmanic and gmail to reach me by e-mail. |
| Thread Tools | |
| Display Modes | |
| Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 05:19 PM |
| Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 12:15 PM |
| Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 10:53 PM |
| Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 05:13 AM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
