#21
Andrew Sarangan provided this link to his article on the subject:
http://www.sarangan.org/aviation/art...er-article.pdf I thought Andrew's article was very well written. I record nearly all my flights, not just training. I usually don't listen to the full recording, but I like to be able to check a few minutes here and there and see if I heard or said what I thought I did. Yup, I really did acknowledge, "Follow the Alfa on Alfa." Yup, the DEN tower controller really did call traffic at 9:00. (It was at 3:00.) I like to have the device record continuously rather than use voice-activated mode so I have a timeline. I had been using an Olympus DM-1 I bought it in 2002 for $250. It could record 22 hours on the included 64 MB card. I later spent another $100 for a 128 MB card. That card recently died. I looked for a replacement card and found it's been discontinued. The few I found on the web were $100 each. Fortunately, my wife suggested I look at new recorders. I found an Olympus VN-3100PC at Circuit City for $75. It can record over 71 hours. Amazing! Its USB transfer rate is much lower than the DM-1, but I can live with that. Jon |
![]() I selected an mp3 player/recorder which used SD card (paid something like $100 in 2005). I put an 256mb card in it and it seemed to last forever. SD cards have come down quite a bit in prices. I had just paid $5 for 2gb card (after rebate). I will check to see if the larger memory SD cards will fit in my recorder. Hai Longworth |
Ummmm.. not quite.. He is correct....almost....
The insulation DOES protect by breaking down in the heat.. but not to water... Thats where there is a "time" protection at various temperatures. It turns into a "Cooling gas" (similar to steam) at fire temperatures, protecting the contents until the material is gone.. This sacrifical evaporation process offers a lot of heat protection.. This is how my 800 lb fire "proof" 4 drawer filing cabinet works... Now, the cheaper 200 dollar Wally World variety cabinet is , as you pointed out, just insulated... Dave On Thu, 22 Mar 2007 06:04:33 -0400, "Morgans" wrote: "Christopher Brian Colohan" wrote My understanding is that fire safes are designed to protect documents. They are lined with a chemical which produces water when it is heated, which stops documents from lighting on fire. Water probably won't do a lot of good for electronics. Lining produces water? Where did you hear that poppycock? They insulate, plain and simple, to keep the document below ignition temperature. |
#24
![]() "Lou" wrote in message ups.com... : Has anyone ever made their own in-flight recorder? I'm curious how : this would be done. I don't think it would be that difficult if you : use a regular cassette in one of those small fire safes. Just : drill a small hole to accomadate the mic wire. But how would you hook : it up to the intercom? : Or would you have a small lapel mic attatched to your headset? Anyway, : has anyone tried this? : Lou : Lopresti Fury folks are talking about an iPlane - they are putting in a iPod to do data acquisition as well as the standard stuff... |
How to Share a Flight Recorder in a Club? | ContestID67 | Soaring | 17 | September 26th 06 02:23 AM |
Backup Flight Data Recorder? | Fox Two | Soaring | 14 | August 27th 06 09:42 AM |
EW B-Model flight recorder | BDS | Soaring | 12 | August 19th 06 04:39 PM |
US: Flight Recorder Alert | Judy Ruprecht | Soaring | 8 | July 19th 04 09:04 PM |
who does Flight Recorder calibration... | ken ward | Soaring | 4 | March 5th 04 02:28 AM |
