I have an old EW B model flight recorder with no manual. Is anyone familiar
with this device willing to post a quick list of the keyboard functions? I have figured out the basics and can get it to record from my GPS - I just want to know how to access all of the functions, or as many as someone might be willing to spend the time typing out. BDS |
Obviously, you have figured out how to turn it on.
mine has a breif description of functions on the back of the unit. But if I remember correctly. press on off off to to turn the unit off, on and step through the setup to set time, day, year, user #, interval in seconds, and it starts recording. if you want to see the battery level you press on, 3, time, this will show a 400 to 500 battery level, if it is lower than that it will gjive you an err code, I think it is 6, other codes include low memory, memory out, ect. It was originally designed to output directly to a printer and to get it to downlaod you will need ew windows uploader program and a serial port or adaptor only a belkin usb to serial adaptors have proven to work. It has limited memory and setting it at a 8 second interval will only give you around 6-8 hours of flight time. I set mine to 12 or 16 to make sure I get everything on those long flights or 2 flight before downloading. Oh yea when you first turn it on it tell you how much memory is remaining and asks if you want to save it. There is also a feature that I don't use that allows you to set a higher sample rate and when you short out two pins in the connector it goes into a 2 second sample rate for two minutes when you get close to a turn point for quicker turns. I never used that feature. hope this helps. At 19:06 15 August 2006, Bds wrote: I have an old EW B model flight recorder with no manual. Is anyone familiar with this device willing to post a quick list of the keyboard functions? I have figured out the basics and can get it to record from my GPS - I just want to know how to access all of the functions, or as many as someone might be willing to spend the time typing out. BDS |
Cliff Hilty wrote: Obviously, you have figured out how to turn it on. mine has a breif description of functions on the back of the unit. But if I remember correctly. press on off off to to turn the unit off, on and step through the setup to set time, day, year, user #, interval in seconds, and it starts recording. if you want to see the battery level you press on, 3, time, this will show a 400 to 500 battery level, if it is lower than that it will gjive you an err code, I think it is 6, other codes include low memory, memory out, ect. It was originally designed to output directly to a printer and to get it to downlaod you will need ew windows uploader program and a serial port or adaptor only a belkin usb to serial adaptors have proven to work. It has limited memory and setting it at a 8 second interval will only give you around 6-8 hours of flight time. I set mine to 12 or 16 to make sure I get everything on those long flights or 2 flight before downloading. Oh yea when you first turn it on it tell you how much memory is remaining and asks if you want to save it. There is also a feature that I don't use that allows you to set a higher sample rate and when you short out two pins in the connector it goes into a 2 second sample rate for two minutes when you get close to a turn point for quicker turns. I never used that feature. hope this helps. At 19:06 15 August 2006, Bds wrote: I have an old EW B model flight recorder with no manual. Is anyone familiar with this device willing to post a quick list of the keyboard functions? I have figured out the basics and can get it to record from my GPS - I just want to know how to access all of the functions, or as many as someone might be willing to spend the time typing out. BDS Hi there not a good idea to set the rate at more than 5 sec. At the recent Russian Qualifiying Grand Prix an experienced pilot had a sample rate of 10sec and missed his last control point and bagged himself a 5 minute penalty. He claims his logger beeped but the trace shows clearly that he did not make a point inside the TP area which was parallel to the track for the finish. Checking in SeeYou showed his recording points just before and after the TP Tangent. Within these 10 seconds he propably did fly into the Sector and out of it again. Regards Bruno |
Mottley wrote:
Hi there not a good idea to set the rate at more than 5 sec. At the recent Russian Qualifiying Grand Prix an experienced pilot had a sample rate of 10sec and missed his last control point and bagged himself a 5 minute penalty. He claims his logger beeped but the trace shows clearly that he did not make a point inside the TP area which was parallel to the track for the finish. Checking in SeeYou showed his recording points just before and after the TP Tangent. Within these 10 seconds he propably did fly into the Sector and out of it again. Regards Bruno When I started analysing traces in 1993 (UK overseas Nationals) the standard thing was to set it to 10 second sampling. It was very rare not to have a point in the TP sector. However, it did happen and we just pulled the films - which were always in (how can you prove 1m accuracy on a photo?). Some pilots would increase the rate close to the TP, or mark the trace as they turned in the sector. No doubt things have moved on... Dave Kearns |
Dave K wrote: Mottley wrote: Hi there not a good idea to set the rate at more than 5 sec. At the recent Russian Qualifiying Grand Prix an experienced pilot had a sample rate of 10sec and missed his last control point and bagged himself a 5 minute penalty. He claims his logger beeped but the trace shows clearly that he did not make a point inside the TP area which was parallel to the track for the finish. Checking in SeeYou showed his recording points just before and after the TP Tangent. Within these 10 seconds he propably did fly into the Sector and out of it again. Regards Bruno When I started analysing traces in 1993 (UK overseas Nationals) the standard thing was to set it to 10 second sampling. It was very rare not to have a point in the TP sector. However, it did happen and we just pulled the films - which were always in (how can you prove 1m accuracy on a photo?). Some pilots would increase the rate close to the TP, or mark the trace as they turned in the sector. No doubt things have moved on... Dave Kearns There were some photos with the wingtip pointing at the turnpoint and the buildings leaning the wrong way, only proving the glider was somewhat inverted and possibly short of the turnpoint. Frank Whiteley (UK Opens photo, GPS, scoring team '93, '94) |
Frank Whiteley wrote:
There were some photos with the wingtip pointing at the turnpoint and the buildings leaning the wrong way, only proving the glider was somewhat inverted and possibly short of the turnpoint. Frank Whiteley (UK Opens photo, GPS, scoring team '93, '94) I think Steve Jones was the winner for the most marginal logger points. I think he managed 3 TPs in one flight with just one point in each sector. Those early days of GPS analysis were fun - I remember doing the first analysis of traces to get a 'wind at flying height' reading at Enstone for the 93(?) Open Nationals and then getting phone calls a year or so later from NZ asking for advice on this before they had their Worlds. Only last year I found my multi-way lead that could connect to any type of logger without changing leads... I must be getting old. Dave Kearns |
EW Baro Start Up Procedure
Press ON "FREE" flashes and then a number indicating % of memory remaining appears Press ENT "CLEr" flashes Press NO (unless you need to clear memory for flight) year appears. If incorrect, enter last 2 digits of year Pres ENT mm/dd appears. If incorrect, enter 4 digits Pres ENT time appears. If incorrect, enter time in hhmm 24 hrs format Pres ENT U (user number) appears. Enter number from 1 to 9999 to identity pilot, aircraft, or observer. 7 is default for Pete Brown Pres ENT INT (interval will momentarily appear.) Enter [10] seconds. Pres ENT Baro will now start flashing, recording PA( pressure altitude) at 10 second intervals. To Begin Calibration Process: (see page 30 of manual) Press [ENT] [4] [ENT] Reads in thousands of meters, i.e., .120 = 120 meters Baro should now be placed in decompression chamber with display facing operator and decompressed normally. Chart is made of chamber readings and baro display reading. To turn off Press [ON] [OFF] [OFF] Common Error codes Err2 memory low but useable 3.3 hrs at 10 second sample rate Err5 battery is low, change soon, several hours remain Err6 device has turned off due to extremely low battery Use 10 second sample rate for badges & records 10 seconds = 10 hours of data 30 seconds = 30 hours Battery: PP3 alkaline 9 volt To check battery level Press [ON] [3] [time] fresh battery should be ~500 replace at ~ 350 do not use below 300 I have a manunual that I could copy. Email me for details on where to send it if you would like. Pete Brown pdbatgcidotnet BDS I have an old EW B model flight recorder with no manual. Is anyone familiar with this device willing to post a quick list of the keyboard functions? I have figured out the basics and can get it to record from my GPS - I just want to know how to access all of the functions, or as many as someone might be willing to spend the time typing out. BDS -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
Great - thanks for the help!
BDS "Pete Brown" wrote in message ... EW Baro Start Up Procedure Press ON "FREE" flashes and then a number indicating % of memory remaining appears Press ENT "CLEr" flashes Press NO (unless you need to clear memory for flight) year appears. If incorrect, enter last 2 digits of year Pres ENT mm/dd appears. If incorrect, enter 4 digits Pres ENT time appears. If incorrect, enter time in hhmm 24 hrs format Pres ENT U (user number) appears. Enter number from 1 to 9999 to identity pilot, aircraft, or observer. 7 is default for Pete Brown Pres ENT INT (interval will momentarily appear.) Enter [10] seconds. Pres ENT Baro will now start flashing, recording PA( pressure altitude) at 10 second intervals. To Begin Calibration Process: (see page 30 of manual) Press [ENT] [4] [ENT] Reads in thousands of meters, i.e., .120 = 120 meters Baro should now be placed in decompression chamber with display facing operator and decompressed normally. Chart is made of chamber readings and baro display reading. To turn off Press [ON] [OFF] [OFF] Common Error codes Err2 memory low but useable 3.3 hrs at 10 second sample rate Err5 battery is low, change soon, several hours remain Err6 device has turned off due to extremely low battery Use 10 second sample rate for badges & records 10 seconds = 10 hours of data 30 seconds = 30 hours Battery: PP3 alkaline 9 volt To check battery level Press [ON] [3] [time] fresh battery should be ~500 replace at ~ 350 do not use below 300 I have a manunual that I could copy. Email me for details on where to send it if you would like. Pete Brown pdbatgcidotnet BDS I have an old EW B model flight recorder with no manual. Is anyone familiar with this device willing to post a quick list of the keyboard functions? I have figured out the basics and can get it to record from my GPS - I just want to know how to access all of the functions, or as many as someone might be willing to spend the time typing out. BDS -- Peter D. Brown http://home.gci.net/~pdb/ http://groups.yahoo.com/group/akmtnsoaring/ |
At 17:54 17 August 2006, Frank Whiteley wrote:
Dave K wrote: Mottley wrote: Hi there not a good idea to set the rate at more than 5 sec. At the recent Russian Qualifiying Grand Prix an experienced pilot had a sample rate of 10sec and missed his last control point and bagged himself a 5 minute penalty. Dont set the sampling rate to low with the model B. On my first 300k attempt I set it at 5sec and ran out of memory 2/3rd the way round. It then just stops recording. Yes i was that slow it took me 5 1/2 hrs altogether. Nigel |
I suspect that the one I have is technically no longer IGC approved since
the latest approval document states that Models A, B, and C must have version or upgrade dates after May 1997 and mine has AEWAB1238 9716 in the data file, which seems to indicate the 16th week of 1997 as the date of the firmware version. I have emailed EW Avionics to confirm this but am not optimistic about hearing anything back from them. BDS "Nigel Pocock" wrote in message ... At 17:54 17 August 2006, Frank Whiteley wrote: Dave K wrote: Mottley wrote: Hi there not a good idea to set the rate at more than 5 sec. At the recent Russian Qualifiying Grand Prix an experienced pilot had a sample rate of 10sec and missed his last control point and bagged himself a 5 minute penalty. Dont set the sampling rate to low with the model B. On my first 300k attempt I set it at 5sec and ran out of memory 2/3rd the way round. It then just stops recording. Yes i was that slow it took me 5 1/2 hrs altogether. Nigel |
| Thread Tools | |
| Display Modes | |
| RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 07:31 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Stupid Question | Crash Lander | Piloting | 35 | July 23rd 06 03:39 AM |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
