Powder Coat on 4130
Old March 24th 07, 02:36 AM posted to rec.aviation.homebuilt
cavelamb himself
Default Powder Coat on 4130
Morgans wrote:
" jls" wrote
Whatever the reason for the FAA hostility for powder coating, I have
receive pma'd parts that were powdercoated, or "powercoated" as a
member of my EAA chapter calls it.
Cute g
Although I have never had, or seen, an aircraft "powercoated" part crack, I
have seen other powder coated steel parts crack, and the powdercoated crack
remained hidden.
I would not choose powdercoating for a finish for anything I built.
Besides that, I can spray paints, myself, and can not so easily powdercoat
anything.
Besides that, the stuff is heavy!
Old March 24th 07, 03:09 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yeah, what he said! g
I can't believe I didn't think of that, too.
The stuff sure is pretty, though.
Another thing is, it is so tough, that it is not likely to show damage when
something smashes into it. If something hits my metal hard enough to chip
or mark paint, I would want to know about it. That stuff wouldn't show a
mark.
Jim in NC
Old March 24th 07, 10:09 PM posted to rec.aviation.homebuilt
J.Kahn
Drew Dalgleish wrote:
I find it very hard to believe that forces strong enough to crack 4130
wouldn't be strong enough to crack powder coating.
I suspect the real reason for not powdercoating the chopper frame has
a lot to do with filming schedules.
Drew, I believe it is related to the fact that the film is somewhat
flexible and tough so that it can accommodate a small subsurface change.
It's a bit like polyurethane paint's ability to hide filiform
corrosion, which really hurt Cessna owners back in the 80s when their
late 70s 172s started showing filliform corrosion under the paint
because Cessna used washer primer instead of epoxy primer when they
first went to urethane paints.
John
Old March 24th 07, 10:12 PM posted to rec.aviation.homebuilt
J.Kahn
Rich S. wrote:
"Don W" wrote in message
Now that is an interesting way of doing it. Just check the pressure on
preflight, and you'll know there aren't any cracks if it's still holding
pressure.
Well . . . you will know that the gauge pointer hasn't moved. For fire
extinguisher classes, I had a demo extinguisher which was cut open so's you
could see the interior. The gauge still read in the green.
Rich S.
It's probably overkill to have a gage reading continuously anyway. The
gage would change for some reason and you'd panic and ground your
airplane. Better to just hook something up during an annual.
John
Old March 25th 07, 12:39 AM posted to rec.aviation.homebuilt
jls
"Morgans" wrote in message
have
Cute g
crack, I
powdercoated crack
remained hidden.
I wouldn't use powdercoat on an engine mount, for sure and not on a
4130 fuselage. But it came on the lift strut of a PA-18 and a
rudder-- both PMA'd.
I would use it on the step (or stirrup) that helps you get into the
cockpit. There you need it because of all the wear you would have on
paint.
I have seen it used with great esthetic appeal on yokes.
powdercoat
anything.
Eastwood has a kit you can buy which is cheap and easy to use. You
just need an oven to cure it in once you've got it sprayed on your
part. The powder is attracted to the part by a high voltage.
I would not use powdercoat on highly stressed parts but it certainly
has a use in places on some aircraft, especially where the wear on
paint keeps you having to recoat it.
Jim in NC
James in WNC
Old March 26th 07, 04:23 PM posted to rec.aviation.homebuilt
Drew Dalgleish
On Sat, 24 Mar 2007 18:09:01 -0400, "J.Kahn"
John
Thanks John I thought powder coat was more like ceramic and
inflexible.
Old March 28th 07, 02:09 AM posted to rec.aviation.homebuilt
Alphonse Le Creur[_3_]
" jls" wrote in news:%9_Mh.30455$sC.5421
@bignews2.bellsouth.net:
"Drew Dalgleish" wrote in message
4130
has
I believe the reason is that the coating can lift if the surface
underneath gets a bit rusty, forming a pocket where moisture can form
between the coating and the steel. The coating won't deform and flake
off in the same way that paint will and the rust will continue until
it's eaten through something with little or no external evidence that
that is happening. There have been some real problems with tube
airplanes in wet regions and in fact the UK CAA is considering banning
it altogether.
ALC
Old April 2nd 07, 12:16 AM posted to rec.aviation.homebuilt
John T[_1_]
Ernest Christley wrote:
clare at snyder.on.ca wrote:
On Thu, 22 Mar 2007 23:29:15 -0400, "Phil" wrote:
Hello
Was watching American Chopper this evening , I see things on that
show that make me cringe but I do enjoy the antics of that family,
they always refer to Pipe if they are building a frame out of Tubing
etc. , this evening they were working on a dragster bike for NAPA and
when it came time to paint the machine they said that powder coat
couldn't be used because of the heat involved would ruin the 4130
tubing , seems like a lot of engine mounts and other A/C parts will
have to be junked , would like to hear some thoughts on this concept
, as an A/C welder it is of interest to me.
Thanks
Phil Lohiser
EAA 12873
Powder coating won't hurt 4130, but is NOT RECOMMENDED for aircraft
Responding to an "old" thread here, but powdercoat cures at about 400
deg. F.
Still not enough to change 4130
Powder coating is done at what, 275 degree F? I gotten my airframe
hotter than that by cussing at it when members wouldn't meet up
properly. 4130 will see it as a pleasantly warm temperature, suitable
for shorts and maybe a light sweater.
Old April 5th 07, 04:21 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
I have a Baby Belle helicopter that has the entire airframe powder coated.
It was done in 97. No problems to date. I know of several other
helicopters with powder coated airframes. No problems have been reported.
Yep it is heavy. Yep it is tough. If you have to remove some to make a mod
it takes a bit of sanding.
Big mistake was the color black. Friend had his powdercoated yellow and a
small crack showed up like a big black line.
Stu Fields
"John T" wrote in message
Hello
show that make me cringe but I do enjoy the antics of that family, they
always refer to Pipe if they are building a frame out of Tubing etc. ,
this evening they were working on a dragster bike for NAPA and when it
came time to paint the machine they said that powder coat couldn't be
used because of the heat involved would ruin the 4130 tubing , seems
like a lot of engine mounts and other A/C parts will have to be junked
, would like to hear some thoughts on this concept , as an A/C welder
Thanks
Phil Lohiser
EAA 12873
Responding to an "old" thread here, but powdercoat cures at about 400 deg.
F.
hotter than that by cussing at it when members wouldn't meet up properly.
4130 will see it as a pleasantly warm temperature, suitable for shorts
Alodine POWDER? flybynightkarmarepair Home Built 3 May 12th 06 01:18 AM
Gel Coat for Dummies Ray Lovinggood Soaring 12 December 24th 04 01:12 AM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 08:15 PM
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 07:01 AM
Tire talc...baby powder? No Spam Owning 12 August 8th 03 05:03 PM
