Gel Coat for Dummies
Old December 12th 04, 05:17 PM
Ray Lovinggood
Default Gel Coat for Dummies
Help.
I want to repair some self-inflicted wounds on the
leading edges of the wings on my LS1-d. The wounds
were created when getting the wings out from and/or
putting them back into the definintely non-Cobra/Komet
trailer. While not a Cobra, it is a 'serpent' type
of trailer, but more of a intestinal 'tape worm'...
I scraped off little bits of gel coat from time to
time and I want to reapply gel coat. Fill the little
divots and sand them off.
But, how do you sand the leading edge? These divots
were probably no more than about 50 mm long for the
largest and no more than about 10 mm high, again for
the largest. Others are smaller. And, they are right
on the nose of the leading edges.
I've begun the work with some gel coat and I've sanded
it down, but wondering what the 'right' way would be.
What size sanding block to use? I'm using a milled
piece of wood that measures about 75mm wide by 15 mm
thick by about 450 mm long and wrapping a sheet of
sanding paper around it.
My sanding movements have been parallel with the leading
edge, trying to keep the sand paper right over the
gel coat which 'stands proud' above the surrounding
areas.
Any help will be appreciated.
Ray Lovinggood
Carrboro, North Carolina, USA
Old December 12th 04, 06:00 PM
KiloKilo
There's a lot more in this article then you need ... you can actually
paint gelcoat with a brush for small LE repairs ... a sanding block/bar
is essential ... a small one is probably OK for small dings ... I use
longer for LE refinishing.
http://sailplane-racing.org/Articles...asw20_wing.htm
KK
Ray Lovinggood wrote:
Help.
Old December 12th 04, 07:23 PM
KiloKilo
Just to look at this a little more ... small fixes are often the most
difficult. As you sand down the newly applied material, you ultimately
hit the surrounding area and remove gelcoat there ... sometimes to the
point where the underlying darker glass surface starts to show. Except
for small chips, I always use some type of disclosure agent which shows
where I am sanding. I have also used tape to shield areas ... this can
help ... and always use the finest grit paper possible ... slower is
better. Leading edge sanding around the front radius requires feel and
wrist action ... it would be easier to explain on the phone if you want
to discuss.
KK
Old December 13th 04, 01:19 AM
There is an excellent video series on gel coat repairs for the
fiberglass boat community. These will give you the general knowledge
you need. You can then use the group for the more specific knowledge of
work on sailplanes.
Cosmetic Gelcoat and Fiberglass Repair Volumes I-III
V I: Gelcoat 100 minutes
V II: Stress Cracks, Air Voids, and Fractures 104 minutes
V III: Color Matching 34 minutes
Bennett Marine Video 1989
Marina Del Ray, CA 90292
Old December 13th 04, 02:46 AM
Bob Gibbons
Nothing new here, but what I do is use a short piece (6 inches) of 1
inch square aluminum bar stock. I put strips of various grades of
wet/dry sandpaper on each side. Say, 200grit, 400 grit, 600 grit, 1000
grit.
I support the wing leading edge down and paint on some matching
gelcoat. The leading edge down assures complete coverage of the
leading edge dings.
When the gelcoat hardens I use the multisided sanding bar to
progressively remove the higher material, using water and finer
sandpaper as I progress down.
Finish with polishing compound and wax.
Bob
On 12 Dec 2004 17:17:38 GMT, Ray Lovinggood
Help.
areas.
Ray Lovinggood
Old December 13th 04, 03:43 AM
Tony Verhulst
What, if anything, do you do about matching the shade of the existing
surface?
Tony V.
http://home.comcast.net/~verhulst/SOARING
Old December 13th 04, 06:16 AM
F.L. Whiteley
Hopefully, basic white without tints.
Gels and Imron may discolor with age and environment. I had an Imron
painted Open Cirrus and tried very hard to match and sought 7 different
opinions before ordering, using the factory color charts. Under overcast
and blue sky and fluorescent lighting there was some divergence between a
light gray tint and a light blue tint. I went with the predominently female
opinions, since color vision deficiency is more generally a male trait.
It was a bit blue once applied, the gray may have worked better. However, I
had to order a minimum amount and when the person I sold my final share to
damaged the glider, the fuselage was re-sprayed with the remainder, so it
finally matched.
Frank Whiteley
"Tony Verhulst" wrote in message
news:ld8vd.227573$HA.7445@attbi_s01...
surface?
Tony V.
Old December 13th 04, 12:33 PM
Ray Lovinggood
Tony,
That's the LEAST of my worries. :-)
Ray
of the existing
surface?
Tony V.
Old December 22nd 04, 05:41 AM
Larry Goddard
OK everyone, take a deep breath before responding how stupid my approach
is... I am fully aware of the potential damage that _could_ occur.
One method that I have used successfully doing similar things to my
wings is to use a _clean_ mill ******* file. I know, I know.... sounds
like heresy to lay a file on your wing but if you lay it flat, parallel
to the leading edge, it is possible to "file" down the proud portion of
the gelcoat without gouging into or scratching the existing gelcoat.
The file rides smoothly over the existing gelcoat but takes off the
excess new gelcoat. It takes a light sensitive touch but makes very
quick work of the job because the teeth of the file only catches on the
raised replacement gel coat.
Try at your own risk!!!
Larry Goddard
"01" USA
Help.
areas.
Ray Lovinggood
Old December 22nd 04, 09:57 PM
John Sinclair
Actually that's a very good idea, Larry
We did just that when the repair shop was open ('76
to '96)
+ Scrub with acetone to remove wax and crud.
+ Sand edges with 600 to remove oxidized gelcoat (or
a yellow ring will be trapped at the edge of your repair)
+ Mask off and brush on several coats of gelcoat. Use
heat gun to make it dry faster (hair dryer works)
+ Remove high spots with a file, this works best on
straight sections, like leading edges.
+ Wet sand with a block (600 & 800)
+ Buff out with a wool pad and liquid buffing compound.
We called the above, 'Dings & Things' Every annual
came with a request to fix this ding and take a look
at ---------------------
Best if a reasonably clever owner does this on his
own.
Happy, Happy to all on ras,
JJ
stupid my approach
_could_ occur.
things to my
I know.... sounds
it flat, parallel
to the leading edge, it is possible to 'file' down
existing gelcoat.
but takes off the
but makes very
only catches on the
Larry Goddard
'01' USA
Help.
be.
mm
areas.
Ray Lovinggood
One coat paint for aluminum? [email protected] Home Built 10 September 17th 04 07:01 AM
Repairing gel coat chips Gary Evans Soaring 6 April 27th 04 03:23 AM
Water-borne barrier coat larsen-tools Home Built 0 February 3rd 04 08:42 PM
Refinishing: Who has tried a shortcut? Ian Forbes Soaring 60 December 26th 03 09:30 AM
Poly paint Miguel Lavalle Soaring 18 October 30th 03 08:55 PM
