On Wed, 4 Apr 2007 18:26:52 -0400, "Capt. Geoffrey Thorpe" The Sea
Hawk at wow way d0t com wrote: The volatility should be the average of the two. I don't know that I would assume that - vapor pressure can have some non-linear behavior. Example: When you add ethanol, the vapor pressure with 10% is higher than the vapor pressure at either 0% or 85%... I am not disagreeing, but do wonder where this information is available? Thanks, George |
"GeorgeB" wrote in message
... On Wed, 4 Apr 2007 18:26:52 -0400, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote: The volatility should be the average of the two. I don't know that I would assume that - vapor pressure can have some non-linear behavior. Example: When you add ethanol, the vapor pressure with 10% is higher than the vapor pressure at either 0% or 85%... I am not disagreeing, but do wonder where this information is available? Thanks, George I've seen it at work - no help to you, eh? There are a number of SAE papers covering this. e.g. http://www.sae.org/technical/papers/852116 http://www.sae.org/technical/papers/2000-01-1712 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Alternate Fuels | john smith | Piloting | 0 | September 25th 05 03:10 AM |
Mixing PPG delta and PPG Durathane.....??? | Randall Shimizu | Home Built | 3 | November 5th 04 05:07 AM |
U-2 fuels ? | Lynn Coffelt | Military Aviation | 2 | May 29th 04 04:48 PM |
mixing 80 and 100 and autogas...? | R. Wubben | Owning | 5 | March 15th 04 03:28 AM |
Mixing construction materials | Neal Fulco | Home Built | 3 | October 7th 03 01:55 PM |
