Mixing construction materials
Old October 5th 03, 08:27 PM
Neal Fulco
Default Mixing construction materials
In the " I wonder if this would work " department, I have a question
about mixing different materials in main airframe structures. To make
a long story short, I was wondering if some weight could be saved by
making a wing with a carbon fiber spar ( high strength, light weight )
with aluminum ribs and skins. Would the carbon and aluminum be
compatible? Of course an acceptable method would have to be devised
to attach the ribs and skins to the spar, but I don't see this as a
big problem. Since the spars are some of the heaviest part of the
wing, I thought this would be a good way to save some weight, and in a
case I have in mind, an easy way to join the spar to the fuselage,
especially if the fuselage is composite. I would want to keep the
rest of the wing aluminum mainly to save dollars, but also because of
the proven history. Would the weight savings be worth the effort?
Neal
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 08:48 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
