A friend forwarded the following study ... has anyone tested
Transponder Antenna output on a graphite ship without an additional ground plan? Title: Performance of graphite epoxy as an antenna ground plane Authors: Erickson, J. E.; Graham, O. D. Affiliation: Air Force Academy, CO. Publication: Final Report Air Force Academy, CO. Publication Date: 08/1978 Category: Communications and Radar Origin: STI NASA/STI Keywords: AIRCRAFT ANTENNAS, GRAPHITE-EPOXY COMPOSITES, GROUND SUPPORT EQUIPMENT, PLATES, ANTENNA RADIATION PATTERNS, DIPOLE ANTENNAS, IMPEDANCE MEASUREMENT, MONOPOLE ANTENNAS Bibl iographic Code: 1978aifo.reptQ....E Abstract This final report describes work undertaken by members of the Department of Electrical Engineering at the USAF Academy, Colorado for the Post Doctoral Program/Rome Air Development Center/Griffiss AFB, N.Y. This effort involved a study of graphite epoxy composite material as an antenna ground plane at the frequencies of 370 and 837 MHz. Five by five foot sheets of graphite epoxy were provided by the Composites Laboratory of the Air Force Flight Dynamics Laboratory at Wright-Patterson AFB. Antenna impedance and antenna pattern measurements were made using these graphite epoxy sheets and also an identically sized sheet of aluminum. These measurements were made with both monopole and dipole antennas and also with a UHF blade antenna from an F4 aircraft. Results show that the 50 ply sheet of graphite epoxy behaves identically with an aluminum ground plane when used with a monopole or dipole receiving antenna at 370 and 837 MHz |
"Ken Kochanski (KK)" wrote in message oups.com... A friend forwarded the following study ... has anyone tested Transponder Antenna output on a graphite ship without an additional ground plan? .....Snip.... .... Results show that the 50 ply sheet of graphite epoxy behaves identically with an aluminum ground plane when used with a monopole or dipole receiving antenna at 370 and 837 MHz 50 ply! How many layers of graphite are used in the construction of the average sailplane? Wayne HP-14 "6F" http://www.soaridaho.com/ |
yeah, understood, hardly that many ... I just want to know if we have
any actual test results. KK |
On Apr 6, 8:07 am, "Ken Kochanski (KK)"
wrote: yeah, understood, hardly that many ... I just want to know if we have any actual test results. Standard practice for Schleicher is to install the antenna on the ASH-26E, ASW-27, etc... just behind the main wheel. Pretty much looks like they just drill a hole and install a typical antenna with no other prep work. Beyond the lack of complaints of poor performance, I don't know if there has been any scientific testing performed to prove out the installation. -Tom |
I have a stub antenna installed on the underside of my Ventus 2cM fuselage
(carbon-fiber / epoxy). No scientific testing, but it seems to work just fine. The high frequency electro-magnetic fields generated by transponder antennas hardly penetrate at all into metal or graphite, so I wouldn't expect 5 layers or 50 layers to make any significant difference. Ray "5Z" wrote in message ups.com... On Apr 6, 8:07 am, "Ken Kochanski (KK)" wrote: yeah, understood, hardly that many ... I just want to know if we have any actual test results. Standard practice for Schleicher is to install the antenna on the ASH-26E, ASW-27, etc... just behind the main wheel. Pretty much looks like they just drill a hole and install a typical antenna with no other prep work. Beyond the lack of complaints of poor performance, I don't know if there has been any scientific testing performed to prove out the installation. -Tom |
Notice that they stated for use as a receiving antenna. I haven't done any
studies either, but the stub antenna mounted just forward of my landing gear on my discus 2b seems to work fine. There is no trouble in the static tests to get it certified, and local controllers seem to "see" my reply just fine. Bob Greenblatt |
On Apr 6, 6:52 am, "Wayne Paul" wrote:
50 ply! How many layers of graphite are used in the construction of the average sailplane? Average, I couldn't say. But when we made Brad's carbon fiber HP-24 fuselage, we used the equivalent of about 5 plies at 0.010" (0.25mm) per ply. In thickness, weight, and stiffness it came out to be about like what the European factories do. Thanks, Bob K. |
| Thread Tools | |
| Display Modes | |
| antenna ground planes | [email protected] | Home Built | 12 | November 5th 05 12:30 AM |
| VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 05:29 PM |
| Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 09:59 PM |
| Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 04:32 AM |
| Wanted: Transponder antenna | Grandpa B. | Home Built | 22 | November 28th 03 09:03 AM |
