Is there any trick how to prevent suction mount with a relative heavy gps
device on it (G96) to fall off the canopy every half an hour or so?! The canopy is new, surface is perfectly clean, almost flat (blanik's canopy starboard side), tried two diferent suction mounts, one with light PDA device mounted but the result is the same - it is always falling off the canopy! |
A small amount of spit for a seal and do it while the air is at low pressure
eg while as high up as possible. |
I was using very effective suckers with a locking action - until the
dangers of cracking canopies was pointed out. Clinton LAK 12 |
Hi,
Have you tried the RAM-B-224 suction cup mounts that I sell? They work great for me and I've sold hundreds of them to glider pilots around the world. If you clean the canopy and wet the suction cup it should never fall off. I use mine to hold an iPAQ hx4700 with large battery and CF GPS with no problems. It has withstood the 4Gs of a loop and the bumps of a landing on a grass runway in a Ventus with no shock absorber and the tire pumped up to a high pressure - very bumpy. It should hold your large Garmin fine as well. If you have tried that suction cup without success then you may have received a defective one that could be replaced free of charge. You can see details he http://www.cumulus-soaring.com/ram.htm Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "db" wrote in message ... Is there any trick how to prevent suction mount with a relative heavy gps device on it (G96) to fall off the canopy every half an hour or so?! The canopy is new, surface is perfectly clean, almost flat (blanik's canopy starboard side), tried two diferent suction mounts, one with light PDA device mounted but the result is the same - it is always falling off the canopy! |
Hi Clinton,
Good point! I sell a suction cup from RAM called a RAP-224-1 that pulls a hard vacuum when you rotate the locking ring. I don't recommend it for use on glider canopies because it pulls the canopy out of shape - which could cause crazing or other damage in the long run. I would never use one on a glider canopy, but it works well on glass windows in cars. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Clint" wrote in message oups.com... I was using very effective suckers with a locking action - until the dangers of cracking canopies was pointed out. Clinton LAK 12 |
On Apr 11, 9:26 am, "Paul Remde" wrote:
Hi, Have you tried the RAM-B-224 suction cup mounts that I sell? They work great for me and I've sold hundreds of them to glider pilots around the world. If you clean the canopy and wet the suction cup it should never fall off. I use mine to hold an iPAQ hx4700 with large battery and CF GPS with no problems. It has withstood the 4Gs of a loop and the bumps of a landing on a grass runway in a Ventus with no shock absorber and the tire pumped up to a high pressure - very bumpy. It should hold your large Garmin fine as well. If you have tried that suction cup without success then you may have received a defective one that could be replaced free of charge. You can see details hehttp://www.cumulus-soaring.com/ram.htm Good Soaring, Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com "db" wrote in message ... Is there any trick how to prevent suction mount with a relative heavy gps device on it (G96) to fall off the canopy every half an hour or so?! The canopy is new, surface is perfectly clean, almost flat (blanik's canopy starboard side), tried two diferent suction mounts, one with light PDA device mounted but the result is the same - it is always falling off the canopy! Just to reinforce what Paul says, I bought that suction cup mount from him. It holds my Axim just fine. It never comes off. I hate to say this, but I usually lick around the edge, then stick it on. But I have to remember to clean the inside of the canopy _really_ well, or my partner gives me such a ration of s**t that I can hardly stand it. "There's no reason to ever touch the canopy." Well, sometimes, ya gotta. In my truck, I use the same Axim for navigation, and there I have a smaller suction cup with a toggle lever on it that holds for weeks at a time, but eventually falls off. Paul's suction cup is much better. Ed Ed |
flying_monkey wrote:
"There's no reason to ever touch the canopy." Well, not if you fly ASW 15. I have to touch it after each landing... no way to get out without touching. ;( Andreas |
Has anyone ever seen a canopy cracked by a 'lever-action' suction
device? You've got me worried now .......... |
I read somewhere that water will work better than spit, and my own
experience reinforces this. I can't explain why, but try water instead of spit. Fred |
Hi Bernie,
I doubt it would crack a canopy. My fear (founded or unfounded) is that the localized deformation of the canopy would lead to internal crazing - especially in extremely hot or cold conditions. I just wouldn't want to risk a $2000 to $5000 glider canopy. Paul Remde "Bernie" wrote in message ups.com... Has anyone ever seen a canopy cracked by a 'lever-action' suction device? You've got me worried now .......... |
Lycoming O-360 oil suction screen torque | [email protected] | Owning | 8 | August 19th 06 07:52 PM |
PDA suction mount? | Bernie Baer | Soaring | 7 | August 17th 06 02:21 AM |
G-force vs. Ram GPS suction mount | [email protected] | Piloting | 9 | October 20th 05 10:51 PM |
Suction mounts for Garmin 296 | Ekim | Piloting | 5 | June 25th 05 10:55 AM |
Effect of suction on DG | Jay Honeck | Owning | 6 | March 3rd 04 01:12 PM |
