PDA suction mount?
Old August 14th 06, 10:54 AM posted to rec.aviation.soaring
Bernie Baer
Default PDA suction mount?
Hi, does anybody recognise the triple suction PDA mount pictured in the =
cockpit at this site: http://www.sequrux.com/~pw5/new_page_2.htm
Brand/make/model/suppliers, any info apreciated. I'm in Australia so =
would need to mail order.
Thanks, Bernie.
Old August 14th 06, 11:27 AM posted to rec.aviation.soaring
Mal[_1_]
"Bernie Baer" wrote in message
Thanks, Bernie.
His email is at the top and bottom of the website ask him were he got it
from.
Old August 14th 06, 02:24 PM posted to rec.aviation.soaring
Thanks, Bernie.
Personally, I have made good experiences with RAM Mounts:
http://www.ram-mount.com/
....and Brodit:
http://www.brodit.com/
/Reno
Old August 14th 06, 03:21 PM posted to rec.aviation.soaring
John Scott
I've had very good luck with a RAM suction cup mount that I purchased from
Cumulus-Soaring.
http://www.soarmn.com/cumulus/ram.htm
I use the RAM-B-224 suction cup with the RPA-B-201 arm and RAP-B-238 ball.
This is attached to the appropriate cradle for your model iPAQ. In my case
I have a 3850 with a PC-CARD sleeve.
This stayed firmly attached to the canopy recently for more than 6 hours. I
can also attest to it holding firmly during a very rough off field landing.
In fact, I now remove the stylus from the iPAQ as it has a tendancy to come
out during bumpy landings.
John Scott
Old August 14th 06, 04:31 PM posted to rec.aviation.soaring
bumper
Be cautious about using suction cups on canopy acrylic. Cracking and crazing
can be a potential problem.
When in the sun, the area where the suction cup is attached will heat up
more rapidly and get to a higher temperature than the surrounding canopy.
Also, if the suction cup is not completely cured, some of the chemicals in
the cup can attack the acrylic.
I've seen a suction cup removed and a round area of crazing underneath. This
was, however, not on a glider but on a power plane.
all the best,
bumper
Thanks, Bernie.
Old August 14th 06, 04:43 PM posted to rec.aviation.soaring
John Scott
I've seen no canopy problems on any of the planes I have flown over the last
2 years using the RAM suction cup.
However, I generally only attach the suction cup 5-10 minutes before launch
and remove it shortly after landing. The planes due not sit out in the sun
idle with the suction cup in place. I think this may be why I haven't
encountered the potential problems Bumper identified. The suction cup does
leave a ring on the canopy from being moisten prior to installation. This
cleans off easily with a little water and paper towel.
I use the suction cup mount when flying club planes. For my own plane I am
fitting a permanent mount for the iPAQ.
I also use the suction cup mount to install the iPAQ in my car for
navigation on road trips, with different software, of course.
John
Old August 15th 06, 02:39 PM posted to rec.aviation.soaring
Graeme Cant
Thanks, Bernie.
That site appears to date from about 2001 so if it's a bought one it
could be long gone.
In any case, don't mail order. Buy three suction cups from the bathroom
section of Bunning's and fold your own from 1.6mm (1/16") Al and Velcro.
Easy.
Mine's worked without fail for 5 years now.
I got the idea and a pattern from someone on this group and if I
remembered who it was I'd credit him! Great idea.
GC
Old August 17th 06, 02:21 AM posted to rec.aviation.soaring
Bernie Baer
Hi Graeme et al,
the site was last updated 2005 but as he has not replied
to my email I had already planned a trip to Bunnings!
The Winpilot site has some other photos of the same
or similar mount so had figured it was somewhat home
made. I've roughed out a plan form to cut from Al,
a prototype in cardboard will soon be in production.
Thanks to all who made constructive comments.
Regards, Bernie.
Softcomm panel mount intercom? Junk? [email protected] Owning 10 November 26th 05 06:46 AM
G-force vs. Ram GPS suction mount [email protected] Piloting 9 October 20th 05 10:51 PM
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 01:26 AM
Mount Washington NLS 14 dedication Kevin Brooker Soaring 0 August 8th 05 10:38 PM
Effect of suction on DG Jay Honeck Owning 6 March 3rd 04 01:12 PM
