Positioning of navs and strobes on the wing tip???
Old April 24th 07, 12:16 AM posted to rec.aviation.homebuilt
DonMorrisey
Default Positioning of navs and strobes on the wing tip???
Hello group.
Is there a regualtion/description detailing how/where Nav/Strobe/
Position lights get mounted on the wing tip?
I have Aeroflash lights and am ready to cut my fiberglass wing tip to
mount them but am wondering if there are specific recommendations
other than they should be seen from 360 degrees.
Thanks for the help. Don....
Old April 24th 07, 02:56 AM posted to rec.aviation.homebuilt
Vaughn Simon
"DonMorrisey" wrote in message
Hello group.
I believe that the nav lights are only supposed to be seen from 180 degrees
or so. At night, you should be able to determine the relative direction of an
observed plane by the pattern of lights. Certainly there is a regulation
somewhere, but if you just take a walk around the parking area at your local
small airport, you will get the idea of where they go.
Vaughn
Old April 24th 07, 03:51 AM posted to rec.aviation.homebuilt
Ernest Christley
DonMorrisey wrote:
Hello group.
http://ernest.isa-geek.org/Delta/Exp...iment_LED.html
Just a little ways down the page shows how the lights should be laid out.
Old April 24th 07, 12:54 PM posted to rec.aviation.homebuilt
Peter Dohm
"Ernest Christley" wrote in message
DonMorrisey wrote:
Hello group.
The actual rule on this for US registered aircraft, AFAIK, is Part 23; which
is on line at:
http://www.access.gpo.gov/nara/cfr/w...4cfr23_04.html The position
lighting portion begins at 23.1383
Peter
Old April 24th 07, 05:11 PM posted to rec.aviation.homebuilt
Michelle P
DonMorrisey wrote:
Hello group.
Visibility should be 120 degrees per position.
Left from nose counter clockwise to 120 degrees
Right from nose clockwise to 120 degrees
Rear the remaining 120. Must be visible from above and below as well. AC
43-13 or Part 23 would have the legal answer.
Michelle
Old April 25th 07, 12:43 AM posted to rec.aviation.homebuilt
DonMorrisey
Thanks Peter and Ernest, that is exactly what I was looking for.
Don.
Old April 25th 07, 04:28 AM posted to rec.aviation.homebuilt
Ernest Christley
DonMorrisey wrote:
Hello group.
is on line at:
Peter
Those are the portions quoted on my webpage, but thanks for that link.
I haven't found a reference where all the sections were seperated out
into easily digestable pieces.
Old April 25th 07, 04:29 AM posted to rec.aviation.homebuilt
Ernest Christley
Michelle P wrote:
DonMorrisey wrote:
Hello group.
Michelle
The side lights span 110 degrees. The rear covers 140.
Old April 25th 07, 03:02 PM posted to rec.aviation.homebuilt
Peter Dohm
Michelle P wrote:
DonMorrisey wrote:
Hello group.
Michelle
I believe that the rear position light spans something like 180 to 190
degrees.
Peter
Old April 25th 07, 08:02 PM posted to rec.aviation.homebuilt
jerry wass
Michelle P wrote:
DonMorrisey wrote:
Hello group.
Michelle
degrees.
Peter
Yeah, ya gotta have it span more'n 180° er ya couldn't tell which
direction the observed plane was a goin'..(when it's flyin 90° to your
line of sight)
Hershey bar wing vs composite wing - how much drag? Nathan Young Home Built 34 March 29th 07 11:20 PM
Irretating strobes noise John Doe Owning 7 December 22nd 05 01:52 PM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
Strobes Jim Kellett Soaring 18 December 6th 03 12:49 PM
