interesting moment yesterday on final
Old April 27th 07, 09:11 PM posted to rec.aviation.piloting
Neil Gould
Default interesting moment yesterday on final
Recently, Tom posted:
So I went for a lovely flight yesterday, from Bedford (KBED) down to
Nantucket (KACK) for dinner. We flew down there in the last hour or so
of daylight with a smooth ride and great views, and then returned at
night with an even smoother ride and great night-time views, including
a few circles over Harvard, MIT and Back Bay on the way home. ATC were
very accommodating since it was fairly late.
Bedford tower was closed so I was on the CTAF frequency as I
approached the field. I was initially thinking of taking runway 24
since the winds were 190. When I announced my imminent arrival in the
vicinity of the field an aircraft informed me they were on final for
11. They also mentioned an aircraft in the area that was at 5,000 and
on an IFR flight plan but not talking to ATC, possibly inbound for
landing as well.
Armed with this information, I changed my plan and entered a downwind
leg for 11 (since the winds were not strong and that seemed to be the
established pattern). I announced my downwind leg, my base and my
final (looking out for traffic all the way). When I was at 1 mile
final, I hear
"Nxxxx, 3 mile final for 11, Bedford"
I respond with "I am 1 mile final for 11, Bedford"
He responds with "We'll slow it down"
This doesn't comfort me that much, since I'm only going 65 knots.
Maybe I should have said this to him at the time.
Then he comes in again with "We're going to break off our approach, do
a 360 and rejoin"
As I'm at 50ft, he says "Have you landed yet"
I reply with "Just about to touch down"
Then I land, clear the runway, inform him I am clear, and then he
lands. Everything works out fine although my landing isn't exactly a
greaser.
I didn't feel that great about the incident: did I do something wrong?
Why didn't I see him on final before I turned final (I specifically
remember looking in that direction before turning final)? What if the
timings had been slightly different?
And for his part, shouldn't he have been on the frequency and known I
was in the pattern? Shouldn't his first call have been a lot sooner
than 3 mile final? Shouldn't he have flown a circuit rather than come
straight in? I'm assuming he wasn't in any kind of emergency situation
as he would have asked me to go around.
Thoughts appreciated, especially from those with extensive flying
experience.
Tom
My first reaction is that I'm surprised that he wasn't looking for you,
given that he was attempting a straight-in from only 3 miles out with
known traffic in the pattern. He shouldn't have had to ask whether you
landed yet or not.
At uncontrolled fields anything can happen, and should be watched for. The
uncontrolled field I use most often has two crossing runways and *no*
established pattern. It isn't unusual to have several planes in the
pattern as well as incoming traffic of various kinds from biz jets to
biplanes and helos. People come in as they wish, and only those with
radios can announce. Gives "see and avoid" a bit of signficance! ;-)
Neil
Old April 27th 07, 09:17 PM posted to rec.aviation.piloting
Larry Dighera
On 27 Apr 2007 10:13:14 -0700, Tom wrote in
. com:
That depends on the altitudes of your and his aircraft:
http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.2.4.7
§ 91.113 Right-of-way rules: Except water operations.
(d) Converging. When aircraft of the same category are converging
at approximately the same altitude (except head-on, or nearly so),
the aircraft to the other's right has the right-of-way.
(g) Landing. Aircraft, while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take
advantage of this rule to force an aircraft off the runway surface
which has already landed and is attempting to make way for an
aircraft on final approach. When two or more aircraft are
approaching an airport for the purpose of landing, the aircraft at
the lower altitude has the right-of-way, but it shall not take
advantage of this rule to cut in front of another which is on
final approach to land or to overtake that aircraft.
Perhaps he was so low, that his visual conspicuity was diminished
against the surface clutter?
Old April 27th 07, 09:18 PM posted to rec.aviation.piloting
Tom[_5_]
This sounds like misinformation.
What do you mean?
As far as looking down final, ...the base leg is a busy period where you're
rolling level, maintaining your decent, watching your airspeed, maybe adding
flaps, looking for your landing point, and clearing the final approach for
any other inbound. Lots of times, if you are not aware of an actual inbound,
that "look" is just cursory and short of a 747 with lights on, you'll miss
that traffic. Also, pilots do not always report the distances accurately.
Sounds like he may have initiated a standard rate 360 and called you on roll
out, which would be about 2 minutes later. But you state a 1 mile final, and
approx two minutes later you were 50agl, that's a long time for a no wind 1
mile final.
Good point about the look possibly being cursory. My guess is he
called my half way through the turn (which was why he couldn't see
me), which would be about right for a 1 minute 1 mile final at 65
knots.
But again, the events you describe sound pretty routine for after hour ops
at any airport under a B or C shelf. When I first learned to fly I actually
avoided non-towered fields because planes seemed to pop out of the strangest
places.
Places I know I just looked and were empty. ;-o
Old April 27th 07, 10:06 PM posted to rec.aviation.piloting
Erik
I had an opportunity to go head to head with someone
once. I was in the established pattern, there were about
3 or 4 of us. I called my turn to base. Shortly after,
this guy announces base.
I'm looking around like my head was detached from my body.
I called and asked if he really had announced base because
I can't find anyone. He never answers.
I'm still looking and turn final. I announce my position
and he announces final.
Lo and behold, there he is, about a mile away from me coming
from the opposite direction. I move over to the right a bit
and stop my descent. Someone told him that he was opposite
the calm wind runway. He announces he's leaving the area and
splits.
I go around and do it all again.
(Note to self: Remember that yours isn't the only pattern,
there's another on the other runway)
Old April 27th 07, 10:26 PM posted to rec.aviation.piloting
karl gruber[_1_]
landing. A plane calls out that he is 5 miles for the straight in. I
replied that with the traffic, traditional pattern may be appropriate. He
called that he would enter the correct pattern.
Regards, Ross
C-172F 180HP
KSWI
Are you working on your junior "G" man controller badge? I'd have told you
to mind your own business!
Karl
Andrew Gideon
On Fri, 27 Apr 2007 18:02:13 +0000, ktbr wrote:
I like to be over on the local frequency by
at least 5 miles out.
Even w/o being cleared, I like to at least be monitoring CTAF further out
than that. However, if the frequency is busy this becomes impossible as
it interferes with my ability to communicate with ATC. So it's a
sometimes thing.
[Why doesn't an audio panel have a "priority" mechanism, so a squelch
break on com X squelches com Y (or nav X or nav Y)? Or do some have this
feature?]
It's a little annoying, in a way. I was just at an ASF seminar where
"anyone in the pattern" was [justifiably] ridiculed. But the idea that
anyone approaching the airport should be on the CTAF while still way out
ignores the reality of IFR in some locations/under some conditions.
- Andrew
Old April 27th 07, 10:38 PM posted to rec.aviation.piloting
Erik
Regards, Ross
C-172F 180HP
KSWI
Karl
That is exactly what I was thinking. Who the hell is he to tell
someone that doesn't give a crap about the pattern what to do!
I hate the busy bodies that are always sticking their nose in there
trying to disrupt people that are doing their own thing regardless
of what everyone around them are doing. Why, just the other day
I was at Carl's Jr and there was a big line. I thought, "I don't
want to wait all this time!" and went right to the counter. Some
busy body behind me told me to get back in line. I told them where
they could stick it.
Old April 27th 07, 11:12 PM posted to rec.aviation.piloting
Judah
ktbr wrote in :
If he was IFR its possible ATC did not clear him to go to advisory
frequency soon enough, for whatever reason... maybe he did not have
the airport in sight soon enough. I like to be over on the local
frequency by at least 5 miles out.
If he was IFR, ATC would have probably informed him there was traffic in the
pattern at his destination and might have tried to wait until he had a visual
before allowing him to change frequency.
If he was a big plane with multiple radios (and perhaps pilots), he should
have been monitoring CTAF for many more miles than 3, but he might not have
been talking.
He yielded and did a 360, which implies to me that he might have known the OP
was there and what to expect...
Old April 27th 07, 11:14 PM posted to rec.aviation.piloting
Judah
Andrew Gideon wrote in
news
feature?]
On our CNX-80's (or whatever they're called now , you can push a button to
monitor the standby frequency. The selected frequency will cut off the
standby frequency if both are receiving...
It's a great unit...
Old April 28th 07, 12:14 AM posted to rec.aviation.piloting
Newps
Erik wrote:
Because straight in approaches at an uncontrolled airport
disrupt the pattern that everyone is using. Perhaps if there
were no other traffic at the time, it would be perfectly fine
but when everyone is in line and doing their thing, someone
cutting in sucks. There is a fairly large municipal airport
nearby that accommodates jets and sometimes, we single engine
folk have to anticipate them, but it still disrupts things.
So you'll gladly adjust the size of your pattern, maybe extend an upwind
or crosswind to fit somebody in the pattern because he enters it the
'right' way. But if he tries to enter on a straight in it's disrupting
the pattern?
Interesting experience yesterday Paul Folbrecht Instrument Flight Rules 5 January 2nd 06 11:55 PM
"Interesting" wind yesterday Jay Honeck Piloting 36 March 10th 05 05:36 PM
A Moment of Thanks. Peter Maus Rotorcraft 1 December 30th 04 09:39 PM
Looking For W&B Using Arm Instead of Moment John T Piloting 13 November 1st 03 09:19 PM
Permit me a moment, please, to say... Robert Perkins Piloting 14 October 31st 03 03:43 PM
