Looking For W&B Using Arm Instead of Moment
Old October 30th 03, 12:41 PM
John T
Default Looking For W&B Using Arm Instead of Moment
I'm looking for an example of a W&B worksheet using CG arm values instead of
moment values. Basically, I'm curious to see how these are done and what
the worksheets look like.
Either online or emailed examples are acceptable.
Thanks!
John T
tknoflyer[remove] at hotmail[remove].com
http://tknowlogy.com/tknoFlyer
_______________
Old October 30th 03, 03:45 PM
John T
m
You can't do it with just an arm. You need the arm plus the weight.
And then your calculation is just going to multiply them together
(yielding the moment).
Yes, but recent readings suggested that my understanding my have
been...incomplete.
For instance, every W&B graph I've seen (Skyhawks, Skylanes, C150s,
Warriors, Katanas, Tomahawks - all under 35 years old) have shown this graph
using only weight/moment. All the sample loading problems I've seen have
all used moment instead of arm, too.
Recent readings revealed folks referencing balance by arm instead of
moment - something I'm not used to doing or reading. It raised the question
in my mind whether there are charts that use weight/arm instead of
weight/moment.
So that's the real question: Do such charts exist? If so, where can I take
a peek at one?
Thanks.
John T
__________
Old October 30th 03, 04:14 PM
Robert Moore
C150s, Warriors, Katanas, Tomahawks - all under 35 years old)
have shown this graph using only weight/moment. All the sample
loading problems I've seen have all used moment instead of arm,
too.
In those airplanes, the "arm" is generally fixed by the location
of the seats and bagage compartment. On the graphs, the upward
sloping lines each represent a different arm. Regardless of how
it is presented, a w/b calculation always involves weights and
arms. Moment is simply weight times the arm.
Bob Moore
Old October 30th 03, 04:52 PM
Ron Natalie
"John T" wrote in message ws.com...
Which graph are you talking about? The CG envelope itself is almost always
the CG position (arm) versus weight. The other graphs (where you follow the
weight out various lines for the different positions) are just computing the moment
(multiplying the arm for you). The cessna books give you the arms you can use
in lieu of these charts if you really want.
I'm sure you're confused. The CG point is always an arm. A moment tells
you NOTHING about the CG. A moment of 1000 could be 1000 pounds at the
datum or 1 pound 1000 units away from the datum. If you've computed the
moment, you divide that by the weight to get the arm.
weight/moment.
They all do. Googling for cg graph yeilds this page, which is quite representative
of just about every plane I've ever come accross...
http://www.eaa838.org/wtbal.htm
Old October 30th 03, 05:18 PM
Orval Fairbairn
In article om,
Thanks!
If you can use Excel, you can easily construct your own W&B worksheet.
Put the weight of each component in column "A", its arm in column "B",
its resultant moment in column "C".
All you have to do is multiply column "A" by column "B" in coulmn "C",
add the sum of columns "A" and "C", divide the sum of column "C" by the
sum of column "A" and you have the CG in column "B".
You can get better by adding fuel in gallons, converting it to lbs in
the weight computation, oil in qts, converting it, etc.
You can build pax/fuel loading scenarios and get a real handle on what's
going on.
It is really quite elementary.
A year ago I helped a retired AA captain build a W&B program for his
plane -- it really opened his eyes!
Old October 30th 03, 05:45 PM
Teacherjh
weight/moment.
Yes, such charts exist.
I take it you are referring to the "envelope" into which you n eed to fit.
I've seen it with weight plotted against CG (arm), which I prefer as it makes
the envelope fit better on the page, and I've seen it with weight plotted
against moment, (which makes a skinny sloping envelope) There are other ways
to represent the envelope too, but in all cases you need some term involving
weight plotted against some term involving arm. The "arm" term could be arm
(CG) itself, or moment, which is just armxweight. Whichever is used, I'll call
it "balance".
To get the final point, you still need to figure out the contribution to total
weight and total balance due to each factor (pilot, passenger, fuel, etc).
This is a simple multiplication, but a multplication can be represnted on
another graph by a sloping line. This is just the old algebra y=mx+b rearing
its friendly head again. The charts are designed to be compatible, so there's
a minimum of arithmetic involved.
It is actually possible to plot the contributions from each station as
gridlines on the same graph as the envelope, but the lines are curved if you
use arm for balance, and they are hard to distinguish from each other if you
use moment for balance. I did actually set a few up that way; it allows one to
figure out the weight and balance with no math whatsoever. But before I
finished the program to do that, I found CoPilot for the Palm, and that was
that.
Jose
Old October 30th 03, 06:18 PM
John T
Thanks, folks.
While I'll grant you that my math skills aren't nearly as polished as my
piloting skills, I did know that "weight * arm = moment".
The item I was looking for (included in Ron's helpful link) was a CG
envelope (thanks to Jose for the correct term) using arm instead of moment.
As I said, all the envelopes in the POHs I've used for the planes I've flown
have all used moment - not arm - in the graphical representation.
After seeing the graphic from Ron's link, I realize that I've seen similar
charts - just not in any of the POHs I've used.
Thanks again!
John T
__________
Old October 30th 03, 07:03 PM
Jim Weir
And not to belabor the point, what John wanted (and finally found) was the
good-old-days CG "box" instead of the dumbed-down parallelogram that Cessna
foisted on us starting around 1960. Seems that some marketing genius thought
that the flying public was too stupid to do a "real" weight and balance by doing
the multipication of weight*arm, adding the moments, and dividing by the total
weight to get the point of balance.
I started flying in '64, and it wasn't until I went for my A&P in '70 that I
ever saw (or used, for that matter) the good old box style CG method of
calculation.
"John T"
-Thanks, folks.
http://www.rst-engr.com
Old October 30th 03, 10:44 PM
Karl Medcalf
I wrote a weight & balance program some time ago that will display the
envelope either way. If you're interested in looking at it, you can
find it at http://users3.ev1.net/~medcalf/avinfo.html
As noted, I accept no liability for use of the program, as you are
still responsible to properly calculate weight & balance for your
specific plane.
Enjoy.
Thanks!
John T
_______________
Karl Medcalf - WK5M
PP-ASEL-IA (N43CS)
Old October 31st 03, 12:17 AM
Verbs Under My Gel
"John T" wrote in message ews.com...
Thanks!
Moment is the vector product of force (weight) and displacement
(distance, or "arm"), in other words, F X S
Flap Hinge Moment Calc Bo Home Built 2 February 2nd 05 10:26 AM
Flap Hinge Moment Calc Bo Home Built 0 February 2nd 05 06:01 AM
Permit me a moment, please, to say... Robert Perkins Piloting 14 October 31st 03 02:43 PM
