Glider definition (span^2/weight)
Old April 29th 07, 04:19 AM posted to rec.aviation.soaring
Bob C
Default Glider definition (span^2/weight)
A while back I read an FAA definition of a glider (as
opposed to an airplane). I think it was an FAA document
that referenced JAR 22. One of the criteria was a
span squared over weight number (S^2/W). I can't find
this document. Does this sound familiar to anyone?
Bob C.
Old April 29th 07, 04:32 AM posted to rec.aviation.soaring
Bob,
Here is the reference:
http://mysite.verizon.net/engreenwel...teria_2004.pdf
You have it backward it is Weight / span ^ 2 0.62
HP-14 "6F"
http://www.soaridaho.com/Schreder
"Bob C" wrote in message
Bob C.
Old April 29th 07, 05:05 AM posted to rec.aviation.soaring
Bob C
Thanks. I found it online about two minutes after
I posted the question. Advisory Circular 21.17-2A
Bob C.
At 03:36 29 April 2007, Wayne Paul wrote:
Bob,
http://mysite.verizon.net/engreenwel...r_criteria_200
4.pdf
You have it backward it is Weight / span ^ 2 wrote
in message
find
Bob C.
Old April 29th 07, 07:17 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Sat, 28 Apr 2007 21:32:47 -0600, "Wayne Paul"
Bob,
In other words, it's the wing loading.
rj
Old April 29th 07, 07:25 PM posted to rec.aviation.soaring
"Ralph Jones" wrote in message
Bob,
Ralph,
No, wing loading = weight / (span * MAC). Span loading does not consider
the wing's cord.
HP-14 "6F"
Old April 29th 07, 11:22 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Sun, 29 Apr 2007 12:25:49 -0600, "Wayne Paul"
Bob,
Ralph,
the wing's cord.
Oops, my bad.
rj
Old April 30th 07, 10:52 AM posted to rec.aviation.soaring
Al Eddie
Isn't a glider simply defined as an aircraft with no
motive power..?
Any aircraft can become a 'glider', whereas a sailplane
is a glider built specifically for soaring.
What a motorglider is, I have no idea...
;o)
Bob C.
There are only 10 types of people in the world. Those who understand Binary, and those who don't.
Old April 30th 07, 01:37 PM posted to rec.aviation.soaring
Al,
In the US formula is used to determine whether a fixed wing aircraft with an
engine is classified as a glider or as an airplane.
HP-14 "6F"
"Al Eddie" wrote in message
motive power..?
;o)
Bob C.
Old April 30th 07, 03:36 PM posted to rec.aviation.soaring
jettester
Boy, this is how years worth of misconceptions get started..
If you go to the FAA website http://www.FAA.gov and use the aircraft
certification site ... reference the FAR part 1 Definitions.
http://www.airweb.faa.gov/Regulatory...2572960077077A
page 8 states " Glider means a heavier - than - air aircraft, that is
supported in flight by the dynamic reaction of the air against its
lifting surfaces and whose free flight does not depend principally on
an engine."
The JAR 22 reference is a European reference.
CAR 3 is the old certification reference for the USA. I can't recall
any US gliders that have been certified recently. The Kansas City
Small Aircraft Directorate is in charge of that in the US. In fact,
when I started to register my ASW-20 they were going to register it as
an LSA (light Sport Aircraft) until I told then the top speed is
160K !
"Wing Loading"is Weight/Wing Area (typically ASW-20 is 110 sq ft
approx.)
"Span Loading" is the distribution of lift over the wing span, is
typically elliptical (ie. is the top part of an ellipse with the
greatest amount at the center, decreasing 'elliptically' to the tip).
Old April 30th 07, 05:25 PM posted to rec.aviation.soaring
Al Eddie[_2_]
At 12:42 30 April 2007, Wayne Paul wrote:
Al,
HP-14 '6F'
All very well but, when the engine(s) fail(s), no number
of formulae will ever determine that aircraft to be
anything other than a glider...
;o)
Glider definition (span^2/weight) Bob C Soaring 0 April 29th 07 04:19 AM
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): [email protected] Naval Aviation 0 January 27th 07 02:18 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Glider weight Miguel Lavalle Soaring 8 December 17th 03 03:00 PM
Subject: Glider weight Jim Culp Soaring 0 December 17th 03 05:11 AM
