Altimeter accuracy
Old May 4th 07, 01:17 AM posted to rec.aviation.owning
Jim Stewart
Default Altimeter accuracy
How close should an altimeter be to field elevation
when set to the pressure indicated by the field's
AWOS? I'm seeing a 50' error.
Old May 4th 07, 01:37 AM posted to rec.aviation.owning
karl gruber[_1_]
75'
"Jim Stewart" wrote in message
Old May 4th 07, 02:42 AM posted to rec.aviation.owning
Rip
+/- 75 feet for IFR
Rip
Old May 4th 07, 03:39 AM posted to rec.aviation.owning
Ron Rosenfeld
+/- 75 feet for IFR
Rip
It depends on your field elevation.
You should be able to check and see what the error was at the last
altimeter certification for IFR.
The tolerances, at the lower altitudes, a (Appendix E 14 CFR 43)
0 ±20'
500 ±20'
1000 ±20'
1500 ±25'
2000 ±30'
3000 ±30
4000 ±35
6000 ±40
8000 ±60
For a VFR only a/c, I do not believe there is any particular requirement.
--ron
Old May 5th 07, 06:37 PM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
What's the accuracy of the AWOS?
Geoff
Old May 7th 07, 08:53 PM posted to rec.aviation.owning
Jim Stewart
Glad you asked. I called some friends at Allweather
(which made the AWOS at my field) and they said the
units are factory calibrated to +/- 5 feet and that
FAA specifications are +/- 20 feet.
Geoff
Old May 7th 07, 09:41 PM posted to rec.aviation.owning
Jim Carter[_1_]
I think what you've cited is for bench testing during certification. Once
installed in the aircraft then comparison against the pressure as recorded
by the official weather observation is +/- 75'.
An interesting discussion point came up recently that exposed the difference
in teaching over the past 30 years. 30 years ago we were taught to set the
altimeter to the known field elevation and record the difference between the
official pressure and the indicated pressure, then apply that difference to
every setting you received along your route of flight.
Today they teach to set your altimeter to the official pressure and that's
it.
So my question becomes, when executing a precision approach to a minimum DH
of 200' and then executing the missed procedure, the aircraft is allowed to
descend slightly below the DH as things spool up. If you are already 75'
lower than you think because of altimeter error, and you descend only 20'
more (one gradient on the altimeter) aren't you really only 105' off the
deck?
Jim Carter
Rogers, Arkansas
"Ron Rosenfeld" wrote in message
+/- 75 feet for IFR
Rip
0 ±20'
500 ±20'
1000 ±20'
1500 ±25'
2000 ±30'
3000 ±30
4000 ±35
6000 ±40
8000 ±60
--ron
Old May 7th 07, 11:45 PM posted to rec.aviation.owning
Ron Rosenfeld
On Mon, 07 May 2007 20:41:13 GMT, "Jim Carter"
it.
deck?
I did cite the bench testing numbers, as they are the ones of which I am
aware.
I've heard of the 75' "allowance" for a field measurement, but I've not
seen a regulatory justification for that value. As someone who flies
instrument approaches to minimums, I, personally, would not be happy with a
75' error, and would have the system rechecked.
So far as you being only 105' off the deck in your hypothetical instance,
that is obviously the case.
By the way, for Category II operations, which may have a DH as low as
100'AGL, it is a requirement to have readily available the altimeter
calibration information from the last certification, (and to apply it
appropriately).
--ron
Old May 8th 07, 04:38 AM posted to rec.aviation.owning
Jim Carter[_1_]
Isn't a radar altimeter required equipment for CAT II and CAT III work? We
were trying to get an aircraft and aircrew certified for CAT II in Seattle
many years ago and I thought that was the reason they had the RA installed.
Jim Carter
Rogers, Arkansas
difference
to
it.
DH
to
deck?
aware.
a
appropriately).
--ron
Old May 8th 07, 12:01 PM posted to rec.aviation.owning
dave
I read somewhere on the web that your A&P can adjust your altimeter by
removing a pin or a screw that allows the barometric pressure to be set
independently from the altitude. Once it's set correctly, the pin or
screw is replaced.
Dave
Accuracy of GPS in Garmin 430/530 Will Instrument Flight Rules 110 May 29th 06 04:58 PM
GPS accuracy [email protected] Soaring 5 January 18th 05 06:29 PM
EGT Accuracy O. Sami Saydjari Owning 6 March 16th 04 10:53 PM
ILS instrument accuracy? Help...... TripFarmer Instrument Flight Rules 19 September 22nd 03 08:26 PM
gps altitude accuracy Martin Gregorie Soaring 12 July 18th 03 08:51 PM
