On Tue, 08 May 2007 03:38:30 GMT, "Jim Carter"
wrote: Isn't a radar altimeter required equipment for CAT II and CAT III work? We were trying to get an aircraft and aircrew certified for CAT II in Seattle many years ago and I thought that was the reason they had the RA installed. It is definitely not required for Category A aircraft flying under Part 91 for CAT II. I don't know about other categories. There was a period of time when I and my Mooney were CAT II qualified and certified. The inner marker can substitute for a radio altimeter for 100' DH. The RA is not necessary at all for the 150 DH. The altimeter and static system has to have had the IFR check within the past 12 months; and altimeter correction data must be available to the pilot, including both the scale error and, wheel height correction if the wheel to instrument height is greater than 10 feet. There are a very few CAT II approaches that require a RA for use of the 100' DH, because of absent or siting problems with the IM. I don't know of any guidance for Category A Part 91 a/c under CAT III, or if any authorizations have ever been issued for that. --ron |
![]() "Ron Rosenfeld" wrote in message ... On Tue, 08 May 2007 03:38:30 GMT, "Jim Carter" wrote: Isn't a radar altimeter required equipment for CAT II and CAT III work? We were trying to get an aircraft and aircrew certified for CAT II in Seattle many years ago and I thought that was the reason they had the RA installed. It is definitely not required for Category A aircraft flying under Part 91 for CAT II. I don't know about other categories. There was a period of time when I and my Mooney were CAT II qualified and certified. The inner marker can substitute for a radio altimeter for 100' DH. The RA is not necessary at all for the 150 DH. The altimeter and static system has to have had the IFR check within the past 12 months; and altimeter correction data must be available to the pilot, including both the scale error and, wheel height correction if the wheel to instrument height is greater than 10 feet. There are a very few CAT II approaches that require a RA for use of the 100' DH, because of absent or siting problems with the IM. I don't know of any guidance for Category A Part 91 a/c under CAT III, or if any authorizations have ever been issued for that. --ron Ron is correct. We once had a 182 and pilot approved for the 150' DH for fog seeding. Al G |
dave wrote:
I read somewhere on the web that your A&P can adjust your altimeter by removing a pin or a screw that allows the barometric pressure to be set independently from the altitude. Once it's set correctly, the pin or It's under warranty and the dealer says his A&P can't break the seal. screw is replaced. Dave Jim Stewart wrote: How close should an altimeter be to field elevation when set to the pressure indicated by the field's AWOS? I'm seeing a 50' error. |
On May 7, 2:41 pm, "Jim Carter" wrote:
I think what you've cited is for bench testing during certification. Once installed in the aircraft then comparison against the pressure as recorded by the official weather observation is +/- 75'. The installed altimeter should give the same reading error on the ground as it did on the bench unless the static system is way out of whack, in which case the airplane shouldn't be flown. The Canadian specs for scale error are he http://www.tc.gc.ca/civilaviation/Re...ds/t571s02.htm Dan |
On Tue, 8 May 2007 09:03:07 -0700, "Al G" wrote:
We once had a 182 and pilot approved for the 150' DH for fog seeding. That wouldn't happen to have been in Medford, OR? --ron |
![]() "Ron Rosenfeld" wrote in message ... On Tue, 8 May 2007 09:03:07 -0700, "Al G" wrote: We once had a 182 and pilot approved for the 150' DH for fog seeding. That wouldn't happen to have been in Medford, OR? --ron *Ding*, We have a winner! It was indeed. United Airlines hired us to "Clear it up". $15/hr for Night/Single Engine/IFR below minimums. My wife later bought me some "Small Flowers" from Wal-Mart, so I would always have "Mini-Mums". ![]() Al G |
On Wed, 9 May 2007 09:45:04 -0700, "Al G" wrote:
"Ron Rosenfeld" wrote in message .. . On Tue, 8 May 2007 09:03:07 -0700, "Al G" wrote: We once had a 182 and pilot approved for the 150' DH for fog seeding. That wouldn't happen to have been in Medford, OR? --ron *Ding*, We have a winner! It was indeed. United Airlines hired us to "Clear it up". $15/hr for Night/Single Engine/IFR below minimums. My wife later bought me some "Small Flowers" from Wal-Mart, so I would always have "Mini-Mums". ![]() Al G I have waited many an early morning for the fog to clear. (Our kids used to live in Ashland). Once or twice I noted the Cessna taking off, when the commercial jets couldn't land. --ron |
![]() "Ron Rosenfeld" wrote in message ... On Wed, 9 May 2007 09:45:04 -0700, "Al G" wrote: "Ron Rosenfeld" wrote in message . .. On Tue, 8 May 2007 09:03:07 -0700, "Al G" wrote: We once had a 182 and pilot approved for the 150' DH for fog seeding. That wouldn't happen to have been in Medford, OR? --ron *Ding*, We have a winner! It was indeed. United Airlines hired us to "Clear it up". $15/hr for Night/Single Engine/IFR below minimums. My wife later bought me some "Small Flowers" from Wal-Mart, so I would always have "Mini-Mums". ![]() Al G I have waited many an early morning for the fog to clear. (Our kids used to live in Ashland). Once or twice I noted the Cessna taking off, when the commercial jets couldn't land. --ron The conditions had to be just right. 25-31 degrees F, and the heavier the fog the better. We would fly a 150' pass, and dribble about a 1/2 pound of crushed dry ice over the centerline, making several passes. Within 5 minutes, it was snowing. Within 15-20, most of the fog was on the ground, and RVR's went from -600 to 6000. The 182 would build ice while doing the low passes, but the normal 90-270 was done above pattern altitude where it was 40 F and the ice would leave. We had an "Unofficial" backcourse/Loc only with a 150' DH as well. The Loc/Dme was at the far end of MFR's 14 ILS, so it gave us a distance to the approach end of our backcourse. We figured if the engine went, we would just keep the energy up and shoot one of the approaches. We actually did this under the hood for practice, and I once did it with the GADO inspector who authorized me, on board. Sounds pretty dumb now. At the time it was just like going out for touch & go's, except you couldn't see anything outside. Al G |
"dave" wrote in message
. .. I read somewhere on the web that your A&P can adjust your altimeter by removing a pin or a screw that allows the barometric pressure to be set independently from the altitude. Once it's set correctly, the pin or screw is replaced. Dave Not legally. Adjustment of an altimeter in this manner is considered a calibration. Calibration of instruments is considered a major repair and A&P mechanics are prohibited from performing repairs (minor or major) to instruments. In addition, the data correspondance between the altimeter and encoder (if equipped) would be nullified and require retesting by an appropriately-rated repair station. Mike |
Accuracy of GPS in Garmin 430/530 | Will | Instrument Flight Rules | 110 | May 29th 06 04:58 PM |
GPS accuracy | [email protected] | Soaring | 5 | January 18th 05 06:29 PM |
EGT Accuracy | O. Sami Saydjari | Owning | 6 | March 16th 04 10:53 PM |
ILS instrument accuracy? Help...... | TripFarmer | Instrument Flight Rules | 19 | September 22nd 03 08:26 PM |
gps altitude accuracy | Martin Gregorie | Soaring | 12 | July 18th 03 08:51 PM |
