#21
"P & H Macguire" wrote in news:yFe1i.14160$8E.416
@newsfe5-win.ntli.net: I am in the process of scanning some old slides of 60s to 90s and wondered what the optimum size should be for posting on this N/G. They will be scanned at about 300dpi. Regards PJM Okay. To be technical, DPI is a printing resolution, and you cannot scan at that. This is nit-picky, because the actual term for scanning resolution is PPI (pixels per inch), and most people use them interchangeably, but there is a difference. For scanning slides, start at max resolution and try working backwards on the sharpest slides, watching the differences carefully at 100% in your image editing program. This will largely appear to be blotches of indistinct color, but you can see whether the higher resolutions make any difference to your slides. Super sharp slides may benefit from scanning at 2400 PPI or higher, but film grain, lens quality, and steadiness of the photographer all play a part, and pics of lesser quality may not show any improvement between 1200 PPI and 2400 PPI because, quite simply, the resolution isn't there in the film. For scanning prints, you typically will not pull up much, if any, detail beyond 300 PPI. Magazine prints can typically go lower, but scanning at a higher res with the page at a slight angle helps correct for screening (moire) patterns, and the pic can be straightened after scanning in your editing program. I have never discerned any difference between saving in TIFF (lossless) format and highest quality JPEG, except for the tremendous savings in file size - this, mind you, is for the original scan. Archive off the original scans and back them up - you never know when a slide will get damaged or disappear. And always work on a copy. There's nothing more frustrating than hitting "Save" instead of "Save As..." and overwriting your original scan. As for display resolution, you can ignore DPI entirely - it means absolutely nothing to the monitor or display. My vote goes for 1024x768 pixels or smaller, because I'm one of those miserly people who maintains that as a monitor resolution. Larger just means scrolling, and that detracts from the affect of the shot, especially if you're the type to frame a shot carefully. JPEG compression seems to work just fine at between 50% and 80% quality (100 being full quality, not compressed) - it depends on, not the detail of the shot, but the gradients, which is where jpeg compression has its first affects. If you see your skies becoming blocky in places, increase quality. Sharpening should be done sparingly, if at all. If you see halos or fringing occurring along areas of high contrast, you're sharpening too much. More info than you asked for: DPI is considered a printing resolution, but most printers nowadays ignore it entirely and simply interpolate what is needed from the final print size you indicate. Even the home inkjets will print far more than 300 dots per inch, but this is because they have to make a 16 million color gamut from 6 ink colors or less, and have to layer in multiple tiny ink dots to give the impression of a field of clear Prussian Blue. About the only place I've seen DPI make any difference whatsoever has been when you're laying text in over the image (like a copyright mark). Photoshop, at least, judges font size on the DPI resolution, so pick one and stay with it. It can be 1 DPI if you like, and the file info may consider your pic to be a thousand inches wide, but it'll still display one pixel per pixel on a monitor at 100%. 300 and 72 DPI are the defaults, and either one works fine. Information like that is ignored by both browsers and monitors, which only work from the pixel dimensions. And in fact, even for web pages, the photo displays at the pixel dimensions specified in the html, which may not be the pixel dimensions of the jpeg file. Lots of novice web designers cause huge page loading delays because they take a jpeg way too large for the web and "size it" in the html. All it means is a large file takes time loading just to display at a res that it could have been sized to in the first place. - Al. -- To reply, insert dash in address to separate G and I in the domain |
![]() "Al Denelsbeck" wrote in message .128... "P & H Macguire" wrote in news:yFe1i.14160$8E.416 @newsfe5-win.ntli.net: And in fact, even for web pages, the photo displays at the pixel dimensions specified in the html, which may not be the pixel dimensions of the jpeg file. Lots of novice web designers cause huge page loading delays because they take a jpeg way too large for the web and "size it" in the html. All it means is a large file takes time loading just to display at a res that it could have been sized to in the first place. - Al. -- To reply, insert dash in address to separate G and I in the domain Again, thanks to everybody for these very full and interesting replies. I had no idea I was going to stir up such a hornet's nest! Regards PJM |
![]() "octothorpe" wrote in message news:CVm1i.6994$cu1.1851@trnddc01... "Dave Kearton" wrote in message ... The Old Bloke wrote: "octothorpe" wrote in message news:mJg1i.5118$3B5.4926@trnddc08... "Luke" wrote in message ... "P & H Macguire" wrote in message ... I am in the process of scanning some old slides of 60s to 90s and wondered what the optimum size should be for posting on this N/G. They will be scanned at about 300dpi. 640X480 is a dandy size for initial viewing. If folks want larger prints for wallpaper or suck they will ask. They are never shy. Luke May I add that the size that you suggested should be at ~72 dpi resolution to keep the file size smaller for the web. Monitors cannot display the 300 dpi res any better than the 72 dpi res. The 300 is good for printing. Tom For qualty retention 4800X4800 is needed. Don't listen to him, he's from the dark side (by the way Luke, he's your father) Dave, just what is that rubbish supposed to mean? Tom Someone is not a Jedi... :-( Peter |
![]() "Lynn Coffelt" wrote in message . .. "Terry M" wrote in message m... I prefer 800x600 or larger. Most of us have monitors set at that size or larger. Using any smaller gives just that - a very small picture. The 640x480 size was for very old monitors - hardly anyone has their monitor set at that resolution since monitors have physically grown in size. "P & H Macguire" wrote in message ... I am in the process of scanning some old slides of 60s to 90s and wondered what the optimum size should be for posting on this N/G. They will be scanned at about 300dpi. Regards PJM If one is going to benefit from old slide and negative resolution, scan at the highest resolution your system can handle. Some amazing detail is available in some of them. Store or archive them in that highest resolution. Store on CD or DVD disks. Then when one wants to post to newsgroups or internet sites, you can downsize copies for posting if that's what your intended viewers want. BUT, keeping the high resolution scans makes it possible to clip out portions of the original picture, magnify the clips and find great history in the details! For the record, I usually do not follow my own good sense advise. Old Chief Lynn It also keeps the old scans usefull with future monitors for a longer time. Don't ask me how I know. :-( Peter |
![]() "Pjmac35" wrote in message ... Again, thanks to everybody for these very full and interesting replies. I had no idea I was going to stir up such a hornet's nest! Hornet's nest? good lord man, this is no hornet's nest. This is simply a thread that got a few replies. You want to see some "hornet's nests", check out some of the lengthy and vitriolic thread in alt.binaries.pictures.military, or even alt.binaries.pictures.motorcycles.harley. Them's some hornet's nests... BTW, welcome to the group. Luke |
Of course that's an F-18 Hornet's nest. |
Pjmac35 wrote:
"Al Denelsbeck" wrote in message .128... "P & H Macguire" wrote in news:yFe1i.14160$8E.416 @newsfe5-win.ntli.net: And in fact, even for web pages, the photo displays at the pixel dimensions specified in the html, which may not be the pixel dimensions of the jpeg file. Lots of novice web designers cause huge page loading delays because they take a jpeg way too large for the web and "size it" in the html. All it means is a large file takes time loading just to display at a res that it could have been sized to in the first place. - Al. -- To reply, insert dash in address to separate G and I in the domain Again, thanks to everybody for these very full and interesting replies. I had no idea I was going to stir up such a hornet's nest! Regards PJM Which hornet was that? -- Moving things in still pictures! |
#28
![]() "shiver" wrote in message ... I had no idea I was going to stir up such a hornet's nest! Of course that's an F-18 Hornet's nest. No! A De Havilland Hornet of course! Regards PJM |
#29
Lynn Coffelt wrote:
"Terry M" wrote in message m... I prefer 800x600 or larger. Most of us have monitors set at that size or larger. Using any smaller gives just that - a very small picture. The 640x480 size was for very old monitors - hardly anyone has their monitor set at that resolution since monitors have physically grown in size. "P & H Macguire" wrote in message ... I am in the process of scanning some old slides of 60s to 90s and wondered what the optimum size should be for posting on this N/G. They will be scanned at about 300dpi. Regards PJM If one is going to benefit from old slide and negative resolution, scan at the highest resolution your system can handle. Some amazing detail is available in some of them. Store or archive them in that highest resolution. Store on CD or DVD disks. Then when one wants to post to newsgroups or internet sites, you can downsize copies for posting if that's what your intended viewers want. BUT, keeping the high resolution scans makes it possible to clip out portions of the original picture, magnify the clips and find great history in the details! For the record, I usually do not follow my own good sense advise. Old Chief Lynn ...and you are not alone in that! -- Moving things in still pictures! |
#30
at the highest resolution your system can handle. Some amazing detail is available in some of them. Store or archive them in that highest resolution. Store on CD or DVD disks. Then when one wants to post to newsgroups or internet sites, you can downsize copies for posting if that's what your intended viewers want. BUT, keeping the high resolution scans makes it possible to clip out portions of the original picture, magnify the clips and find great history in the details! What he said, plus... Make certain that you save the file in .tif format. When you resize for posting the web, save that image as a .jpg. |
O/A welding question: tip size | mhorowit | Home Built | 25 | July 11th 06 03:22 AM |
What size hole saw do I use? | [email protected] | Home Built | 22 | July 16th 05 08:21 AM |
Cockpit size of Libelle? | Kevin Morris | Soaring | 4 | July 15th 04 11:32 PM |
Size does matter | HECTOP | Piloting | 59 | May 13th 04 11:48 PM |
LS4 - LS6 Fuselage size | Mark | Soaring | 15 | November 3rd 03 03:47 AM |
