Picture size
Old May 13th 07, 05:55 AM posted to alt.binaries.pictures.aviation
Al Denelsbeck
Default Picture size
"P & H Macguire" wrote in news:yFe1i.14160$8E.416
@newsfe5-win.ntli.net:
I am in the process of scanning some old slides of 60s to 90s and
wondered what the optimum size should be for posting on this N/G.
They will be scanned at about 300dpi.
Regards
PJM
Okay.
To be technical, DPI is a printing resolution, and you cannot scan
at that. This is nit-picky, because the actual term for scanning
resolution is PPI (pixels per inch), and most people use them
interchangeably, but there is a difference.
For scanning slides, start at max resolution and try working
backwards on the sharpest slides, watching the differences carefully at
100% in your image editing program. This will largely appear to be
blotches of indistinct color, but you can see whether the higher
resolutions make any difference to your slides. Super sharp slides may
benefit from scanning at 2400 PPI or higher, but film grain, lens
quality, and steadiness of the photographer all play a part, and pics of
lesser quality may not show any improvement between 1200 PPI and 2400 PPI
because, quite simply, the resolution isn't there in the film.
For scanning prints, you typically will not pull up much, if any,
detail beyond 300 PPI. Magazine prints can typically go lower, but
scanning at a higher res with the page at a slight angle helps correct
for screening (moire) patterns, and the pic can be straightened after
scanning in your editing program.
I have never discerned any difference between saving in TIFF
(lossless) format and highest quality JPEG, except for the tremendous
savings in file size - this, mind you, is for the original scan. Archive
off the original scans and back them up - you never know when a slide
will get damaged or disappear. And always work on a copy. There's nothing
more frustrating than hitting "Save" instead of "Save As..." and
overwriting your original scan.
As for display resolution, you can ignore DPI entirely - it means
absolutely nothing to the monitor or display. My vote goes for 1024x768
pixels or smaller, because I'm one of those miserly people who maintains
that as a monitor resolution. Larger just means scrolling, and that
detracts from the affect of the shot, especially if you're the type to
frame a shot carefully.
JPEG compression seems to work just fine at between 50% and 80%
quality (100 being full quality, not compressed) - it depends on, not the
detail of the shot, but the gradients, which is where jpeg compression
has its first affects. If you see your skies becoming blocky in places,
increase quality.
Sharpening should be done sparingly, if at all. If you see halos or
fringing occurring along areas of high contrast, you're sharpening too
much.
More info than you asked for:
DPI is considered a printing resolution, but most printers nowadays
ignore it entirely and simply interpolate what is needed from the final
print size you indicate. Even the home inkjets will print far more than
300 dots per inch, but this is because they have to make a 16 million
color gamut from 6 ink colors or less, and have to layer in multiple tiny
ink dots to give the impression of a field of clear Prussian Blue.
About the only place I've seen DPI make any difference whatsoever
has been when you're laying text in over the image (like a copyright
mark). Photoshop, at least, judges font size on the DPI resolution, so
pick one and stay with it. It can be 1 DPI if you like, and the file info
may consider your pic to be a thousand inches wide, but it'll still
display one pixel per pixel on a monitor at 100%. 300 and 72 DPI are the
defaults, and either one works fine. Information like that is ignored by
both browsers and monitors, which only work from the pixel dimensions.
And in fact, even for web pages, the photo displays at the pixel
dimensions specified in the html, which may not be the pixel dimensions
of the jpeg file. Lots of novice web designers cause huge page loading
delays because they take a jpeg way too large for the web and "size it"
in the html. All it means is a large file takes time loading just to
display at a res that it could have been sized to in the first place.
- Al.
To reply, insert dash in address to separate G and I in the domain
Old May 13th 07, 09:11 AM posted to alt.binaries.pictures.aviation
Pjmac35
"Al Denelsbeck" wrote in message
.128...
dimensions
loading
it"
place.
- Al.
Again, thanks to everybody for these very full and interesting
replies. I had no idea I was going to stir up such a hornet's nest!
Regards
PJM
Old May 13th 07, 02:02 PM posted to alt.binaries.pictures.aviation
Peter Dohm
"octothorpe" wrote in message
news:CVm1i.6994$cu1.1851@trnddc01...
"Dave Kearton" wrote in message
news:mJg1i.5118$3B5.4926@trnddc08...
"Luke" wrote in message
"P & H Macguire" wrote in message
640X480 is a dandy size for initial viewing. If folks want
larger prints for wallpaper or suck they will ask. They are never
shy.
Luke
May I add that the size that you suggested should be at ~72 dpi
resolution to keep the file size smaller for the web. Monitors
cannot display the 300 dpi res any better than the 72 dpi res. The
300 is good for printing.
Tom
For qualty retention 4800X4800 is needed.
Don't listen to him, he's from the dark side (by the way Luke, he's
your
father)
Dave, just what is that rubbish supposed to mean?
Tom
Someone is not a Jedi... :-(
Peter
Old May 13th 07, 02:07 PM posted to alt.binaries.pictures.aviation
Peter Dohm
"Lynn Coffelt" wrote in message
"Terry M" wrote in message
m...
I prefer 800x600 or larger. Most of us have monitors set at that size
or
larger. Using any smaller gives just that - a very small picture. The
640x480 size was for very old monitors - hardly anyone has their monitor
set
at that resolution since monitors have physically grown in size.
wondered
what the optimum size should be for posting on this N/G. They will be
Regards
PJM
If one is going to benefit from old slide and negative resolution,
scan
at the highest resolution your system can handle. Some amazing detail is
available in some of them. Store or archive them in that highest
resolution.
Store on CD or DVD disks. Then when one wants to post to newsgroups or
internet sites, you can downsize copies for posting if that's what your
intended viewers want. BUT, keeping the high resolution scans makes it
possible to clip out portions of the original picture, magnify the clips
and
find great history in the details!
For the record, I usually do not follow my own good sense advise.
Old Chief Lynn
It also keeps the old scans usefull with future monitors for a longer time.
Don't ask me how I know. :-(
Peter
Old May 13th 07, 04:30 PM posted to alt.binaries.pictures.aviation
Luke
"Pjmac35" wrote in message
Again, thanks to everybody for these very full and interesting replies. I
Hornet's nest? good lord man, this is no hornet's nest. This is simply
a thread that got a few replies. You want to see some "hornet's nests",
check out some of the lengthy and vitriolic thread in
alt.binaries.pictures.military, or even
alt.binaries.pictures.motorcycles.harley. Them's some hornet's nests...
BTW, welcome to the group.
Luke
Old May 13th 07, 08:27 PM posted to alt.binaries.pictures.aviation
Shiver
Of course that's an F-18 Hornet's nest.
Old May 13th 07, 08:51 PM posted to alt.binaries.pictures.aviation
®i©ardo
.128...
dimensions
loading
it"
place.
- Al.
Regards
PJM
Which hornet was that?
Moving things in still pictures!
  #28
Old May 13th 07, 09:05 PM posted to alt.binaries.pictures.aviation
Pjmac35
"shiver" wrote in message
No! A De Havilland Hornet of course!
Regards
PJM
  #29
Old May 14th 07, 11:43 AM posted to alt.binaries.pictures.aviation
®i©ardo
m...
I prefer 800x600 or larger. Most of us have monitors set at that size or
set
wondered
Regards
PJM
If one is going to benefit from old slide and negative resolution, scan
available in some of them. Store or archive them in that highest resolution.
possible to clip out portions of the original picture, magnify the clips and
Old Chief Lynn
...and you are not alone in that!
  #30
Old May 17th 07, 01:19 AM posted to alt.binaries.pictures.aviation
john smith[_2_]
What he said, plus...
Make certain that you save the file in .tif format.
When you resize for posting the web, save that image as a .jpg.
O/A welding question: tip size mhorowit Home Built 25 July 11th 06 03:22 AM
What size hole saw do I use? [email protected] Home Built 22 July 16th 05 08:21 AM
Cockpit size of Libelle? Kevin Morris Soaring 4 July 15th 04 11:32 PM
Size does matter HECTOP Piloting 59 May 13th 04 11:48 PM
LS4 - LS6 Fuselage size Mark Soaring 15 November 3rd 03 03:47 AM
