Anyone have Tips, tricks & notes on a C-170B
Old June 1st 07, 04:36 PM posted to rec.aviation.piloting
Al G[_2_]
Default Anyone have Tips, tricks & notes on a C-170B
Hi Gang,
In the next couple of weeks I'll be working with a fellow to finish his
private in a C-170B. Does anyone have any notes, tricks, or gotchas I should
know about? I have taildragger time in everything from a Quickie to a
Lodestar, but haven't flown the 170 for 28 years.
Al G
Old June 1st 07, 04:40 PM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
"Al G" wrote in
Hi Gang,
finish his
should know about? I have taildragger time in everything from a
Quickie to a Lodestar, but haven't flown the 170 for 28 years.
As straightforward as they come.
Remember the old C 145 ices easily, of course.
has the big flaps as well, but it's the same as a 172 as far as that goes.
Bertie
Old June 1st 07, 05:03 PM posted to rec.aviation.piloting
Jim Burns[_2_]
One of my partners in our Aztec owns a 170B, I've got a couple dozen hours
in the right seat.
Spring gear, so watch that final 2-3 feet of your decent, especially if you
have large tires and it hasn't been upgraded to C180 legs. Power is your
friend while taxiing. Plan and anticipate. Keep your feet moving.
"Al G" wrote in message
Hi Gang,
his
should
Al G
Old June 1st 07, 08:13 PM posted to rec.aviation.piloting
Boeing NNTP News Access
On Fri, 1 Jun 2007 08:36:50 -0700, "Al G"
Hi Gang,
Al G
WIth full fuel, an C-145 powered C-170 is a two place airplane.
Other than that, I can't think of anything bad to say about the 170
(owned a B model for 4 years and put 700 hours on it in that
time frame).
As far as the spring steel gear goes, no problem but your butt
and eyeballs do have to figure out where the bottom of those tires are
while landing.... 8^)
Now that I think about it, the only other gotcha I'd watch for is
mis-aligned main gear which could lead to twitchy handling
during takeoffs and landings... (mine was way off when I bought it,
but once the gear alignment was sorted out, it was a pussy cat
on the ground).
Bela P. Havasreti
Old June 1st 07, 08:32 PM posted to rec.aviation.piloting
john smith[_2_]
in the right seat.
You will want to wheel land it, slightly tail low. Some have a tendency
to oil-can if you are going too fast when the tail is put on the ground.
Old June 2nd 07, 04:44 AM posted to rec.aviation.piloting
Luke Skywalker
On Jun 1, 10:36 am, "Al G" wrote:
Hi Gang,
Al G
Hello Al.
Some pretty good suggestions here.
I assume that you are not having to do basic taildragger instruction
since he is "finishing" his private. The hardest thing I found was to
get people to see the landing attitude for a "wheel landing"...
You should have a blast. I have not flown a Cessna tailwheeler that
was not just a fine good time.
Robert
Old June 4th 07, 06:47 PM posted to rec.aviation.piloting
Al G[_2_]
"Luke Skywalker" wrote in message
s.com...
Hi Gang,
his
should
Al G
Hello Al.
Robert
I did have a blast. It is a really nice little A/c. He has redone the
interior in leather, and added a new radio and transponder.
The attitude was a shock. The 170 cowling is very low, and gives the
impression of a nose low attitude when straight and level. Visibility is
excellent.
Yes, the gear is quite springy, even soft. It seems there might be even be
some main wheel alignment issues occurring when up on the mains and
depressing the gear.
The fellow's attitude toward learning is great. He is an A & P, and a
pleasure to fly with.
Al G
Autogas Tips and Tricks Al[_2_] Piloting 46 May 4th 07 11:54 AM
MoGas Tips, Tricks, Concerns, How To Al Gilson Owning 129 May 17th 06 08:20 PM
KX-170B vs GNS 430?? Robert M. Gary Piloting 8 January 23rd 05 10:05 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
KX 170B/KX 170 JimM Home Built 0 October 29th 03 07:05 PM
