#151
Steven P. McNicoll wrote:
"Mark T. Dame" wrote in message ... That's the key, the way I read it. Traffic flying the full recommended pattern has the right of way of traffic not flying the full pattern. That includes those making base leg entries, straight into downwind entries, and straight in approaches (both visual and instrument, be it practice or actual). (All of that assumes the airport is above the VFR minimums. If it isn't, then IFR rules apply and "right of way" is theoretically a non-issue because ATC handle sequencing the departures and arrivals.) The airport can be above VFR minimums but still require an instrument approach, imagine good visibility under a low overcast. What's an arriving IFR aircraft supposed to do if he's still in cloud at the circling MDA and there are VFR aircraft in the pattern? While I suppose that's possible, to be VFR, the ceiling at the airport should be at least a 1,000' (500' above the ground and 500' below the clouds). All the non-precision approaches I'm familiar with have an MDA lower than that. Finally, there is no FAR one way or the other. Just the AC and the ASF publication. Bottom line: the traffic pattern is no place for a ****ing contest. Just be courteous to those around you and pay attention for those who aren't. FAR 91.113(g) does not exist? Where the hell do you get your information? FAR 91.113(g) only says that the aircraft on final has the right of way. It doesn't say anything about the pattern. It also doesn't say anything about other aircraft having to wait for a guy on a ten mile final to land before they can. Look at it this way. If you are in a car at a stop sign at an intersection. The crossing street has no stop sign. Cars on the crossing street have the right of way over cars at the stop sign. If you see a car coming a half a mile away, you don't have to wait for him. If he's 100' away, you do. Right of way only comes into play for conflict resolution. If there is no conflict, there's no right of way decision to make. -m -- ## Mark T. Dame ## CP-ASEL, AGI ## insert tail number here ## KHAO, KISZ "A brute force solution that works is better than an elegant solution that doesn't work." |
#152
Mark T. Dame wrote:
Steven P. McNicoll wrote: "Mark T. Dame" wrote in message ... That's the key, the way I read it. Traffic flying the full recommended pattern has the right of way of traffic not flying the full pattern. That includes those making base leg entries, straight into downwind entries, and straight in approaches (both visual and instrument, be it practice or actual). (All of that assumes the airport is above the VFR minimums. If it isn't, then IFR rules apply and "right of way" is theoretically a non-issue because ATC handle sequencing the departures and arrivals.) The airport can be above VFR minimums but still require an instrument approach, imagine good visibility under a low overcast. What's an arriving IFR aircraft supposed to do if he's still in cloud at the circling MDA and there are VFR aircraft in the pattern? While I suppose that's possible, to be VFR, the ceiling at the airport should be at least a 1,000' (500' above the ground and 500' below the clouds). All the non-precision approaches I'm familiar with have an MDA lower than that. I didn't finish my thought: If you are on a precision approach in those conditions, you will be at least 2.5 miles out when you break out (on a steep glideslope). Normally you will be more than 3 miles out. In either type of approach, you have plenty of time circle to land if the pattern is full. So, if there is VFR traffic in the pattern, an arriving IFR plane has time to transition to VFR and join the pattern without disrupting the flow. If conditions are so bad that the arriving aircraft can't transition in time, then it's unlikely that the airport is VFR legal anyway. -m -- ## Mark T. Dame ## CP-ASEL, AGI ## insert tail number here ## KHAO, KISZ "For example, no book or "owner's manual" will help you understand why your 3 year-old daughter rubs toothpaste in your 1 year-old's hair, or why your children hang their socks in the refrigerator." -- Advanced C++, James O. Coplien |
#153
On Fri, 01 Jun 2007 12:33:49 -0400, "Mark T. Dame"
wrote in : While I suppose that's possible, to be VFR, the ceiling at the airport should be at least a 1,000' (500' above the ground and 500' below the clouds). Have you overlooked the fact that many, if not most, non-towered airports lie within Class G airspace (by virtue of the magenta vignette or not), so according to CFR 14 Part 91 §91.155(a) http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=5edda206c78deab73d9b786f00376b88&rg n=div5&view=text&node=14:2.0.1.3.10&idno=14#14:2.0 .1.3.10.2.5.33 one is required to only remain clear of clouds during daylight hours (not 500' below)? Further, CFR 14 Part 91 §91.155(b)(2) Airplane. If the visibility is less than 3 statute miles but not less than 1 statute mile during night hours and you are operating in an airport traffic pattern within 1/2 mile of the runway, you may operate an airplane, powered parachute, or weight-shift-control aircraft clear of clouds. |
#154
![]() "Mark T. Dame" wrote in message ... While I suppose that's possible, to be VFR, the ceiling at the airport should be at least a 1,000' (500' above the ground and 500' below the clouds). All the non-precision approaches I'm familiar with have an MDA lower than that. A ceiling less 1000 feet puts the field below VFR minimums only if it's in a surface area. Most uncontrolled fields are in Class G airspace where VFR minimums for airplanes are just one mile visibility and clear of clouds. FAR 91.113(g) only says that the aircraft on final has the right of way. It doesn't say anything about the pattern. Correct, "pattern" does not appear anywhere in the right-of-way rules. It also doesn't say anything about other aircraft having to wait for a guy on a ten mile final to land before they can. Correct. Right-of-way should not be an issue in that case. Look at it this way. If you are in a car at a stop sign at an intersection. The crossing street has no stop sign. Cars on the crossing street have the right of way over cars at the stop sign. If you see a car coming a half a mile away, you don't have to wait for him. If he's 100' away, you do. Right of way only comes into play for conflict resolution. If there is no conflict, there's no right of way decision to make. Correct. I've used similar scenarios myself to explain the right-of-way rule. |
#155
![]() "Mark T. Dame" wrote in message ... I didn't finish my thought: If you are on a precision approach in those conditions, you will be at least 2.5 miles out when you break out (on a steep glideslope). Normally you will be more than 3 miles out. In either type of approach, you have plenty of time circle to land if the pattern is full. Nope. Remember, the ceiling is below the circling MDA. So, if there is VFR traffic in the pattern, an arriving IFR plane has time to transition to VFR and join the pattern without disrupting the flow. If conditions are so bad that the arriving aircraft can't transition in time, then it's unlikely that the airport is VFR legal anyway. Nope, VFR legal require just one mile visibility. |
#156
less than 3 statute miles but not less than 1 statute mile during night hours and you are operating in an airport traffic pattern within 1/2 mile of the runway, you may operate an airplane, powered parachute, or weight-shift-control aircraft clear of clouds. Would this permit departing an airport, remaining clear of clouds within half a mile of the airport, while climbing or maneuvering to an otherwise legal VFR position? This could be useful if there are broken low clouds over an otherwise clearing and VFR area, such as just after a storm has passed. Jose -- There are two kinds of people in the world. Those that just want to know what button to push, and those that want to know what happens when they push the button. for Email, make the obvious change in the address. |
#157
![]() "Steven P. McNicoll" wrote in message link.net... "Maxwell" wrote in message m... Why does the aircraft on final have the right-of-way? Primarily because FAR 91.113(g) says aircraft on final have the right-of-way. Agreed. But AC 90-66 describes "final" as the segment between base leg and the runway. Paragraph 7e clearly states that pilots executing a "straight-in approach", without mentioning reason for the straight-in approach, will complete it without disrupting arriving traffic. |
#158
![]() "Steven P. McNicoll" wrote in message hlink.net... "Maxwell" wrote in message m... I don't know, I'm just posting the info Steven was looking for and how it reads to me. I actually found this by accident while doing an unrelated Goggle search. Steven wasn't looking for the info, Steven has all the info. Or just thinks he does. The way I read it you can still do most any kind of approach as long as you don't disrupt normal traffic in the pattern. But the way I read it, with regards to right of way, traffic using the rectangular pattern listed in the AIM is said to be favored. Instead of concentrating on material that is not regulatory you might consider examining some material that is. I suggest FARs 91.113 and 91.126 for starters. Nothing in either of those FARs indicates you can describe "final" as being farther away from the airport than the end of "base leg". |
#159
![]() "Steven P. McNicoll" wrote in message link.net... "Mark T. Dame" wrote in message ... That's the key, the way I read it. Traffic flying the full recommended pattern has the right of way of traffic not flying the full pattern. That includes those making base leg entries, straight into downwind entries, and straight in approaches (both visual and instrument, be it practice or actual). (All of that assumes the airport is above the VFR minimums. If it isn't, then IFR rules apply and "right of way" is theoretically a non-issue because ATC handle sequencing the departures and arrivals.) The airport can be above VFR minimums but still require an instrument approach, imagine good visibility under a low overcast. What's an arriving IFR aircraft supposed to do if he's still in cloud at the circling MDA and there are VFR aircraft in the pattern? Ref AC 90-66a, 7f. Avoid interrupting traffic in the pattern. Basically, you can fly whatever you want, but only if it doesn't conflict with traffic established in the recommended pattern. That holds true any time you enter the pattern. Even when using the recommended 45 degree mid-field downwind entry, traffic already on the downwind (presumably from a take off staying in the pattern) has the right of way and it's your responsibility to time your entry so as not to interfere with existing traffic. So for a straight in approach, if there's no one in the pattern or you can make the approach without interfering with those who are, then go for it. If not, it's your responsibility to figure out how to sequence yourself into the traffic flow without causing a conflict. All of that said, flying a proper pattern doesn't give you the right to cut off someone flying a straight in approach. That's the gist of the FAA ruling someone posted elsewhe the guy was violated for intentionally cutting off aircraft making straight in approaches or really long downwinds. That's a no-no. Finally, there is no FAR one way or the other. Just the AC and the ASF publication. Bottom line: the traffic pattern is no place for a ****ing contest. Just be courteous to those around you and pay attention for those who aren't. FAR 91.113(g) does not exist? Where the hell do you get your information? Sure it does. Look again. |
#160
![]() "Steven P. McNicoll" wrote in message hlink.net... "Maxwell" wrote in message m... Aircraft flying a full pattern do have the right of way. That's not correct. § 91.113 Right-of-way rules: Except water operations. (g) Landing. Aircraft, while on final approach to land or while landing, have the right-of-way over other aircraft in flight or operating on the surface, except that they shall not take advantage of this rule to force an aircraft off the runway surface which has already landed and is attempting to make way for an aircraft on final approach. When two or more aircraft are approaching an airport for the purpose of landing, the aircraft at the lower altitude has the right-of-way, but it shall not take advantage of this rule to cut in front of another which is on final approach to land or to overtake that aircraft. It is correct. AC 90-66 clairifys it very well, and 91.113 is not in conflict. Reporting points should be done in miles at uncontrolled airports. Why? Per AC 90-66. 7f . Position reports on CTAF should include distance and direction from the airport. Everyone should consider aircraft may be correctly operating without radio communications. Yes, or incorrectly operating with radio communications. http://www.airweb.faa.gov/Regulatory...h light=90-66 Did you bother to read any of that? Paragraph 8.k states; "Throughout the traffic pattern, right-of-way rules apply as stated in FAR Part 91.113." Yep! No conflict. http://www.aopa.org/asf/publications/sa08.pdf From the Appendix, page 13" "(g) Landing. Aircraft, while on final approach to land or while landing, have the right-of-way over other aircraft in flight or operating on the surface, except that they shall not take advantage of this rule to force an aircraft off the runway surface which has already landed and is attempting to make way for an aircraft on final approach. When two or more aircraft are approaching an airport for the purpose of landing, the aircraft at the lower altitude has the right-of-way, but it shall not take advantage of this rule to cut in front of another which is on final approach to land or to overtake that aircraft." Correct. But an instrument "approach" is an approach, not an instrument "final". |
Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 10:55 PM |
"Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 04:36 PM |
A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 08:39 PM |
Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 08:19 PM |
Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 02:43 PM |
