#111
On May 30, 7:13 pm, "Blueskies" wrote:
Is it true that there is no longer any requirement to label gasoline contaminated with alcohol? Good article hehttp://motorcycleinfo.calsci.com/Gasoline.html I just did the add water to gas test on a couple of local gas sources and all contain alcohol, and none of the pumps said anything about it. The feds just dropped the requirement to label the pumps and we all missed it? Jay, where do you fill the grape from and how do you know there is no evil alcohol in it? When MTBE was outlawed, the only feasable alternative to add oxygen to gasoline was alcohol. This is mandated in ceartin parts of the country - mostly the east and west coasts plus mant of the major cities. Many states have followed suit and now require 5 or 10% alcohol to be add to auto gas. Some states require that the retail pumps lable that the gasoline contains alcohol - some states do not. Currently retailers can save money by adding alcohol to the gasoline because the alcohol is less expensive than gasoline, so they can blen it in and sell it to you as auto gasoline - you may not know it. Any percentage of alcohol in the gasoline will void your auto gas STC. There are many pushing for a national requirement for alcohol to be added to auto gas. Non alcohol auto gas will be available for FBO's to purchase and sell as auto gas for aviation, but anyone buying auto gas at a retial outlet and taking it to the airport in 5 gallon containers will need to check it for alcohol. EAA has a method on line to tell you how to check it. I recently did a presentation on auto gas with alcoho for an aviation group, added 10% alcohol to pure 87 octane auto gas - then some samples I added water - then lowered the temps on all samples to below freezing. First thing was that the alcohol would not stay mixed with the auto gas - it would seperate out. Second thing is that alcohol absorbs water - so you could not see the water in the alcohol/auto gas mixture, but when the temp was lowered to below freezing the water froze and ice settled out to the bottom. All said - I will not be using auto gas in my plane - it looked like an easy way to have a line freeze and turn the plane into a glider. |
#112
![]() an easy way to have a line freeze and turn the plane into a glider. Then why don't cars have line freezing trouble with E-10 gas? Here in Minnesota, gas line freezeups have essentially disappeared because of the mandated E-10. It is the only good thing about gasahpol though........... I think a major reason not to use E-10 in certificated aircraft is the ~5% power reduction. |
#113
On Sat, 2 Jun 2007 21:55:58 -0400, "Peter Dohm"
wrote: .. Really, the only way that I know to correctly "do the science" is to purchase a small amount (perhaps a liter) of anhydrous ethanol from a medical supply and perform a series of tests on a variety of samples--including samples of known pure and dry avgas and mogas. For the moment, I am unwilling to undertake the project, and also I believe that Clare and Bob are correct. Peter Definitive test for water in fuel. Get some copper sulphate chystals. Put them in a warm oven untill they are totally white. Store in a sealed dry container. Place a few crystals in your check bottle and add fuel. If the crystal turns blue, YOU HAVE WATER.Can't tell you how much, but if it stays white the gas is DRY. -- Posted via a free Usenet account from http://www.teranews.com |
#114
On Sat, 2 Jun 2007 22:16:03 -0400, "Morgans"
wrote: How sure are we that the gasohol in service station tanks contain no water? I would never bet on it. Is it possible that all tanks containing gasohol contain at least some water dissolved? Extremely likely, from past experience (pumping gas decades ago) Is it a certainty that the alcohol added to gasoline contains no dissolved water? No. Definitely NOT a certainty. I don't know the answer to any of these questions. Does anyone know, for CERTAIN, any of these questions? My guess is that all service station tanks, (unless they have never had straight gas, and that they are BRAND NEW) have had an opportunity to get some water in their tanks. If that is the case, and you put gasohol in them, the gasohol samples will contain some dissolved water, and the seltzer test will work. If that is the case, doing a scientific test with clean gas and adding water free alcohol will prove nothing. Except you can NEVER say NEVER, and ALWAYS avoid ALWAYS. It is POSSIBLE you may GET totally dry gasohol. The probability that it will remain dry is slim.(alcohol is hygroscopic - it attracts and binds water) -- Posted via a free Usenet account from http://www.teranews.com |
#115
Well, lemmee give ya a very simple example of cahoots...
First picture the double bottom fuel tanker... He goes to the terminal and loads premium gas for Chevron in the front tanker and premium gas for Shell in the back tanker... The computer adds the dyes, carcinogenic additives, and alcohol, and off he goes... Each company runs advertising on how its premium is better than anyone elses premium because of the companies expertise and care in every step of the production process - and how they search the world for the best crude - and oh yes, they are GREEN to boot... Your gas actually comes from the same generic tank fed off a generic pipeline from a generic refinery, that every branded and unbranded gas station in the area buys from, each putting their own name on it... The FTC is happy with this... The Atty General of the Hew Hess of Hey is happy with this... The states Atty General's are happy with this... Now picture Chivas Regal and Jack Daniels - and it comes to light Woodward and Bernstein strike again that they are not actually fermenting and distilling their own booze but are buying white lightning from an industrial alcohol distillery in Trinidad and Tobaggo same one that supplies it for gasohol and shipping it here in converted petroleum tankers, whereupon they each runit through charcoal, add coloring and flavoring, and each bottle it under their own label... The FTC and the combined Atty Generals will be good with that? No way, mon! There will be executives in hand cuffs testifying in front of Congress... But if it is big oil? - well golly gee it's just a business decision wink, wink, nudge... denny - who is old enough to see the wool over his eyes |
#116
Peter Dohm wrote:
According to annecdotes that I heard many years ago, service station gas tanks have always contained some water--but since the gasolene is lighter, the water settled to the bottom, so they were able to draw straight gasolene from a floating pickup. According to those annecdotes, there could have been as much as a couple of feet on water below the gasolene before it was drawn of as part of periodic maintenance, with the result that the apparatus were designed to shut off with a considerable level of liquid remaining in the tanks--in order to avoid pumping water. Speaking as someone who pumped gas to earn tuition money back in the early 60s before there was gasahol, we'd 'stick' the tanks daily at closing time to verify the amount in the tanks. There was always some water that was evident at the bottom of the stick, but it was never more than an inch or so. |
#117
On Sun, 03 Jun 2007 11:26:38 -0400, Cubdriver usenet AT danford DOT
net wrote: On Sat, 2 Jun 2007 10:38:20 -0400, "Morgans" wrote: I'll bet it really lasts a loooong time in your snow blower, this time of year! ggg And that, indeed, is the point of the exercise! The denatured gasoline evidently starts breaking down in a month. Straight gas in a year. I never drain the tanks on my lawn morwer, snow blower, yard tractor, or push lawn mower. I've never seen car gas break down even after several years. What I have seen is the stuff evaporate in the carburetors and leave a shelac. However I always turn off the gas and run the carbs dry. The next season I turn the gase on, wait a few minutes, prime and pull. They usually start on the first pull. Blue skies! -- Dan Ford Claire Chennault and His American Volunteers, 1941-1942 forthcoming from HarperCollins www.flyingtigersbook.com |
#118
The denizens of this ng have known and discussed this for some time now,
sir. WHere have you been? Jim -- There are only 10 kinds of people in the world. Those who count in binary and those who don't "Denny" wrote in message oups.com... The joke on us all is that gas pumped to your local distribution terminal has no alcohol in it... At the distribution terminal are huge tanks of gas, and smaller tnaks of alcohol, dye, additives, etc... The driver pulls up with his tanker... Keys in who the gas is for Shell, Marathon, ETC.and what the octane rating is and the computer selects the appropriate base stock of gasoline and mixes in the proper additives and dyes as it pumps the load to his tanker, including the alcohol... We are being hosed by the oil companies, in cahoots with the government, in more ways than just price... |
#119
Dave Butler wrote:
Speaking as someone who pumped gas to earn tuition money back in the early 60s before there was gasahol, we'd 'stick' the tanks daily at closing time to verify the amount in the tanks. There was always some water that was evident at the bottom of the stick, but it was never more than an inch or so. The only way we knew it to be "evident" was to put the paste on the stick and note a color change... I used to pump gas in the 70's, later I serviced the pumps and fuel systems themselves (80's)... |
#120
Sportys used to sell a test kit that contained a chemical that would turn
purple if added to a fuel sample that was gasahol. I have no idea of what the chemical was. It was a very easy to test the fuel. They claim that their supplier no longer exists. I bought a bunch of the kits and have about 1/2 a vial of the chemical left. I sure would like to know what the reagent is that was used. Cheers: Paul N1431A |
Gasohol | Blueskies | Piloting | 240 | July 6th 07 12:42 AM |
Gasohol | Blueskies | Owning | 233 | June 30th 07 03:50 AM |
How scary is gasohol? | Charles Talleyrand | Owning | 27 | March 1st 04 11:39 AM |
