Gasohol
Old May 31st 07, 01:13 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
Is it true that there is no longer any requirement to label gasoline contaminated with alcohol?
Good article he http://motorcycleinfo.calsci.com/Gasoline.html
I just did the add water to gas test on a couple of local gas sources and all contain alcohol, and none of the pumps
said anything about it. The feds just dropped the requirement to label the pumps and we all missed it?
Jay, where do you fill the grape from and how do you know there is no evil alcohol in it?
Old May 31st 07, 05:32 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Montblack
Default Gasohol
("Blueskies" wrote)
alcohol in it?
In the Twin Cities (St Paul / Mpls) the pumps with NO ethanol are marked
special. About 1 in 50 stations has such a pump - and it's usually 93
Premium ...Non-Oxy.
http://www.msra.com/NonOxygenatedFuel/Non-OxyFuel.htm
http://www.msra.com/NonOxygenatedFuel/Non%20Oxygenated%20Fuel%2006.01.07.pdf
Minnesota gas stations with Non-Oxy gas. That's the whole state!
Montblack
Old May 31st 07, 07:41 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Robert M. Gary
Default Gasohol
On May 30, 9:32 pm, "Montblack" Y4_NOT!...
("Blueskies" wrote)
alcohol in it?
Premium ...Non-Oxy.
Can I have some shipped out to California? I'm tired of having to
drain my lawn mower and edger after every mowing and having to throw
out the gas in my cans every 30 days. The mower shops are booked up 3
months out cleaning the gook out of carbs.
-Robert
Old May 31st 07, 08:47 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
NW_Pilot
Default Gasohol
("Blueskies" wrote)
evil
alcohol in it?
Premium ...Non-Oxy.
-Robert
Lawnmower carbs are simple to clean!!!!! I run Avgas in mine Never a
Problem!!!!
Old June 1st 07, 03:33 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
BT
Default Gasohol
The mower shops are booked up 3 months out cleaning the gook out of carbs.
-Robert
Must be why mine was running rough last weekend, it operates maybe twice a
month for about 15 minutes or less and it has not been serviced in 10 years.
B
Old May 31st 07, 06:11 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
tony roberts
Default Gasohol
Worse.
I read that, starting in 2007, in some places, California and some
Canadian Provinces included, it is regulated that all gasoline sold must
contain at least 5% alcohol/ethanol.
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old May 31st 07, 09:40 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
mike regish
Default Gasohol
I'm pretty sure Mass. is already there. I don't know if there's a minimum,
but we've got 10% ethanol everywhere now.
mike
"tony roberts" wrote in message
news:indiacharlieecho-9E437A.22120430052007@shawnews...
Worse.
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old May 31st 07, 12:28 PM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
B A R R Y[_2_]
Default Gasohol
Same in CT.
I think most, if not all, of the Northeastern states sell the same
blend, no longer labeling the pumps for the 10% alchohol content.
Old June 1st 07, 02:06 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
Blueskies
Default Gasohol
"B A R R Y" wrote in message t...
mike regish wrote:
I'm pretty sure Mass. is already there. I don't know if there's a minimum, but we've got 10% ethanol everywhere now.
Same in CT.
I think most, if not all, of the Northeastern states sell the same blend, no longer labeling the pumps for the 10%
alchohol content.
And that means that all of us using gasohol are getting worse gas mileage than we would get with straight gasoline. If
the fuel is 10% ethanol that is 10% less gasoline being pumped while the price has gone up double in the last two years.
Energy bill of 2005, eh?????
Old June 1st 07, 03:37 AM posted to rec.aviation.homebuilt,rec.aviation.owning,rec.aviation.piloting
BT
Default Gasohol
than we would get with straight gasoline. If the fuel is 10% ethanol that
the last two years. Energy bill of 2005, eh?????
The oil companies recently blamed the Bush Administration's emphasis on
converting to bio fuels as the cause for the price increase in gasoline.
Their statement: If they (bush) would support gasoline, then the oil
companies would spend money on additional refineries to meet the demand and
price could stay low. But with the emphasis on conversion to bio fuels and
alternative energy, the oil companies have no incentives to
rebuild/repair/build new refineries to meet the increasing consumption
demand.
So they say as they pocket record profits.
BT
Gasohol Blueskies Piloting 240 July 6th 07 12:42 AM
Gasohol Blueskies Owning 233 June 30th 07 03:50 AM
How scary is gasohol? Charles Talleyrand Owning 27 March 1st 04 11:39 AM
