#11
how bout the flitplane from ed fisher
("patrick mitchel" wrote)
how bout the flitplane from ed fisher http://www.digitalmarketingusa.com/flitplane.html The Flitplane http://www.digitalmarketingusa.com/h...ltralight.html Home Despot Ultralight ......"Motor Glider 101" A: Why not name it 103? (Stall speed. Drat!) B: I like different, and this is different!!! (From the link) Power is provided by two 10 HP Tecumseh motors are mounted directly onto two by two's, hollowed out in the center with 1/8 inch plywood on the side. No rubber mounts are used for the engines, but it would be a good idea. Power from the two 10 HP engines was transferred directly to the props, no gear reduction was used. The props for the prototype were homemade and were "whittled out of wood." They were redesigned several times until optimum performance was reached. The wings have a plywood main spar, the ribs are Styrofoam, and 1.7-ounce Dacron sail cloth is used as a covering material. According the Jack he has "over 50 years of experience building planes." The plane shown here had about 7 hours on it with the last flight made the week prior to the show where it was on display. Jack reports that it fly's along at about 40 to 45 mph. When asked how much the average person would have invested in materials - the reply was "if you go down and buy everything from Home Depot, the average person will have about $1,000 invested in engines and materials. However, the builder will, carve his own props or buy some commercially produced." Of course materials like the 4130 steel tubing, sail cloth, etc will have to be sourced out somewhere else. http://www.digitalmarketingusa.com/index.html Ok, the subs are COOL! Montblack |
"Montblack" wrote:
http://www.digitalmarketingusa.com/index.html Tecumseh motors cost more than they used to... Like alot of things... |
![]() "Montblack" wrote http://www.digitalmarketingusa.com/index.html Ok, the subs are COOL! No doubt! I want one of the luxury 213' luxury models! -- Jim in NC |
![]() Montblack wrote: ("patrick mitchel" wrote) how bout the flitplane from ed fisher http://www.digitalmarketingusa.com/flitplane.html The Flitplane http://www.digitalmarketingusa.com/h...ltralight.html Home Despot Ultralight ......"Motor Glider 101" A: Why not name it 103? (Stall speed. Drat!) B: I like different, and this is different!!! (From the link) Power is provided by two 10 HP Tecumseh motors are mounted directly onto two by two's, .... IIRC it also weighs more than 400 lbs, nowhere close to being a FAR 103 Ultralight. That's why he calls it a 'Motorglider', not an Ultralight. OTOH if you have (or can get) a glider license with a self-launch endorsement then a motorglider may be a better choice than a FAR 103 ultralight. -- FF |
wrote)
OTOH if you have (or can get) a glider license with a self-launch endorsement then a motorglider may be a better choice than a FAR 103 ultralight. This is a hoot - AND A MUST READ!!! g http://edburkhead.com/Challenger/gli...torglider1.htm Experimental Glider? YES!! IIRC it also weighs more than 400 lbs, nowhere close to being a FAR 103 Ultralight. That's why he calls it a 'Motorglider', not an Ultralight. As a 'Motorglider': (ii) Maximum weight does not exceed 850 kg (1874 pounds); and (iii) The maximum weight to wing span squared (w/b2) does not exceed 3.0 kg/M2 (0.62 lb./ft.2). 500 lbs MTOW and 28.5 ft wingspan = 812 (wing span squared) 500 lbs MTOW (/) 812 = 0.61576 lb./ft.2 ....which does not exceed 0.62! So yes, it is a motorglider ....IF the MTOW is 500 lbs ....or we go with longer wings ....or we follow the first link. g http://www.usppa.org/Resources/FARs/part103_far.htm (Part 103) Home Depot Ultralight: aka "Motor Glider 101" http://www.digitalmarketingusa.com/h...ltralight.html Specifications: Empty Weight: 254 lbs Stall Speed: 30 mph Cruise Speed: 55 mph @ 2600 rpm. Fuel Capacity: 5 US Gallons. Wing Span: 28' 6" Gross Weight: Not established, however pilot flew prototype with 5 gallons fuel, pilot weight 225 lbs. Wing Chord: 5' 0" Gross Wing Area: 142 1/2 sq. ft. Dihedral: 3" from Fuselage to Wing Tip. Tail Span: 6' 6" LOA: 15' 8" Height: 6' 0" Wheel Track: 4' 10" - Center to Center Maximum HP: Not Established Prototype Power: (2) Tecumseh 10hp 4 Stroke Engines or (2) 227 Rotax. Endurance: (2) Techunesh engines consume approx. 1 gph. Landing Speed: 35 mph. Landing Rollout: 100' Rate of Climb: Slow but steady with (2) 10 hp motors. Will maintain level flight on one engine. Bad Montblack, Bad! Too much to do today to play anymore on the Groups :-( |
![]() That's why he calls it a 'Motorglider', not an Ultralight. OTOH if you have (or can get) a glider license with a self-launch endorsement then a motorglider may be a better choice than a FAR 103 ultralight. That would have to be in the amateur built experimental classification, and not even as a light sport plan (thus needing a regular glider ticket, not LSP) because of the two engines, right? Then, you get to the definition of the span to weight requirements of a motorglider, which are not easy to meet. I do not think it meets the requirements for a motorglider, by a long shot. I'm not sure where this plane would fall, except as a twin engine experimental amateur built. You would need a regular PP ticket, (or higher) with a twin engine endorsement, I would think. -- Jim in NC |
![]() "Montblack" wrote This is a hoot - AND A MUST READ!!! g http://edburkhead.com/Challenger/gli...torglider1.htm Experimental Glider? YES!! I predict that if many people start using this option, it is a loophole that will quickly be regulated out of existence. Interesting, indeed. -- Jim in NC |
("Morgans" wrote)
Then, you get to the definition of the span to weight requirements of a motorglider, which are not easy to meet. I do not think it meets the requirements for a motorglider, by a long shot. (Reposted in case someone didn't want to slog through my other post.) As a 'Motorglider': (ii) Maximum weight does not exceed 850 kg (1874 pounds); and (iii) The maximum weight to wing span squared (w/b2) does not exceed 3.0 kg/M2 (0.62 lb./ft.2). 500 lbs MTOW and 28.5 ft wingspan = 812 (wing span squared) 500 lbs MTOW (/) 812 = 0.61576 lb./ft.2 ....which does not exceed 0.62! So yes, it is a motorglider ....IF the MTOW is 500 lbs ....or we go with longer wings ....or we follow the first link. g http://www.usppa.org/Resources/FARs/part103_far.htm (Part 103) Home Depot Ultralight: aka "Motor Glider 101" http://www.digitalmarketingusa.com/h...ltralight.html Specifications: Empty Weight: 254 lbs Stall Speed: 30 mph Cruise Speed: 55 mph @ 2600 rpm. Fuel Capacity: 5 US Gallons. Wing Span: 28' 6" Gross Weight: Not established, however pilot flew prototype with 5 gallons fuel, pilot weight 225 lbs. Montblack |
![]() "Montblack" wrote in message ... ("patrick mitchel" wrote) how bout the flitplane from ed fisher http://www.digitalmarketingusa.com/flitplane.html The Flitplane Looks like a good possibility, especially for a first attempt. What are the pros and cons? Searching for plans, various places are selling them (Raceair, Midwest Engineering..) Who owns the rights? WayneC |
ultralight seaplane | Friedrich Ostertag | Piloting | 13 | September 16th 05 03:37 AM |
Sparrowhawk Ultralight | [email protected] | Soaring | 26 | June 15th 05 07:22 PM |
Ultralight? | dlevy | Owning | 3 | September 1st 04 04:27 PM |
Ultralight costs | Bob Martin | Home Built | 1 | January 1st 04 09:34 PM |
RV Quick Build build times... | [email protected] | Home Built | 2 | December 17th 03 03:29 AM |
