Sparrowhawk Ultralight
Old June 7th 05, 03:41 AM
Default Sparrowhawk Ultralight
Can someone who has flown a Sparrowhawk give their impression of the
AC. What does it do well? Can you really compare this sailplane to a 15
meter or any current sailplane? Can it be a serious cross country flier?
Old June 7th 05, 05:17 PM
"Yes, it's a serious cross country flier. As evidence, here's a
marketing blurb from the manufacturers web site."
Old June 8th 05, 05:15 PM
Eric
It's more of a marketing blurb than an actual account of what happened
at an event.
some people would consider it a bit misleading to say that on May 14 a
sparrowhawk flew the longest distance of the crystal squadron. While
failing to also say that the sparrowhawk was the only glider of the
crystal squadron to fly xc from crystal that day!
Hang gliders have flown diamond distance, so they should be considered
serious cross
country fliers also.
Old June 8th 05, 06:37 PM
For Example John Smith
All aircraft have a performance envelope. Some pilots can "fill" the
performance envelope of their aircraft. Most can't. The real question
aircraft purchasers need to ask is "Will I be happy with the aircraft's
performance at the level to which I can 'fill' its performance envelope?"
Eric
at an event.
serious cross
Old June 9th 05, 06:57 AM
Ian Cant
My Russia works out at about 7 lbs/sq ft. Last September
I shared a thermal with a Sparrowhawk - it was turning
tight and climbing just a shade better than me. And
it's probably a little faster in cruise as well. To
my mind a 'serious cross-country ship' in the West
needs to carry 'serious landout and safety equipment'.
How much space and weight can the Sparrowhawk offer
when you're sitting in the cockpit ?
Ian
At 05:42 09 June 2005, Eric Greenwell wrote:
Tim.Ward wrote:
Well, while the weight is low, the wing is small,
so the wing loading
is probably similar to a 1-26.
It's actually much higher than a 1-26. The 1-26 is
rated at 3.6
pounds/sq ft; the SparrowHawk is typically 5 to 6 pounds/sq
ft. This
makes a big difference! This wing loading is about
the same as Russia
AC-4, which is similar in performance.
As to resale price, that's a tougher one, because
I have not seen one
offered on the used market. I find that interesting,
because I seem to
remember that nearly as soon as the Russias and PW5s
became available
new, they became available used.
Tim Ward
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Old June 9th 05, 03:32 PM
On 9 Jun 2005 05:57:34 GMT, Ian Cant
Ian
The cockpit is very roomy, and the instrument panel lifts up with
the canopy.
Old June 9th 05, 06:30 PM
Eric Greenwell
Ian Cant wrote:
To
There is plenty of room behind the cockpit for the tiedowns and
emergency kit you'd want to carry, and the 5-10 pounds of weight won't
be a problem, except for the heaviest pilots with the BRS option installed.
Eric Greenwell
Washington State
USA
Update on the SparrowHawk and more.... David Bingham Soaring 40 June 14th 04 09:34 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Wanted Sparrowhawk David Bingham Soaring 18 May 4th 04 11:20 PM
Jet Glider Sparrowhawk Mark James Boyd Soaring 31 January 22nd 04 06:09 AM
Ultralight magazine August 1981 Gilan Home Built 0 July 20th 03 04:34 AM
