#291
Actually, you're just a poor student.
.... and you are not a teacher. You are a professor. Jose -- There are two kinds of people in the world. Those that just want to know what button to push, and those that want to know what happens when they push the button. for Email, make the obvious change in the address. |
#292
Recently, Steven P. McNicoll posted:
"Neil Gould" wrote in message t... My question to YOU was when the ability to understand IAPs was added to the Private Knowledge or Practical tests? The fact is that it is NOT a part of the requirements for a Private certificate. The direct route to realizing that fact is to simply read the published requirements. They are not secret documents. So, your references to irrelevant regs (twice, no less) is clearly an indication that you are quite confused about the requirements and expected abilities of private pilots. That was NOT your question to me. I stated, "Every newly minted VFR pilot should be able to identify the fixes in the plan view of an IAP. Your question in response was, "Oh? When was this added to the Private Knowledge Test or Practical?" The fact that you don't know what you asked is a clear indication that it is you that is confused. My question to you had to do with the basis for your assumption. Specifically, what in the Practical or Knowledge Tests -- the ONLY requirements for becoming "a newly minted VFR pilot" -- assures that your assumption is valid. Since there is no requirement that a "...newly minted VFR pilot..." has even SEEN an IAP, your assumption is not reasonable. Neil |
#293
"Steven P. McNicoll" wrote:
So which practice should be followed? The one in AC 90-66A which provides reliable information to none or the one in AC 90-42F which provides reliable information to some? I've found a very helpful AOPA document that provides useful guidance on this subject (and provides me an answer to your questions): "Safety Advisor Operations & Proficiency No. 3 Operations at Nontowered Airports": http://www.aopa.org/asf/publications/sa08.pdf It states: "Pilots practicing instrument approaches at nontowered airports on a VFR day should announce their position in both IFR and VFR terms, "Frederick traffic, Seminole Three-Six Lima, RICKE inbound, four-mile final, Runway Two-Three, Frederick." VFR pilots will benefit from a little education about instrument operations at a nontowered airport. Learn if the airport has IFR approaches and, if so, to which runways by referencing the A/FD. Have an instrumentrated pilot or instructor describe the approach procedures and explain the phraseology IFR pilots use to announce their positions and intentions. .... If you know where the missed approach holding fixes are and how instrument traffic navigates to those fixes, you’ll know where IFR pilots are headed when they announce on the CTAF they are executing a practice missed approach." There is more relevant material (including advice on when a straight-in approach is not recommended) but the document's recommendations appear to be (to me at least) better than the too-brief recommendations in the two FAA ACs referenced above. So my answer to your questions would be "neither," and would follow the practice recommended by the AOPA document. |
#294
![]() "Steven P. McNicoll" wrote in message link.net... "Maxwell" wrote in message ... People that insist on straight in approaches at uncontrolled fields are just as bad if not worse. Not following FAA recommend procedures is proabably worse. Like the FAA recommended procedure to use the FAF to identify one's position in a self-announce broadcast specified in Advisory Circular 90-42F "Traffic Advisory Practices at Airports Without Operating Control Towers" when executing an IAP? Is that the kind of FAA recommended procedure you're referring to? Not following the right-of-way rules in FAR 91.113 is worse. Asked and answered Steven, your just trolling because you don't like the answer. |
#295
![]() "Steven P. McNicoll" wrote in message ink.net... "Maxwell" wrote in message ... So now you are going to try to convince us that final doesn't follow base leg. Do you have a reference? No, I've been explaining that final extends beyond the base leg. It's clear now that that fact is beyond your ability to understand. Asked and answered Steven, your just trolling because you don't like the answer. |
#296
![]() "Steven P. McNicoll" wrote in message hlink.net... "Maxwell" wrote in message ... Just as it's stated. If two aircraft turn final from base leg, 91.113g is still very useful. Of course. FAR 91.113(g) states aircraft on final have the right-of-way. If two aircraft turn final from base leg 91.113(g) gives the right-of-way to the aircraft on final. How could I have ever missed that. Asked and answered Steven, your just trolling because you don't like the answer. |
#297
![]() "Steven P. McNicoll" wrote in message hlink.net... "Maxwell" wrote in message ... Since AC 90-66A doesn't speak to that particular point, and I'm not aware of anything that does, maybe you should ask the FAA? I was answering your question. Do you see the point now? I have seen your point ever since you began deigning 90-66. Asked and answered Steven, your just trolling because you don't like the answer. |
#298
![]() "Steven P. McNicoll" wrote in message link.net... "Maxwell" wrote in message ... Where? In AC 90-42F Traffic Advisory Practices at Airports Without Operating Control Towers, which I posted three weeks ago in this thread. 11. EXAMPLES OF SELF-ANNOUNCE PHRASEOLOGIES. It should be noted that aircraft operating to or from another nearby airport may be making self-announce broadcasts on the same UNICOM or MULTICOM frequency. To help identify one airport from another, the airport name should be spoken at the beginning and end of each self-announce transmission. (3) Practice Instrument Approach: STRAWN TRAFFIC, CESSNA TWO ONE FOUR THREE QUEBEC (NAME - FINAL APPROACH FIX) INBOUND DESCENDING THROUGH (ALTITUDE) PRACTICE (TYPE) APPROACH RUNWAY THREE FIVE STRAWN. STRAWN TRAFFIC, CESSNA TWO ONE FOUR THREE QUEBEC PRACTICE (TYPE) APPROACH COMPLETED OR TERMINATED RUNWAY THREE FIVE STRAWN. Asked and answered Steven, your just trolling because you don't like the answer. |
#299
![]() "Larry Dighera" wrote in message ... On Thu, 07 Jun 2007 23:03:15 -0000, Jim Logajan wrote in : Your citation of AC90-66A [1] appears to clearly indicate that the FAA prefers that IFR pilots report their positions by transmitting their distance from uncontrolled airports when landing at same: How do you resolve that conclusion with the third paragraph from the end below: It seems clear to me that most VFR pilots, as well as many IFR pilots flying VFR in unfamiluar areas, an not going to be aware of all IFR reporting points. Therefore, if someone wants to convey their position to all pilots on CTAF, IFR reporting points will never be completely reliable. It also seems the FAA understands this, or they wouldn't have clearly mentioned it in the AC. So I would think we could assume the FAA was thinking of an IFR situation when the example in 90-42 was written. I don't see how any reasonable person could report himself in reference to an IFR reporting point, in VFR conditions, and expect all others to understand. Right or wrong, someone doing so doesn't seem to be making his reporting position clear. |
#300
![]() "Steven P. McNicoll" wrote in message nk.net... "Jim Logajan" wrote in message .. . I believe the "definition" in that circular is implicit in the labeling of the airport operation diagrams in appendix 1. The line out from infinite to the point where it joins the base leg is labelled "straight-in approach" and the narrative for point (3) labels the line from the base leg to the runway as final. The "final" label in that diagram is on the side of the base leg away from the airport, indicating that final extends past the base leg. That is consistent with the definition of final found in the Pilot/Controller Glossary The narrative for point 3 is, "Complete turn to final at least l/4 mile from the runway." That does not even approach suggesting that final does not extend beyond the base leg. Asked and answered Steven, your just trolling because you don't like the answer. |
Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 10:55 PM |
"Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 04:36 PM |
A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 08:39 PM |
Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 08:19 PM |
Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 02:43 PM |
