Maintenance Questions
Old June 25th 07, 04:34 AM posted to rec.aviation.piloting
C. Massey
Default Maintenance Questions
Cousin has a glider and said that he needs to add fluid in compass.
Is this something that can be done? If so, can he do it or does an A&P have
to do it? What is the fluid?
Also, he is also wanting to replace the tubing between the pitot tube and
the instrument. Again, can he do this or does an A&P have to do it?
Thanks...
Old June 25th 07, 05:21 AM posted to rec.aviation.piloting
Morgans[_2_]
"C. Massey" wrote
What is the fluid?
In sailboats, it is mineral spirits. I don't know about airplanes, cause I
don't think I am allowed to mess with the sacred compass! ;-))
Old June 25th 07, 05:29 AM posted to rec.aviation.piloting
Dave[_5_]
Kerosene. If the compass is an Airpath, which seems to be the most
common, you can buy a rebuild kit that includes new seals and fluid.
I will let the armchair lawyers hereabouts comment on the legalities.
David Johnson
Old June 25th 07, 05:31 AM posted to rec.aviation.piloting
BT
Para 43.3, (g) Authorized persons, preventive maintenance, rated pilot
Appendix A to Part 43 of the Fed Air Regs, paragraph C, Preventive Maint
Do not see a compass as an approved item..
do see.. "replacing hoses other than hydraulic"
Normally there is more to a compass than "adding fluid", if it needs
fluild.. there is a leak.. need to rebuild it.
Then need to "swing the compass" installed in the glider with electrics on.
BT
"C. Massey" wrote in message
et...
have to do it? What is the fluid?
Thanks...
Old June 25th 07, 05:33 AM posted to rec.aviation.piloting
Robert M. Gary
Thanks...
I know I can't legally do either of these on my airplane (my A&P can't
even change the tube, that an avionics job). Is this glider FAA
certified?
-Robert
Old June 25th 07, 12:32 PM posted to rec.aviation.piloting
Ron Natalie
Hmm... the only glider I ever flew in didn't have anything resembling
electricity.
Old June 25th 07, 02:09 PM posted to rec.aviation.piloting
acid free white kerosene
fill compass/ get A&P to replace tubing
et...
Thanks...
Old June 25th 07, 06:17 PM posted to rec.aviation.piloting
Robert M. Gary
Thanks...
BTW: After making the mistake once, I would never again "add fluid" to
a compass and replace the seals. After buying a total of 4 kits and
paying almost 5 hours in labor my compass no longer leaks again. For
about 1/2 that price I could have just bought a new compass. It seems
as though the body of the compass warps over the years and getting a
solid seal becomes very, very difficult.
-Robert
Old June 25th 07, 06:43 PM posted to rec.aviation.piloting
[email protected][_2_]
electricity.
You might be surprised at the sophistication of a modern glider (not
some stone age beat up trainer). My 20 year old LS6 has two
independent GPSs, moving map, glide computer, electric varios with
audio, radio, ELT, dual redundant separate battery systems, etc.
Many of my friends have transponders and/or TPAS's in theirs.
Nice to have on those long XC flights.
Kirk
66
Old June 26th 07, 12:28 AM posted to rec.aviation.piloting
Kyle Boatright
My understanding is that your cousin cannot legally work on his certified
airplane's compass, nor can an AI or A&P. My understanding is that an FAA
approved instrument repair station is needed.
At least this is what a buddy of mine (an AI) told me one day when he was
standing over his workbench repairing a compass from another guy's *boat*.
Aircraft Spruce sells both the correct fluid for a compass and the seals for
the compass. To top off the fluid, you can simply pull the little plug (or
is it a screw ? - can't remember) at the top of the compass and use a
syringe or pipette to add fluid. I had to do that to my *boat's* compass a
few years ago. Apparently compasses are vented and the fluid can evaporate
over time.
KB
et...
Thanks...
What do you do about maintenance? Andrew Gideon Owning 5 July 2nd 06 04:00 PM
Maintenance questions JJS Owning 15 August 18th 05 01:43 AM
Maintenance Manuals RST Engineering General Aviation 6 April 4th 05 06:47 PM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
B-25 Maintenance Randy Military Aviation 1 July 11th 03 03:37 AM
