Maintenance questions
Old August 12th 05, 03:03 AM
JJS
Default Maintenance questions
Okay, the Cherokee 140 annual is nearly finished. Compressions are 80, 80, 80, & 78 over 80 after 5 1/2 years and
650 hours of mostly autogas use.
So far everything looks very good except for two things. My A&P IA was inspecting the propeller spinner back plate
and was turning the prop real slow by hand as he did so. He noticed that the impulse coupler on the left mag wasn't
clicking. He turned it a little faster and it works fine. Tried it slow again and sometimes... no clicky. Since
I've had no starting problems, he suggests I just keep flying it unless it begins to give trouble. The mags won't be
due for overhaul for at least another year. My question is: Is there a slow death type "normal" failure mode in
which progressively harder starts occur or do impulse couplers usually fail suddenly and leave you stranded? I
really don't want to throw away money. On the other hand I'd rather not get stranded after dark at an airport away
from home with no mechanics around or parts to be had.
Question #2 The nose strut is not leaking, but there is a spot in which the chrome plating is beginning to blister.
It is hard to see and is low on the strut where it would take some extremely hard braking or a big bump, (or one of
my not so good landings, come to think of it) to get the top portion of the strut to pass over it. Eventually I
suspect, it will need attention. Is it still possible to have these struts rechromed? A Google search turned up a
post from 2002 listing these guys:
Industrial Plating Co. Inc.
1300 Clydesdale Avenue
P.O. Drawer 2365
Anniston, AL 36201
800-525-6408
Fax 256-237-1579
FAA Repair Station # IPBR525K
Can anyone who has had this done in the not to distant past recommend additional business possibilities and perhaps
relate a cost to do it?
Joe Schneider
8437R
(Remove No Spam to Reply)
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
Old August 12th 05, 05:01 AM
On 11-Aug-2005, "JJS" jschneider@remove socks cebridge.net wrote:
My question is: Is there a slow death type "normal" failure mode in which
fail suddenly and leave you stranded? I really don't want to throw away
money.
On the other hand I'd rather notget stranded after dark at an airport away
A "sudden" failure would most likely be a fracture of the impulse coupler
itself, which does not seem to be where your problem is leading. I'd deal
with it if and when you begin having starting difficulties. However, please
remember that this advice may be worth no more than you are paying for it.
-Elliott Drucker
Old August 12th 05, 02:03 PM
: So far everything looks very good except for two things. My A&P IA was inspecting
the propeller spinner back plate : and was turning the prop real slow by hand as he
did so. He noticed that the impulse coupler on the left mag wasn't : clicking. He
clicky.
I would be a bit concerned on that. There are AD's against some mags' impulse
couplings (like mine... O-360 with Bendix). Basically, the little tabbies that are
supposed to catch and load the spring get worn. Also, there is a bad type of rivet
that holds them on the impulse coupling. If the pivot point on the catch tabs are
worn, it could be binding enough once in awhile so gravity won't drop them where they
need to catch. If these couplings fail and fall apart, they'll drop a bunch of little
steel pieces in the accessory housing and likely jam up the gears. Since important
things like the camshaft run on those, it could ruin your day.
Even if they aren't the type with ADs on them, I'd take the mags off an have a
looksee. It doesn't take that long to take them off and look. Also, it's typical for
only one mag on the Cherokees to have a impulse coupling. Does yours have one on
both?
: Question #2 The nose strut is not leaking, but there is a spot in which the chrome
plating is beginning to blister. : It is hard to see and is low on the strut where it
would take some extremely hard braking or a big bump, (or one of : my not so good
Eventually I : suspect, it will need attention. Is it still possible to have these
struts rechromed? A Google search turned up a : post from 2002 listing these guys:
I don't know about rechroming, but the worst thing I can think of that would
happen would be a bit more wear on the rubber O-ring seals on the struts. They're not
that tough to replace either... just a bit messy. I would be a bit concerned about
any heating that may have to happen to have it rechromed. I don't know anything about
the process, but losing the heat treatment on them could be bad. I'd probably see
what some fine sandpaper on the blistered chrome would do. Just make sure it doesn't
rust afterwards.
-Cory
* Cory Papenfuss *
Old August 12th 05, 03:39 PM
On Thu, 11 Aug 2005 21:03:51 -0500, "JJS" jschneider@remove socks
cebridge.net wrote:
snip
Typically, there is a light spring on each fly-weight that holds it in
the engaged position to "cock" the coupling. When the engine starts,
and the magneto RPM increases, the heavy end of the f-w overcomes the
spring and keeps it from cocking and clicking. When the engine is
running, tension from the main coiled flat spring that "fires" the
coupling is what holds the coupling in the static straight-up (opposed
to retarded for start) timing position.
If the coupling does not cock-and-fire, you are trying to start your
engine with standard timing (advanced 20-25 degrees BTDC). If the flat
spring breaks, you have retarded "start" timing in flight-that is not
a good thing. As another poster mentioned, the riveted assembly can
come apart-that is not a good thing either.
It's your airplane, you decide what you want to do.
snip
P.O. Drawer 2365
Anniston, AL 36201
800-525-6408
Fax 256-237-1579
Yes-it is much cheaper than purchasing a new strut, but it is not
inexpensive. It is the only facility that I am aware of that has the
capabilities (and the approval) to grind and hard-chrome aircraft
struts.
It will come back looking like brand-new.
Regards;
TC
Old August 12th 05, 05:16 PM
dave
The coupler was failing on my left mag. Starting the plane became more
and more difficult particularly in cold weather. Why take a chance on
being stuck somewhere?
Dave
68 7ECA
P.O. Drawer 2365
Anniston, AL 36201
800-525-6408
Fax 256-237-1579
Old August 12th 05, 07:32 PM
DL
If the impulse coupler spring breaks, you have, at best, a dead mag. If you
don't notice the subtlety in flight (as I once did) you will notice it as a
dead mag on your next run-up.
"JJS" jschneider@remove socks cebridge.net wrote in message
inspecting the propeller spinner back plate and was turning the prop real
left mag wasn't clicking. He turned it a little faster and it works fine.
Tried it slow again and sometimes... no clicky. Since I've had no
give trouble. The mags won't be due for overhaul for at least another
in which progressively harder starts occur or do impulse couplers usually
airport away from home with no mechanics around or parts to be had.
Joe Schneider
8437R
Old August 13th 05, 12:11 AM
There are ADs against many mags, some of them dealing with
impulse failures. Get the mechanic to check for any that apply to this
mag.
Corrosion and sludging often cause sticky impulse couplings.
Neither are good, especially the corrosion, which can cause spring
breakage and power loss. Mags on infrequently-flown airplanes, or those
mags that haven't been off for a long time, definitely need checking.
Dan
Dan
Old August 13th 05, 01:32 AM
JJS
snip
P.O. Drawer 2365
Anniston, AL 36201
800-525-6408
Fax 256-237-1579
struts.
Regards;
TC
TC, Thanks. I was hoping you'd comment. I called my A&P IA today and visited with him. We will pull the mag and
inspect the coupling closely. All of the mag AD's have been been complied with all along since I've owned the
airplane. I appreciate the comments on the repair station as well.
Old August 13th 05, 01:34 AM
JJS
"DL" wrote in message ink.net...
If the impulse coupler spring breaks, you have, at best, a dead mag. If you don't notice the subtlety in flight
(as I once did) you will notice it as a dead mag on your next run-up.
May I ask how you detected a broken impulse coupler spring in flight, DL? I might learn something here.
Old August 13th 05, 01:42 AM
BTIZ
depending on the Mag, there is a service AD for the magneto on the impulse
coupler fly weight tolerances (or something like that). I'd ask about the AD
and ask if your mag requires that inspection. I think it is due at each
annual.
BT
80, 80, & 78 over 80 after 5 1/2 years and 650 hours of mostly autogas
use.
the chrome plating is beginning to blister. It is hard to see and is low
bump, (or one of my not so good landings, come to think of it) to get the
top portion of the strut to pass over it. Eventually I suspect, it will
Google search turned up a post from 2002 listing these guys:
P.O. Drawer 2365
Anniston, AL 36201
800-525-6408
Fax 256-237-1579
additional business possibilities and perhaps relate a cost to do it?
Joe Schneider
8437R
News==----
Newsgroups
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
