#61
Longworth wrote:
Everytime that I read a post about some bad events from a fellow pilot, I always cringe in seeing reprimanding or scolding remarks from the Monday morning quarrterback or armchair pilots. It's a good thing the Callback site does not have a readers' feedback option! Well said. Dave M35 |
#62
Landing with less than full flaps is CERTAINLY not "Beating up the
airplane." Where do you come up with such rubbish. My Cessna's POH specifically states: FLAP LIMITATIONS: Approved Landing Range. 0--40 Not being able to select the proper flap for landing conditions is a serious training flaw. Full flap all the time is ridiculous. Karl "Blueskies" wrote in message et... "kontiki" wrote in message ... Get a real A&P to check out the flap situation. If its not the breaker it could be the flap motor (one of the reasons I do like manual flaps). As far as why you didn't notice that your flaps were not working... well... that is disturbing. I notice *every* little sound, motion, vibration or whatever in my airplane. I hardly ever land with full flaps unless its a short field. Why are you beating up the plane? I was taught and used to teach that any landing without full flaps was an 'emergency' landing. The airplane has a landing configuration and the performance in the book is based on that configuration... It is good to practice emergency landings every so often. |
#63
Maybe not, you don't have to USE them..........but they must be operable.
Karl "Al G" wrote in message ... "Hilton" wrote in message t... Al G wrote: Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. It is up to you to decide *while adhering to the FARs*, I think you're missing that point. Hilton (b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur Nothing in the "regs" says I have to use flaps in a C172. Al G |
#64
![]() "Roy Smith" wrote in message order. There is some logic in this. All the Cessna AFMs I've seen (i.e. for various flavors of their piston singles) have nice detailed performance charts showing how much runway you need to land with various combinations of weight, temperature, elevation, wind, and phase of moon, but the numbers always are for full flaps. There is NO data on how much runway you need without flaps, therefor there is no way you can comply with 91.103 which requires that you familiarize yourself with the takeoff and landing distances. Well, you certainly haven't seen all the Cessnas POHs. Mine has performance numbers for "SHORT FIELD" only. Normal landings can be conducted with ANY amount of flaps, per the FLAP LIMITATIONS section. Karl |
#65
![]() "Marty Shapiro" wrote in message ... I guess no one has ever landed an airworthy 1977 C172N! Landing an unairworthy airplane is not the question. It's knowingly taking off with an unairworthy airplane that is not only illegal but stupid. Karl |
#66
Karl,
Not being able to select the proper flap for landing conditions is a serious training flaw. Full flap all the time is ridiculous. That the POH doesn't say ;-) -- Thomas Borchert (EDDH) |
#67
On Wed, 11 Jul 2007 17:38:09 +0000, Hilton wrote:
NOTE: If one or both of these conditions are not met, the aircraft would be considered unairworthy. What about an otherwise airworthy aircraft whose airworthiness certificate was destroyed in the laundry? Is that airplane airworthy? My understanding (not having researched this; just what I was told) is that it is not. That despite being itself in fine shape absent a paperwork problem. Not quite the same, but still not really TC or "condition for safe operation" issue: what about a perfectly fine airplane that's out of annual. Let's take it further, and say that it received a 100 hour inspection on Jan 31 and was out of annual on Feb 1. The only difference is the lack of an IA's signature. Unairworthy? - Andrew |
#68
... "Hilton" wrote in message t... Al G wrote: Never the less, it is left to me to decide, and for a 172 I stand by my statement, even to a FSDO. It is up to you to decide *while adhering to the FARs*, I think you're missing that point. Hilton (b) The pilot in command of a civil aircraft is responsible for determining whether that aircraft is in condition for safe flight. The pilot in command shall discontinue the flight when unairworthy mechanical, electrical, or structural conditions occur Nothing in the "regs" says I have to use flaps in a C172. Al G "karl gruber" wrote in message ... Maybe not, you don't have to USE them..........but they must be operable. Karl I don't see where that is true. Hilton helped us with the definition: a. The aircraft must conform to its TC. Conformity to type design is considered attained when the aircraft configuration and the components installed are consistent with the drawings, specifications, and other data that are part of the TC, which includes any supplemental type certificate (STC) and field approved alterations incorporated into the aircraft. Obviously the 172H was certified to fly without flaps, as that is the normal operating mode. The G's allowed are higher without flaps, so it must be safer, right? Many of the tests for certification were done ONLY with flaps up. This aircraft has no KOEL, nor does the limitations section of the owners handbook refer to flaps. I can understand the requirement when operating in a manner that requires them, say over an obstacle. In that case your "Operations" require them. However, I do not see how operating with flaps up and un-available violates any portion of the type certificate, and therefore does not make this aircraft un-airworthy. If an aircraft is certified VFR/IFR, and a vacuum pump goes south, you can operate it VFR without a ferry permit, right? The attitude indicator is not part of VFR certification. Do you need a "Special Certificate" to fly home? How about the landing light or panel lights during daylight operations? Not needed, not part of the day VFR certification. Same thing right? Are you telling me that if you were in Joseph, Oregon, (No mechanics, No Feds, No help), and you had a panel light dimmer failure, that you wouldn't fly home and get it fixed? This is almost getting to the point where "everything" must work, (zero tolerance). If I have two navigation lights on each wing, and one of them burns out, can I fly at night? It sounds awfully unsafe to say I'm going to go out and fly at night with a known inoperative nav light. In fact, if this were true, you would cut your dispatch rate by adding the extra nav light, as that provides one more item to go bad, thereby doubling the effective "Nav Light Cancellation Rate". Al G |
#69
On Wed, 11 Jul 2007 14:48:58 -0700, "Al G"
wrote: Obviously the 172H was certified to fly without flaps, as that is the normal operating mode. The G's allowed are higher without flaps, so it must be safer, right? Many of the tests for certification were done ONLY with flaps up. This aircraft has no KOEL, nor does the limitations section of the owners handbook refer to flaps. I can understand the requirement when operating in a manner that requires them, say over an obstacle. In that case your "Operations" require them. However, I do not see how operating with flaps up and un-available violates any portion of the type certificate, and therefore does not make this aircraft un-airworthy. And for a H model where there is aparantly no limitation to the contrary it likely doesn't. The point here is that at least in the R, S, and T NAV III 172/182 models there *IS* a specific limitation that for all intents and purposes requires the flap system be operable. The point here is that people should check their own aircraft's POH to make sure they are in compliance with the limitations when they have inoperative equipment, regardless of what equipment is inop. If an aircraft is certified VFR/IFR, and a vacuum pump goes south, you can operate it VFR without a ferry permit, right? The attitude indicator is not part of VFR certification. Do you need a "Special Certificate" to fly home? If it's not required explicitly in part 91, the next question that needs an answer is wheter the item is listed as R or S in the KOEL or eqipment list? If it's listed as required equipment in the KOEL or equipment list then I postulate that yes, in fact, you either need to fix it, or you do need a special cert to fly home if that item is inopearive. It can and has been demonstrated to be different from range of aircraft to range of aircraft, even in the same generic model (I.E. Nav II or Nav III equipped 182T), and whatever POH is in that specific airframe is what's required to be adhered to. |
#70
![]() "Peter Clark" wrote in message ... On Wed, 11 Jul 2007 14:48:58 -0700, "Al G" wrote: Obviously the 172H was certified to fly without flaps, as that is the normal operating mode. The G's allowed are higher without flaps, so it must be safer, right? Many of the tests for certification were done ONLY with flaps up. This aircraft has no KOEL, nor does the limitations section of the owners handbook refer to flaps. I can understand the requirement when operating in a manner that requires them, say over an obstacle. In that case your "Operations" require them. However, I do not see how operating with flaps up and un-available violates any portion of the type certificate, and therefore does not make this aircraft un-airworthy. And for a H model where there is aparantly no limitation to the contrary it likely doesn't. The point here is that at least in the R, S, and T NAV III 172/182 models there *IS* a specific limitation that for all intents and purposes requires the flap system be operable. The point here is that people should check their own aircraft's POH to make sure they are in compliance with the limitations when they have inoperative equipment, regardless of what equipment is inop. Agreed. If an aircraft is certified VFR/IFR, and a vacuum pump goes south, you can operate it VFR without a ferry permit, right? The attitude indicator is not part of VFR certification. Do you need a "Special Certificate" to fly home? If it's not required explicitly in part 91, the next question that needs an answer is wheter the item is listed as R or S in the KOEL or eqipment list? If it's listed as required equipment in the KOEL or equipment list then I postulate that yes, in fact, you either need to fix it, or you do need a special cert to fly home if that item is inopearive. It can and has been demonstrated to be different from range of aircraft to range of aircraft, even in the same generic model (I.E. Nav II or Nav III equipped 182T), and whatever POH is in that specific airframe is what's required to be adhered to. Agreed. So the OP was flying a C-177RG, I guess it depends on the year, and what is in the KOEL if applicable. Al G |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
Flaps on take-off and landing | Mxsmanic | Piloting | 397 | September 22nd 06 09:02 AM |
Fowler flaps? | TJ400 | Home Built | 20 | May 19th 06 02:15 AM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
FLAPS-Caution | Steve Leonard | Soaring | 0 | August 27th 05 04:10 AM |
