Flaps on take-off and landing
Old September 14th 06, 06:55 AM posted to rec.aviation.piloting
Mxsmanic
Default Flaps on take-off and landing
At what point does one normally set flaps before take-off? I've been
doing it only when aligning with the runway, on the theory that
extending flaps prior to that would just make me more vulnerable to
wind while on the taxiway or at the gate. Similarly, I retract the
flaps completely as soon as I'm completely on the runway for landing,
so that the wind doesn't push me around. Is this the correct way to
do it?
Old September 14th 06, 07:28 AM posted to rec.aviation.piloting
jad
I generally extend flaps as I approach the holding point, stops the wind
grabbing you and better visibility all round (well for the Cessna)
As for retracting, I use them for a drag advantage to slow the aircraft
down and retract when I have full nosewheel steering control of the
aircraft!
This is real world, as for simulator.. just throw them down during the
taxy! Generally, airline drivers have flaps set prior to taxy after
pushback!
Jad
do it?
Old September 14th 06, 08:11 AM posted to rec.aviation.piloting
Peter Duniho
"Mxsmanic" wrote in message
do it?
It depends on the airplane and the pilot.
Personally, for the airplane I am flying the most, I have the flaps down
from preflight to takeoff. This is because the airplane requires flaps for
landings and takeoffs, there is only one "flaps down" setting, and I like
having the flaps down during the preflight as well. So I put the flaps down
before a landing, and they don't come up until after the next takeoff.
For Cessnas, which generally don't require flaps for takeoff, it's a
different matter. I lower the flaps for the preflight inspection so that I
can properly inspect the flap mechanisms, but then retract them after engine
start and before taxiing. Certain takeoffs may dictate lowering them again
prior to takeoff, which I do as part of my pre-takeoff checks, which include
reviewing the takeoff procedure checklist (flap setting is listed with the
checklist items for the takeoff itself).
Some pilots retract the flaps as soon as they touchdown, with the theory
that this will enhance their braking. However, IMHO this ignores the fact
that there is more aerodynamic braking with the flaps down early in the roll
out, and by the time the extra drag is negligible, so is any additional lift
the flaps might be generating. It also ignores the hazard in some airplanes
of accidently retracting the landing gear rather than the flaps.
Other airplanes run the gamut in terms of what's required or desired
operationally, and of course each pilot may have their own preferences as
well.
IMHO, since you're not actually flying an airplane, I wouldn't worry about
it. Put the flaps down whenever you want.
Pete
Old September 14th 06, 12:54 PM posted to rec.aviation.piloting
Mxsmanic
Peter Duniho writes:
Doesn't flap movement require engine power?
The idea is to try to approach real life. Additionally, many things
are simulated. If adjusting flaps has a bad effect in real life,
there's a good chance that it has a bad effect in simulation as well.
Old September 14th 06, 01:09 PM posted to rec.aviation.piloting
Jim Macklin
Some airplanes use electric motors to move the flaps, some
use engine driven hydraulic pumps. Some use hand cranks and
some use a lever.
Most light aircraft use either a mechanical human powered
lever or crank or electric motors that will run on the
battery. Heavier airplanes, over 12,000 pounds often use
hydraulics. Sometimes the hydraulic pumps are electric
powered, but engine driven pumps are common.
many things
real life,
simulation as well.
Old September 14th 06, 04:41 PM posted to rec.aviation.piloting
Ron Natalie
Depends on the aircraft. Some planes they are purely mechanical from
the flap handle in the cockpit. In others they are electric. On my
plane they are hydraulic, which is run from the engine if it is running
but has a backup "wobble pump" which I can use to retract them on the
ground if I forget to do so before shutdown.
My plane specs flaps up or 1/2 for takeoff (short field takeoff done
with 1/2). Landing can be done with any setting of flaps.
Old September 15th 06, 01:16 AM posted to rec.aviation.piloting
Mxsmanic
Ron Natalie writes:
I'm surprised that a small handle in the cockpit would provide enough
leverage to lower flaps. Isn't there are a lot of aerodynamic
pressure to overcome against them (at least if they are lowered in
flight)?
I'm always surprised by how much is still mechanically linked in
aircraft. I'm not necessarily saying that's bad--simple is reliable,
generally speaking--but somehow I don't picture control surfaces as
something that one could easily move without assistance. I suppose
small planes are lighter than they appear, and just because the wings
look relatively big doesn't mean that they are heavy or hard to move.
I've always been landing with flaps down completely, and usually
taking off with some flaps, as I had read that this was necessary (and
I had seen accident reports about pilots who crashed because they took
off without first lowering flaps). But from what you and others here
say it sounds like I have considerably more discretion in whether or
not I lower flaps for both operations.
Are there good reasons to lower flaps in flight, outside take-off and
landing? I've thought that they would be useful for increasing drag
and lowering airspeed, but since they apparently cannot be used at
high speeds I guess this isn't a good idea. Sometimes if one must
descend rapidly just idling the throttle doesn't seem to be enough to
stay below hazardous speeds, and few aircraft seem to have speed
brakes.
Old September 15th 06, 02:01 AM posted to rec.aviation.piloting
Margy Natalie
Mxsmanic wrote:
Ron Natalie writes:
Who said the handle is small? Some of these "handles" are 2 - 3 feet long.
Margy
flight)?
Old September 15th 06, 02:39 AM posted to rec.aviation.piloting
Jim Macklin
Every airplane with flaps has speed limits with flaps
extended. If there is a positive stop, they may have a
series of allowable speeds. The same sort of limits apply
to landing gear extension and operation with the gear
extended.
In some airplanes the gear is not to be extended at speeds
above a certain speed because the motor and linkage is not
strong enough, but once fully extended and lock down, the
airplane can be flown at a higher speed. Some airplanes can
have the gear extended at very high speed in an emergency,
but then the gear doors may be damaged and require
replacement or adjustment before the next flight.
Real airplanes and the simulators that exactly duplicate a
particular airplane are flown by the identical procedures.
Table-top PC "simulators" are more properly known as
training devices and they mimic some generic airplanes.
A real simulator costs more than the airplane it is
duplicating, a Beechjet or Boeing simulator can cost $8-10
million dollars or more. It is worthwhile because it
doesn't burn several thousand pounds of fuel per hour, can
be run nearly 24/7, rarely kills anyone and it is a safe
place to do things that can't be done safely in a real
airplane. Also, it allows the airplane to be out earning
revenue.
Even a PC based training device is very useful for learning
and practicing procedures, but you get what you pay for. A
King Air trainer with out full visual and motion still
allows learning all the systems and practicing the various
emergency and abnormal procedures.
| Ron Natalie writes:
mechanical from
provide enough
aerodynamic
lowered in
| flight)?
linked in
is reliable,
surfaces as
I suppose
because the wings
hard to move.
takeoff done
flaps.
usually
necessary (and
because they took
others here
whether or
take-off and
increasing drag
used at
one must
be enough to
speed
| brakes.
Old September 15th 06, 03:03 AM posted to rec.aviation.piloting
Tom Young[_2_]
"Mxsmanic" ... wrote in message
flight)?
In a Beech Sundowner the handle is maybe 18" long and looks like a big
version of a parking brake lever that you might see in a car. There's more
resistance the higher your airspeed, but it pulls up easily enough below the
max flaps speed. Also, it's good to have a bit of mechanical feedback like
that in case you don't have your wits about you and try to pull flaps at too
high an airspeed.
brakes.
Flaps have two main effects, they increase drag, like you said, and they
also increase lift and reduce your stall speed. These two effects can be
useful at different times. For example, if your wing is on fire and you want
to descend quickly, you lower the flaps and descend at Vfe (max speed with
flaps extended, top of the white arc). It's an interesting exercise the
first time you practice it, with the ground filling up your windscreen like
that and all. Another use is when you simply want to fly slower, such as
when you're in the traffic pattern and want to avoid getting too close to
someone in front of you. You can slow down without flaps, but using them
keeps you farther from a stall, which is a good thing at pattern altitude.
I'm sure more experienced pilots can give more interesting ways to use flaps
in normal flight, but those are the ones that come to mind just now.
Tom Young
