Dirty oil, part II
Old July 14th 07, 11:35 PM posted to rec.aviation.owning
Default Dirty oil, part II
On Jul 14, 8:55 am, "Dennis Johnson" wrote:
ps.com...
The temp in the pan is true state of affairs in the engine.
While that might be true, I think the benefit of measuring oil temperature
as the oil enters the engine is that it enables the engine manufacturer to
provide meaningful oil temperature specifications. For my engine, TCM says
that the oil entering the engine (after passing through the oil cooler) can
be as hot as 240°F at full power and still be acceptable. TCM apparently
feels that so long as the oil entering the engine is no hotter than that,
then the engine will be fine so long as I'm using a recommended oil. For
takeoff, the oil entering the engine should be at least 100°F as it enters
the engine.
If we measured oil pan temperatures, the engine manufacturer would never
know what kind of oil cooler we had or how well the cooler was installed and
could not specify a maximum or minimum oil temperature because they wouldn't
know how efficient the oil cooler was.
Dennis
If we/ they didn't measure the temp of the oil as it left the pan the
oil manufacturer would have no idea how to formulate the correct
viscosity, additives, and anything else needed to make oil perform at
a given temp. . In a certified plane the manufacturer knows exactly
what kind and how efficient the oil cooler is. They would never honor
a warranty if they didn't. Take a Piper, leave on the winterazation
[sp] plate that blocks alot of the air feeding the cooler. Fly said
plane through death valley when the air temp is 120+f, now take plane
to local dealer for a warranty claim for a "cooked" motor and see how
fast they laugh you right out of the hangar........ G
Ben
Old July 15th 07, 10:57 AM posted to rec.aviation.owning
John Galban
On Jul 13, 7:39 am, "Dan Luke" wrote:
"Jim Burns" wrote:
From Sac Sky Ranch:
1. Blowby of combustion gases past the piston ring belt. Accompanied by
high
oil temperature and increased oil flow out engine breather. Check engine
compression.
Borescopes and compressions were ok, but I still think it was something like
this that was going undetected. But what?
Did you get any compression numbers from the shop? I've found that
what TCM considers to be "OK" compressions, wouldn't necessarily be
considered OK by a lot of mechanics. A friend had a cylinder in the
50s a couple of years after a TCM factory overhaul and they considered
it "OK".
Old July 15th 07, 12:35 PM posted to rec.aviation.owning
Dan Luke[_2_]
like
it "OK".
Compressions were all in the 74-78 range, about the same as at annual a few
months before.
Dan
T-182T at BFM
dirty oil Dan Luke Owning 46 March 15th 07 02:25 PM
Dirty Laundry [email protected] Piloting 6 October 18th 06 10:36 PM
dirty bird The Weiss Family Owning 9 November 9th 04 05:14 PM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
Vic Tatelman's Pictures of "Dirty Dora", "Dirty Dora II" and the Surrender Mission Adam Lewis Military Aviation 0 February 3rd 04 03:39 PM
