Gear up takeoff
Old July 18th 07, 02:37 AM posted to rec.aviation.piloting
Morgans[_2_]
Default Gear up takeoff
"Roy Smith" wrote
Bombers have an advantage over other types on these types of takeoffs.
When you feel the aircraft starting to settle, you can just hit the button
and drop your load. The sudden decrease in aircraft weight will give you
the extra performance boost you need to start climbing.
But, even IF the bombs were hot, it would be helpful if the bomb bay doors
were opened, first. g
Jim in NC
Old July 18th 07, 02:40 AM posted to rec.aviation.piloting
Morgans[_2_]
"Gatt" wrote
Some/all B-17s will do that too. When Evergreen turned me loose in their
bird (flipped on the battery and open the bomb bay for some visiting WWII
vets) I was specifically briefed NOT to bump the landing gear lever or it
would be a very bad day at the hangar. I've had more than one nightmare
of doing just that since.
Did the B-17 not have landing gear locking safety pins to keep that from
happening once they were safely on the ground?
Jim in NC
Old July 18th 07, 05:31 AM posted to rec.aviation.piloting
IIRC, the B-17 (and probably all other US bombers) had a safety cable across the
lower part of the bomb bay which would open the doors if a bomb inadvertently
dropped.
Old July 18th 07, 03:26 PM posted to rec.aviation.piloting
john hawkins
don't know anything about the cited incident but. Ever watch an older
mooney doing the gearup dip on takeoff? pulling that johnson bar takes your
attention off the flight attitude.
"john smith" wrote in message
DESCRIPTION
AIRCRAFT ON TAKEOFF, SANK DOWN ONTO RUNWAY WITH GEAR RETRACTED, FORT
LAUDERDALE, FL
Is this an example of putting the gear lever up before advancing the
throttle for takeoff?
Old July 18th 07, 04:45 PM posted to rec.aviation.piloting
Andrew Gideon
your attention off the flight attitude.
Cessna gear (ie. an R182) folds under in such a way that drag is
increased during the retraction (or extension) beyond the level of drag
with the gear extended (or retracted, of course {8^). I've never thought
it that much that it would cause an altitude loss, but perhaps under the
right circumstances...?
- Andrew
Old July 18th 07, 05:43 PM posted to rec.aviation.piloting
pgbnh
Have not read the details, but I offer one vote for the cause being an
attempt to retract FLAPS and laying a hand on the wrong switch
DESCRIPTION
LAUDERDALE, FL
Old July 18th 07, 09:30 PM posted to rec.aviation.piloting
Andrew Gideon
On Wed, 18 Jul 2007 12:43:18 -0400, pgbnh wrote:
the cause being an
Why do so on t/o that close to the runway?
- Andrew
Old July 18th 07, 09:51 PM posted to rec.aviation.piloting
Al G[_2_]
"Andrew Gideon" wrote in message
news
- Andrew
The old 210's and skymasters were the same way. Once all of those doors
start opening, there is
a slew of new drag. An Ex-Boss of mine was demonstrating the squat switch
to a prospective buyer, when he retracted the 210 nose gear while sitting
firmly on the ground.
Al G
Old July 19th 07, 04:52 AM posted to rec.aviation.piloting
Peter Dohm
"Morgans" wrote in message
their
WWII
it
Jim in NC
I don't believe so. The mechanism is jack screws, rather than hydraulic or
pneumatic, so they should not be needed.
Peter
Old July 19th 07, 06:00 AM posted to rec.aviation.piloting
Ricky
On Jul 17, 5:10 pm, Roy Smith wrote:
"Montblack" wrote:
("Ross" wrote)
My father was an B-25 instructor in CA during WWII. He said some of the
cadets would do this and the CO would be real mad when the B-25 settled
back to earth.
B-25 ....BOMBER!
I'm with the CO on this one. :-)
Paul-Mont
When you say "drop your load" do you mean drop the bombs?
Is it the decrease in weight or the exploding bombs that gave that
"extra performance boost you need to start climbing?"
Ricky
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
Crashing on takeoff... how odd ramapriya.d@gmail.com Piloting 165 August 31st 06 04:30 AM
seaplane takeoff Lets Fly Owning 1 December 5th 05 10:18 PM
Takeoff with a problem? Rocky Piloting 14 January 23rd 04 02:26 PM
Jet takeoff performance karl gruber Piloting 6 November 21st 03 05:59 PM
